Question about Tilia FoodSaver V2240
Need schematic or shop manual
My dad wants to fix his Foodsaver V825.He loves his hobby and he's extremely good at it BUT he doesn't know how to get ahold of the schematic or shop manual. Can you help??
Anna
3 Suggested Answers
  • 300 Answers
SOURCE: I am on my 2nd
Hi!
"I do not want to buy a new FoodSaver every year or so, because of a simple gasket problem!"
I have one just like that, but I don't use it much. The few times I used it, it worked OK.
Reading about your problem, I checked mine and noticed the gasket is just high density styrofoam. Sadly, this type of material degrades with use, moisture and mostly oil.
Then I Googled for some information and found some chatboards where it is said that this particular model does have a history of poor gaskets.
I suppose if you are using the FoodSealer a lot, it may be a good idea to upgrade to something more suitable. It will be more expensive but it will likely last you a long time.
I wish I could be more ... more encouraging and helpful.
Posted on Feb 14, 2011
I replace my gasket with a piece of 3/8" Poly Foam Caulk Saver (found mine at Home Depot - @$2.00 for 20'). It's a snug fit in the gasket groove. Cut long enough so that the ends touch tightly. It will create a good air seal and works well.
Posted on Dec 28, 2012
How to remove engine from 03 mdx. engine 3.5
Go to helm.com and buy a 'real' shop manual. You will need it and it's extremely helpful, especially with the MDX's.
yes it's a little spendy (around $100+) but you will value it immediately. I love mine!
While you're at it, buy a good code scanner with enhanced capabilities. Very helpful, especially on these cars.
May 05, 2016 | Acura MDX Cars & Trucks
Free 966 international tractor wiring diagram
I don't know where there's a schematic on the web, however, the schematic is in this shop manual:
SMIH203 International Harvester Farmall Shop Manual
Good luck
Nov 03, 2014 | Toys
Foodsaver tilia v3240 manual
There does not seem to be a manual specific to this model. There is an extensive description of the product available on Amazon.com including a demo video.
See here:
http://www.amazon.com/FoodSaver-V3240-Vertical-Vacuum-Sealer/dp/B003U738ZE
You may also find one of the manuals from the 3000 series to be helpful. These and FAQs are available here:
http://www.foodsaver.com/manuals.aspx?cid=1177
Trust this is helpful.
Apr 16, 2012 | Tilia FoodSaver V3240 verticle vacuum food...
I am on my 2nd foodsaver. My 1st one stopped working, which I later found out, was probably due to the bottom gasket. My 2nd one had the same problem. I called FoodSaver, and they suggested that I flip...
Feb 14, 2011 | Tilia FoodSaver VAC420
I need a owner's manual foodsaver compact fc-no-202412 i dont no how lang to l hold it down to seal the bag.model foodsaver compact .f.l.a.e.m.nuova.s.r.l
Well you many please follow the below link to get your manual -
http://www.foodsaver.com/manuals/FoodSaver/T000-32030_English.pdf
Check out page number 4 on this manual to know the time to seal the bag.
Good Luck!!
Thanks for using FixYa!!
Aug 28, 2010 | Tilia FoodSaver V2240
Kew hobby 80-1 instructions
I have a kew hobby 70 with little use. The nozzle wont spray, it just sends a weak jet of water. how can i fix it? I have hardly used it. It has been
in a shed for years . thanks
Sep 29, 2009 | Garden
Lost manual for K. E. W. HOBBY 88 pressure washer
Hi, Do you use the unit now. My unit of th same vintage has just failed and I would be interested in purchasing the same model slong as it works. Cliff Cason, Derbyshire DE6. Tel 01889 565574 mob 07711218929.
Sep 25, 2009 | Garden
Foodsaver Profesional II heat strip transformer burned out.
The transformer can be found at a good wholesale electronics store, it is 12 volt and will register slightly higher with ohm meter. You can also use a 220 to 24 volt transformer.
Dec 04, 2008 | Food Processors
Hyundai lantra sportswagon 2000 owners manual
Ebay is your best bet, might also try craigslist, etc.  I know for most cars you can also get a shop manual on Ebay that will include details on maintenance for most if not all of the car.
Oct 24, 2008 | 2000 Hyundai Elantra
Tilia FoodSaver V2240 Logo
187 people viewed this question
Top Tilia Kitchen Appliances - Others Experts
Lee Eismann
Mike Squire
Tim Doolittle
Tim Doolittle
Are you a Tilia Kitchen Appliances - Other Expert? Answer questions, earn points and help others
