Question about Dometic Rooftop RV Air Conditioner
Coleman rooftop a/c coachman travel trailer
I have a rooftop coleman a/c. the ran runs fine but the compressor(motor) continues to run even when i switch off the thermostat. the only way to cut it off is to flip the breaker... please advise
  • 144 Answers
It's likely that the contacts are stuck closed. You can usually just tap them with a screw driver and they will open but then you should replace them. If you don't know where they are. Find the power wires coming inside the unit and follow them. Contacts are fairly easy to replace as long as you do it wire for wire. In other words when you remove a wire from the old attach it to the new before removing another. I hope this helps. Please don't forget to give me a Fixya rating.
Posted on Feb 26, 2009
Dometic duo-therm rooftop ac unit motor wont spin unless i jiggle the wires that go into the motor then it works! Trailer sat in a monsooon storm last night. next morning compressor kicks on just fine and...
If you have to jiggle the wires going into the compressor motor to get it going, I would submit that you may very well have a broken wire or otherwise loose connection that is making contact when you jiggle the wires. If all appropriate connections were good, jiggling the wires would/should have no effect. I assume you are jiggling wires AT THE MOTOR input and not elsewhere in the circuitry. After you jiggle the wires and get it started, does it continue to run? or if not, describe more thoroughly what is happening..
Jul 14, 2012 | Dometic Rooftop RV Air Conditioner
I have a springdale travel trailer with a dometic ac system. When I turn the air on, with the fan in the auto position on the thermostst, the compressor turns on and runs, but the fan does not. The...
The fan should run in the 'auto' position.
If it runs (on hi and lo settings) then I doubt if anything is wrong with the fan motor.
I would think your thermostat is bad and needs replacing.
Jun 05, 2011 | Dometic Rooftop RV Air Conditioner
Keeps kicking breaker
Your unit is pulling too much power which is popping the circuit breaker. Either the compressor motor or Fan motor has a problem and you need a pro here. Drawing excessive electrical current is not good and you can do even more damage to your unit by continuing to try and run it!
Jul 19, 2010 | Dometic Rooftop RV Air Conditioner
You dont have a filter on top unit but you need to have your fan impeller and condensing coil clean regularly about once a year and more when your on dusty area.
Aug 21, 2009 | Dometic Rooftop RV Air Conditioner
We have a Coleman 7300 rooftop ac unit. When the
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of
tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
Jun 07, 2009 | Dometic Rooftop RV Air Conditioner
Coleman Mach 3 Rv air conditioning
Dirty coils might be your problem. You might have a refrigerant problem as well. Try cleaning it first then have a tech put gages on it. Doesn't sound too serious
Jun 12, 2008 | Heating & Cooling
I would check the thermostat based on what you said it could be out of calibration
Jun 11, 2008 | Coleman Mach 15 Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
765 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
