Works fine, but the freezer gets too cold, and the freezer door sweats.
SOURCE: Samsung french door fridge not working?
I had the same problem ("OF" on display and not working) and just found a fix and it worked (on SAMSUNG site).It was correctly stated that fridge is in "demo" mode. You need to push and hold POWER FREEZE and ENERGY SAVER buttons (not "Fridge button and the Power Cool buttons" as it was suggested above).
SOURCE: SAMSUNG RS20CCMS
Defrost by turning off for 48 hours and the unit will work ok (for a while)
Its a design fault common to many Samsung Side By Sides
SOURCE: removing doors from a samsung rsg 5 dumh american fridge freezer
doors are removable. wiring to the door is plug and socket
SOURCE: frigde wont get cold but freezer does.
I am an authorized Samsung service center, and I have dealt with this
ongoing design problem for years. The problem occurs when the unit
comes out of the defrost cycle, not all of the frost has been removed
by the defrost element and an ice bridge occurs at the top and bottom
evaporator coil. There are sensors that send readings back to the main
PCB during and after this cycle, They have to be replaced along with
adding heat transfer clips for better frost meltage and air
circulation.
Order the following parts through Samsung:: Fixer # DA61-03585A,
Plate # DA61-03502A, Thermal Bi-metal # DA47-10160H, Sensor #
DA32-00006W. Have these parts installed by a professional appliance
repair company.
I hope this will fix your dilemma, Ward Appliance Repair.
SOURCE: Samsung Fridge can't get temp down
it is probably the door switch. I just pulled the switch from a rb2055 and disassembled the switch. one of the contacts is broken.
If you unplug the fridge and plug it back in, the light should work. push in on the switch button with the door open. If the light does not go out, switch is bad.
pry the switch gently out with screwdriver, unplug it and get a replacement.
If you are watching this I can also probably tell you how to jerry-rig it to run while waiting for replacement swicth.
