I was attempting to disconnect a Webcam's USB cable and accidentally unplugged the wireless receiver..Once I realised I plugged it back in, but now it says there is no connection to the internet.I've tried restarting the router and I've also switched it on and off.
When you set up a dial-up Internet service connection on your Windows computer, it comes automatically configured to disconnect itself after a predetermined period of inactivity.
This means that if you walk away from your computer and forget that you're online, your internet connection will automatically shut itself down.
If this feature isn't as helpful as you assumed it would be, you can turn it off using the Network and Sharing Center.
Click "Start."
Click "Control Panel."
Click "Network and Sharing Center."
Click "Change Adapter Settings."
Right-click on your dial-up Internet service icon.
Click "Properties."
Clear the check box next to the "Auto Disconnect" listing on screen.
Click "Apply."
The auto disconnect on your computer Internet service connection is now turned off.
also if its running slow
Slow computers that persistently disconnect from Internet access may have issues with the wireless setup or if on a wired connection, there may be a problem with the Ethernet cable or port.
Troubleshooting connection and speed issues can save money rather than taking the computer to a technician or repair shop.
Additionally, some firewalls and security features can make it difficult to access certain types of websites.
Before spending money to have the computer diagnosed, try running through the most common, basic causes of connection issues.
Consider the type of site you are trying to access.
High-traffic sites such as gaming sites can sometimes be affected by high volumes of users accessing or attempting to access the site at once.
Test this by attempting to access the site at different times during the day and evening; peak hours for games that typically appeal to children may be during the afternoons on weekdays while games for older or more mature audiences will see high traffic at night.
Check your Internet connectivity and determine whether you are using a wired or wireless connection.
In the lower right side of the computer screen there should be an icon displaying the Internet or network connection.
Wireless connections are displayed with connection bars similar to those seen on cell phones while wired connections may show the end of a plug next to a monitor icon.
Reset the router if using a wireless connection.
For most home routers you simply unplug the power cord from the router box, wait a moment and plug it back in.
You may have to restart your computer to reestablish a secure connection.
Access the router through the computer and check for updates. Some routers offer firmware updates that fix some connectivity issues.
While updating the router, check for Internet browser updates as well as any critical updates for your computer's operating system.
Verify the computer uses the most up-to-date version of the Web browser available.
Try a different browser. Internet Explorer is the most commonly used Web browser, but not always the best for every site.
Try downloading another Web browser such as Firefox, Opera, or Google Chrome and test the sites there.
If the connections are still disconnected and the Internet speed seems slow, it may be an Internet issue.
Wired Connections
Trace the Ethernet cable from the Internet modem to the computer if using a wired connection.
Unplug the end of the Ethernet cable and check that the plastic head is secure and that there is a click when you return the plug to the modem; do the same on the computer end.
Inspect the Ethernet cable carefully as it runs from the modem to the computer.
If the cable was tacked down with a staple gun or other attachment, check the cable to verify it wasn't accidentally pierced.
Additionally, check for bends, twists or worn areas along the cable.
Measure the length of the Ethernet cable.
In general, cables longer than 100 feet tend to receive poorer signal transmission.
If the cable is longer than 100 feet, replacing with a higher quality cable or moving the computer or Internet modem may resolve connection issues.
Hope this helps.
f you are attempting to connect your Wii console online using a wireless router and you receive this error :
Ensure you are using a broadband or high speed internet connection such as cable, DSL, or fiber optics. Slower connections, such as dial up, may cause issues with the Wii or may not work properly.
Ensure there is no interfering devices by shutting off microwaves, cordless phones, wireless keyboards, and wireless mice.
Diable your firewall settings, as it may be causing a connection problem.
Try changing the channel of your wireless router to either channel 1 or channel 11 which can increase download speeds. Be sure to test both channels to see which works better or faster.
If you are using a Netgear wireless router, disable the SPI firewall setting which is usually found under the WAN Settings of your wireless router.
If you are attempting to connect your Wii console online using the Nintendo Wireless (Wi-Fi) USB Connector and you receive this error :
If your PC is using security features or programs such as a firewall, antivirus, or antispyware, check all settings of these security features or programs to allow a successful connection.
You may try adding the following programs to your firewall list of "Trusted" applications
Temporarily disable your router's firewall which may allow the Wii console to connect online to recieve a system update. After, you may turn your firewall back on.
I tried Solution #1 but nothing happened, when I tried to view available networks it said 'windows cannot configure this wireless connection.' and then saying that if i use another device for that connection to use that.
The connection between the computer and the Router is now working but it is still unable to connect to the internet.
