Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Hi, I have a phillips 55pw936317f wide screen, the screen is red and can't adjust it out.
Take the panel off the back and you can adjust R B G +/-
Posted on Feb 26, 2009
Convergence problem
Both convergence chips need to be replaced and or some resistors and set adjusted.
If have the original remote go into menu and select convergence to see if it will adjust---if not chips etc need to be replaced.
Set most likely uses 2 stk-392-120 chips but a few use the -110 chip.
May 29, 2012 | Philips Televison & Video
55PW936317F appears to me to be to red
Turn the color off and or go to a black and white program--stand back and examine the screen--what color is screen with no color?
If red or pinkish you may be able to locate and slightly adjust the red screen control down to get rid of this.
It is not real easy on this set as the controls are inside the set and face the rear--two person job--one watches the screen and the other slowly turns (tiny bit at a time) the red screen down.
May 28, 2012 | Philips 55PP9401 55" Rear Projection...
I replaced the lens fluids on a Philips Magnavox 55PW936317F. I might have bumped the magnetic rings on the end of the CRT tubes out of alignment. Now the blue is way off and I can't seem to fix the...
The rings are what center the projected image. Locate the exact center of your screen then cover the other two lenses and then you can adjust the rings to get as close to center as possible, then you should be able to complete the convergence alignment when the other two CRTs are uncovered.
May 09, 2011 | Philips Televison & Video
Another tv issue, I have a phillips 55pw936317f that when i plug in the power light is red, not green. Also when plugged in there is a hissing sound where 120v wires go in. Does anyone know what to first?...
Your signal board is in need of repair. This is the board with all the rca jacks and antenna connections. The high pitch hissing sound was the best clue ever.You will need to see a tv tech and have him rework or replace the convergence board [aka the signal board] Good Luck and thanks for asking!
Jun 23, 2010 | Philips 55PW9363 55" Rear Projection...
My 60" Phillips tv has a blurry picture at the bottom and the top
The convergence output IC's need to be changed. A very common problem with all projection tvs.
Jun 04, 2009 | Philips 60PP9352 60" Rear Projection...
Phillips tv , double vision,
You have bad convergence IC's. Replace both the red and blue drive chips. They are easy to spot. They are mounted to large, finned heat sinks. The # on the chips starts with "STK-" and then there are numbers following. Both red and blue use the same part. There are 20 or so pins to unsolder\solder. These parts are available to the consumer from tritronicsinc.com. Good Luck!!
barneyluc
Oct 03, 2008 | RCA R52WH73 Projection Television
Sony KP-53XBR35 TV Concave top & Bottom in wide screen, along with color distortion around sides
thats usually a convergence IC failure, Are you able to move the red and blue colors in the convergence adjustment menu?
Jul 14, 2008 | Televison & Video
The TV is a Phillips Matchline 55"; wide screen, approx 7 years old.When switched on the LED goes red then there is a clicking sound then the LED blinks red continuosly and there is no picture.
The TV is going into protective shutdown. What is the model number of your set? I may be able to help you depending on the chassis number.
Mar 13, 2008 | Televison & Video
Tv help
Symptom: PICTURE PULLS
Cause: DEFECTIVE D702,D703,D704
Symptom: DIGITAL CONVERGENCE WON'T ADJUST
Cause: DEFECTIVE DCU
Jan 14, 2008 | Hitachi 50SBX70B 50" Rear Projection...
Service Manual for sp43t8-hex/shi - convergence problem
My sp43w6hpx needs the red pulled back in any one help with service manual
Dec 21, 2007 | Samsung HCN436W 43" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
288 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
