Question about Drive Medical Mini Phantom Three Wheel Compact Scooter Blue - 1 each
Need a battery pack for phantom three wheel scooter
Batteries stolen and need a new battery pack.
  • 10,865 Answers
Http://www.alphasource.com/products/batteries/?CMP=KNC-GOOGLE&HBX_PK=G_medical_equipment_battery&HBX_OU=50&gclid=CJH1_o-d-JgCFQrAGgodIHEPng
that web site has all of the medical scooter batteries for sale.
please rate my answer as a fixya.
Posted on Feb 25, 2009
Phantom battery won't charge
Hello
Are you sure your battery charger is working correctly. Have you tried it on another battery? Possibly, there is a wiring problem, or your battery is the type that needs distilled water - Try another known good and charged battery with your scooter before purchasing a new one to ensure that the wiring is not faulty.
ilona
Aug 02, 2017 | Drive Medical Mini Phantom Three Wheel...
I have a Dr.k scooter and the charger say it's full but it wont go
My 94 year old mother has Dr. K. Drive scooter (f66) 0511232 4067
Battery Pack S/N: 0521323 Model: HP-1202B. Her Great Great Children have misplaced the key. As Mother is no longer able to stand, I need to order a key so we can go for walk. Where do I order a key?
Patt
May 29, 2011 | Drive Medical Mini Phantom Three Wheel...
My Dad just passed away and his Dr. K Phantom 3 wheel scooter won't run. When I plug the charger in, it says its fully charged. When I unplug it..it reads E..I want to donate this to a nursing home locally...
tar the batteries are probably too low to charge with the scooter charger and need to be replaced. With the charger plugged in it will indicate a full charge beacuse its reading the output of the charger but when you unplug it the batteries are too low to indicate any voltage. hope this helps you
Apr 10, 2011 | Drive Medical Mini Phantom Three Wheel...
I need to find a stackable battery box for my scooter, as well as what batteries are needed. Also, what charger should be used with it? I bought used from a private party-no charger and the small battery...
James your scooter use 2 12-12ah batteries located inside the battery case. Just remove the screws holding the case together and remove the old batteries then replace with the new ones making sure that you repace the wiring just as you removed them from the old batteries you might also have a heat sensor attached to one of the batteries make sure you reattach that to the new batteries. Any off board charger made for power chairs or scooters will work but try to find a 4 amp charger with an on/off switch. Always turn the charger off when plugging or unplugging from the scooter Check on e-bay or with a provider for a charger Hope this helps
Nov 18, 2010 | Drive Medical Phoenix 3 Wheel Compact...
I have a pride go go elite traveller 4 and need some new batteries, but what batteries and connection am i looking for?
Rachel you need 2 12/12AH batteries that are located in the battery pack under the seat. Simply pull the battery pack from the scooter and with a standard phillips screwdriver remove the many screws attaching the battery pack together (simply turn the pack over to get to the screws) There will be two wire on each battery and also a heat sensor attached to the side of one battery remove the wires from each battery and carefully reove the heat sensor. You can bring one of the batterys to your local battery warehouse type store or a provider and purchase 2 new ones reinstall like you removed attaching red wire to red terminals and black to black terminals and reattach the heat sensor to the side of one battery (you can use packaging tape to reattach). replace all the screws to put the case back together and reinstall in your scooter. Charge the batteries with you charger until the charge light is green then happy riding HOPE THIS HELPS
Aug 20, 2010 | Pride Mobility Products Go-Go Elite...
Batteries won't charge
Hi. Sounds like there is a faulty connection somewhere between the charger and the batteries. Are the batteries connected correctly. The charger uses the voltage level in the batteries to regulate itself. If there is a faulty connection, then the charge will not operate. Use a multi-meter to check if the batteries are connected correctly. There should be 24 to 26 volts across both batteries.
This fault can also be caused by a faulty charger socket. Check for any signs of melting or heat damage. There might also be a disconnected wire in the plug on the charger itself.Good luck. Neil.
May 29, 2010 | Drive Medical BLUE 3 Wheel Compact Mini...
Where and how do I replace my battery for my pride gogo ultra travel scooter
Do not use batteries with different amp-hour (Ah) capacities. Do not mix old and new batteries. Always replace both batteries at the same time.
MANDATORY!
Battery posts, terminals, and related accessories contain lead and lead compounds. Wear goggles and gloves when handling batteries and wash hands after handling.
WARNING! Always use two batteries of the exact same type, chemistry, and amp-hour (Ah) capacity. Use 12 Volt deep cycle batteries.
1.Remove the battery pack from the Travel Scooter.
2.Carefully turn the pack upside down.
3.Remove the eight (8) screws from the perimeter of the battery pack.
4.Carefully turn the pack right side up and remove the lid.
5.Disconnect the black (-) and red (+) battery cables from the battery terminals.
6.Remove the old battery.
7.Place a new battery in the battery pack.
8.Connect the red battery cable to the positive (+) battery terminal.
9.Connect the black battery cable to the negative (-) battery terminal.
10.Position the lid back onto the battery pack ensuring all wires are inside the pack so they don’t become pinched.
11.Carefully turn the pack upside down.
12.Reinstall all screws and tighten.
13.Charge the new batteries for 8-14 hrs before the first use.
I hope this helps and good luck!
Feb 24, 2010 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Do you need to have batteries on charge everynight even if you have not used the scooter as ive been told that with the travelite you do i borrowed one in process of buying it from friend
If you use the scooter then charge it. You need to charge the scooter at least once a week even if you don't use it. More importantly is that you charge the scooter for at least 8 hours at a time. If you charge it less then it will start killing the batteries.
Oct 28, 2009 | Haba Drive Mini Phantom Three Wheel...
Battery pack
call me I have a store, Independent Mobility in Wilkes-Barre: 825-1277. batteries in stock
Feb 08, 2009 | Zoom 220 HMV 3-Wheel Travel Scooter
Drive Medical Mini Phantom Three Wheel Compact Scooter Blue - 1 each Logo
281 people viewed this question
Top Drive Medical Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Robin Hill
Robin Hill
Are you a Drive Medical Health and Beauty Expert? Answer questions, earn points and help others
