Question about Rockford Fosgate Punch P3002 Car Audio Amplifier
I have a PUNCH P3002 amp, it has power and the light on my remote knob is on and now all of a sudden the woofers are'nt working.I checked the grounds, the battery and speaker wire and found nothing obvious, what now?
  • kjames13176 Mar 03, 2009
    The protect light comes on and then the amp turns back on but nothing to the speakers and all the wire hookups are fine. The protect comes on as soon as the speaker begins to hit. IT work great when i originally put it in.
  • pbalien73 May 07, 2009
    I have the same issue except the fuse has blown twice now. Worked fine for 2 years now all of a sudden its not working. Powers up but protection light goes on and off. Help!
    Problem Solver:
  • 10 Answers
Might be your rca connections if everything else seems 2 be working right. best thing 2 do is check each item seperately. you could use a friends car if he/she has a system. just make sure u know what your doin because u dont want to fry their set-up. but u can always have the amp bench tested @ a stereo shop or electronics store. someone somewhere close to u has a test bench u just might have to research a little. good luck. I have the same amp and they kick ***.
Posted on Oct 10, 2009
    Problem Solver:
  • 12 Answers
Be sure the ground and remote are not touching within the amp
Posted on Feb 26, 2009
Rockford Fosgate P3002 stopped working
push down and up on your subs and see if they make a starching noise, if they do then they are blown. take a test light to the amp, on the power and the remote and see if it lights up. if it does then turn the amp down and with a small speaker plug it in to the speaker outs on the amp and see if it plays if not then your amp is bad.
Nov 26, 2013 | Rockford Fosgate Punch P3002 Car Audio...
Hi i purchased the bnps102 woofers and used them for 2 weeks i really enjoyed them and i also purchased the pyle 1400 watt amp and a jvc deck along with the boss amp kit installation now the speakers about...
If the lights on your sub box aren't coming on it's either your ground of power wire came loose or the transformer blew. As for the subs, make sure all the connections are good, especially on your RCA wires. If your amp is getting power, then check your speaker connections. Also, make sure to turn the gain know up. The gain knob is located next to the RCA input on the amp. Let me know if this helps.
Aug 21, 2011 | Pyramid BNPS102 Car Subwoofer
My sub woofer has recently stopped working. I borrowed and hooked up a friend's subwoofer and still doesn't work. However all my other speakers in the car are still working. Could this be the amp? If the...
If you only have the sub connected to the amp, the other speakers would still play, if they are just connected to the head unit. I would check for power and remote power to the amp, and check the ground, if those are ok, I'd say the amp is bad.
May 21, 2010 | Rockford Fosgate Punch 401S Car Audio...
How do you install an amp in new cars when the factory radio is basically an computer and doesn't come out of the dash?
You need to use a Hi Low Converter. They have a different name but I cant think of it right now. Basically it connects to your rear speaker and converts it to RCA connectors that you could connect to your amp. Then connect your amp to power (battery) and Ground to power it up. Last thing to do is connect yours speakers to the amp.
Also get a high Low converter with remote connection.
Apr 22, 2010 | Rockford Fosgate Punch P3002 Car Audio...
Amp not working to power sub woofer
remote wire/ fuse possible? have you checked?
traced all voltage?take and disconnect remote wire from amp and make short wire from remote to 12v if green light works then u may have bad remote wire or blown fuse.
Oct 05, 2009 | Kicker ZX10001 Car Audio Amplifier
Amplifier has no sound
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Your amp is clipping.
A thumbs up would be greatly appreciated if this answer is helpful to you. amplifier-no-sound-peeu4x5nsxvd53n2rwetiqa4-3-0.jpg
Jan 10, 2009 | Rockford Fosgate Punch P325.1 Subwoofer...
Need to hook up two amps input and output
no, all u got 2do is run ur rca from the output of one too the input of the other
Jan 02, 2009 | Rockford Fosgate Punch P3002 Car Audio...
Infinity 3.5c , 2 powered Woofer 5.25" suddenly no sound.,
The woofers on my 3.5c stopped working, but with mine the light was off. I unplugged it and left it for about 24 hours and then plugged it back in and it worked. No idea why. It's happened twice and each time takes at least 12 hours or a day or so before it'll work again, just unplugging it for an hour won't do it.
It seems like both times the problem started when the speaker got unplugged without it being shutoff first, but I can't confirm.
But if your light is still on it's probably a different problem. With my 4.1t towers when the light was on but there was still no sound it equated to numerous fried amp components which cost about $150 for repair.
Oct 31, 2007 | Infinity Intermezzo 3.5C Center Speaker
Blowing fuses
check your car battery and check your ground and check your power wire for any splits or cracks
Nov 22, 2006 | Rockford Fosgate Punch P3002 Car Audio...
Rockford Fosgate Punch P3002 Car Audio Amplifier Logo
278 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
