Question about Reebok New York Giants Eli Manning Jersey
Missing clip for reebok adjustable chrome hand weights
Clip has a post that fits in hole to secure 1, 2, or 3 pound weights.
I also need the clip! Have you found a solution?
Posted on Apr 22, 2012
Cannot open the dvd drive e-the tray for inserting a disc does come out on pressing the button or clicking on the word eject
Every manufacturer for DVDs add a small hole in front of the device. The hole is big enough for a normal paper clip to fit. Untwist a paper clip and gently insert it through that hole. If you do it correctly it will automatically pop the door open.
This is not a permanent fix as the physical DVD door might be bad but it will work anytime you insert the paper clip.
BiL
JESSERIE1@HOTMAIL.COM
Dec 06, 2013 | MSI Computers & Internet
Installing Harley Davidson Chrome & Rubber Hand Grips Large 56263-96A
Sounds like the throttle lock is possibly binding up. Remove the right grip. There should be a little half moon shaped piece of plastic in there at the bottom of the switch housing. This plastic piece will have a small hole in the outside edge. This hole has to be placed over the pointed end of the throttle stop. The throttle stop is the plastic star wheel on the outside of the bottom of the right switch housing. There is a small metal Jesus clip on the inside of the switch housing. This clip is supposed to hold the stop from being turned completely out of the switch housing. It's possible the clip came off and is wedged in there.
May 20, 2012 | 2005 Harley Davidson FLSTC - FLSTCI...
The screws won't stay in the hinges on my Maytag dryer door, model #PYG2300AWW. It's like the holes in the cabinet are too big for the screws. Is there something else missing that they should be...
Hi ddyreson...
You are missing a sheet metal clip.
It will clip on the sheet metal with the large hole in it, to convert it from a large hole to a hole that you need to fit the screw...
Look around where you disassembled the dryer, it is somewhere in the area or in the dryer...
You can get replacement metal clips at HomeDepot,Loews,Ace Hardware,etc.
Please take time to rate me
Sep 05, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Hello there, I have a Bosch Logixx dishwasher which I purchased just over 2 years ago. My upper dishwasher tray is not fitting properly into the hose pipe holes on the inside of the back wall of the...
Hello Deepak,
You can definitely fix this yourself, but I'm not entirely sure from your description which part is "dropping off". It may be a simple fix where something needs to be clipped back into place or you may need to replace something. Please can you take a look at the images below and identify which part you are having trouble with.
Below is the back of the upper spray arm which clips on to the upper rack. It has a grey plastic cover behind which is a large white plastic washer / gasket. The washer simply slots in to the back of the spray arm and the grey cover clips in over the top.
Your description suggests the grey plastic cover and/or the white washer are dropping off. If the grey plastic cover is missing, it may have fallen into the bottom of the washer under the lower rack, in which case you should be able to find it and clip it back on. If it's missing or wont clip back on, you will need to replace the upper spray arm as the cover and washer are not available separately.
This is the water delivery tube which clips to the back wall of the washing compartment. There is a metal clip which secures the tube to the wall. The open hole and one of the spigots slot in to the two holes in the back of the upper spray arm above. The spigot used depends on which height setting the upper rack is on.
Basically, everything simply clips together. If nothing is broken, you should be able to fix this at no cost by simply clipping the offending part back into place.
Hope this helps. If you need further assistance or help locating replacement parts, please let me know what needs to be replaced. Nearly all Bosch parts are available and in stock direct from Bosch.
Regards,
BElectric
Apr 13, 2011 | Bosch 24 in. SGS69L02 Logixx Built-in...
Please, I want to Know, how ti change the rubber door seal? thank you.
Hello there
Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some AEG machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the AEG door seal/gasket that locates on the drum makes fitting the new seal easier.
5 Your new AEG washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 Refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test your AEG machine for any leaks,
I
Jan 01, 2011 | AEG L66600 Front Load Washer
I need the key for the 740 cs model
Call Icon fitness @ 1-800-999-3756
Part #: 119038
Part Name: ASSY,CLIP/ROPE/KEY
Model: 299460 - PROFORM 740CS/745CS
Part List: #119038 - KEY/CLIP
Quantity on Model: 1
Price: $2.35
Weight: 0.020lbs.
May 14, 2010 | Exercise & Fitness
Fitting new door seal ,how to remove old seal and fit new seal?
Follow these steps to replace your door seal:
For all Free appliance repair videos visit ourVIDEO TUTORIALS
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a springsystem holding them, but some have a tensioning arrangement that has to be loosened.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the door seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test the machine for any leaks,
All washing machine spares featured in this article are available at apart4u with more video help in ourtutorial section.
Information provided is a guide only. aPart4u accepts no liability for any problems occurring whilst attempting any advice shown. If in any doubt about fixing your appliance, always contact a qualified repairer.
Mar 31, 2010 | Hotpoint Aquarius WD640 Front Load...
Repacing the door seal on my oko lavamat washing machine
this could be out of the door tension clip you might see it in this video
All washing machine spares featured in this article are available at apart4u with more video help in our tutorial section.
Sep 04, 2009 | AEG Lavamat 88840 Front Load Washer
Attach the clip to the rod from the outside handle to the latch
You should get a new clip because the old ones don't usually last very well once they are taken off. They're cheap at the dealer. Put the clip in the hole of the latch first, then slide the rod into the clip and fasten it to the rod. It just pushes onto the rod.
When the rod is hanging from the door latch it should line up with only one hole. Hope this helps.
Aug 30, 2009 | 1999 Chevrolet Silverado 1500
I have a worn clip - the open close clip to secure the adjustable handle in place. I have the new part but, not sure how to fit it. Can you help?
Yes. Remove the handle and cable, then remove the bag compartment cover. At the back of the bag compartment, towards the top, you will see four screws. Ignore the one furthest to the left, and unscrew the other three. That will release the cover at the rear, and expose the clip you want to get at. The clip is held in place by a metal C-clip, which can be levered off with a screwdriver, but be careful not to damage it because you will need it to secure your new clip. when you've got the new clip in place, re-position the cover (not that it clips in at the top first), replace the three screws and the job's done.
I value your feedback, so please remember to rate this response.  Good luck!
Jul 22, 2009 | Sebo X4 Bagged Upright Vacuum
Reebok New York Giants Eli Manning Jersey Logo
64 people viewed this question
Top Reebok Sport & Outdoor - Others Experts
Tony
michael
michael
Are you a Reebok Sport and Outdoor - Other Expert? Answer questions, earn points and help others
