Question about Whirlpool GD2SHGX Refrigerator
Kenmore ref. side by side, ice maker does not make ice. Model # 106.56534400
  • nailuj12 May 11, 2010
    Try this sitehttp://www.acmehowto.com/howto/appliance... for a into of how the ice maker works. If you have no water in the ice tray, then the ice maker may faulty and it may not be sending power to the water valve or the water valve might be stuck closed not allowing water to enter. Check to make sure the fill tube that lets water into the ice maker is not frozen with water. If it is, you may have a water valve with a slow leak that will need to be replaced.
  • 700 Answers
Check the temperature inside of the freezer and if its colder then 17 degrees then you have to thzaw out the line that dumps the water into the ice maker.
Posted on Mar 21, 2009
Water dispence slow
do you know if it is a whirlpool made model, 27ft french door, ice maker in ceiling, they had issues with a seal between ice compartment and ref side- leaks freezing air to water tank area, freezing tank. other wise if its not the filter -then water flow to unit. ck where it connects to ref, if good( should have steady stream with press. replace ref valve if bad look at your valve in wall or at sink.
Sep 14, 2012 | Kenmore Refrigerators
Small ice cubes
The water is not reaching the ice maker in a sufficient quantity. If you have a water filter, change it. Thank you.
Sep 17, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Ice Maker Not Working
Probably need a new ice maker, whirlpoolpartssurplus.com
Jun 23, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
ICE MAKER NOT WORKING
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Jan 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker will not make ice
Water fill tube above I/M is probably frozen up. Remove I/M and see. If so, use spray bottle to melt out ice. Unplug and replug in ref when done to reset ice level sensor or it still won't work. If no ice blockage then I/M is bad and needs replacing.
Nov 28, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore Refrigerator stopped dispensing water
Either your water tank in the fridge froze up, the waterline that goes up the freezer door from the bottom hinge froze, or the switch that your glass hits is damaged. Do you hear any humming or noises when you put your glass up to get water?
Oct 27, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
KENMORE REFRIGERATOR
Need a model # ... mostly likey better to just replace ice maker if that old.. 12-15 if same age as ref.
Sep 06, 2007 | Kenmore 73952 / 73954 / 73959 Top Freezer...
Ice maker not working
Did you try to disconnect the water filter and try if its working? Check the line if its twisted or something disrupt the water to go in and make sure you open the tap water valve to supply your Ref.
Aug 06, 2007 | Kenmore 52632 / 52634 / 52639 Side by Side...
Whirlpool GD2SHGX Refrigerator Logo
214 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
