Question about Sanyo DP19648 19 in. LCD TV
Picture not centered and not stable
My ctr rca tv is "out of focus", I mean runs down horizontaly. I can't see the bottom of the image and the top is lower then the top of the screen. Also is not stable. I don't know if I am explaining well... horizontal picture is not in focus
  • 71 Answers
This tv does not support v.hold button.
its time to change the tv
Posted on Mar 08, 2009
I have a panisonic pt-lb50ntu Projector. It will only focus the center of the image. When you adjust the focus to the bottom of the image the top and center are out of fucus. The same goes for focusing on...
Is the picture a perfect rectangle shape on the screen. If not then either adjust the angle of the screen, or use the keystone function on the menu to correct it.
Does it still not focus correctly after doing this
Nov 12, 2010 | Panasonic PT-LB50U Multimedia Projector
The TV picture is not focused.Is there a way to focus it?
Yes,remove the back of unit.you will see a red wire leading to the picture tube.Follow that wire down to the board.You will see 2 controls on the transformer.top one is focas,bottom one is screen.Turn focas control until picture is clear.
Oct 08, 2009 | RCA F19262 19" TV
RCA D52W23 breakdown in projection focus
First check capacitors cp150 2200uf 16v and cp114,cp120 220uf 35v If cp150 is puffed up on top it is bad , then there is a fuse FL231 on right side of flyback transfomer it will be the middle fuse if open you will lose convergence on picture .
Dec 30, 2008 | RCA D61W20 61" Rear Projection Television
Picture is warped. rca 52 inch model p52929
This is hte beginning of a convergence problem. If you can solder, try resoldering the pins on the convergence ICs. These are large black ICs attached to a heat sink and will be marked STKxxx. If that fails to resolve the problem, replace the ICs.
Keep us posted.
Dan
Aug 25, 2008 | RCA P52929 52" Rear Projection Television
RCA Projection TV model #p61926
The convergence circuit is your problem and most times with this model the convergence power supply bd. is the problem.
Feb 11, 2008 | RCA P46921 46" Rear Projection Television
Running screen
go to menu then horizotel set it so it wont have lines
Feb 07, 2008 | Televison & Video
I suggest you take your TV to a repairman. The TV will need to be opened up and some adjustments made to the board.
Nov 26, 2007 | RCA F27242GY 27" TV
get an estimate to fix your convergence problem
Oct 08, 2007 | RCA P52937 52" Rear Projection Television
RCA 32V420T 32" TV
This RCA set uses the CTC187BD chassis. Look on the back of the set and to the right of the cable connector you will see 2 controls sticking out, one on top of the other. The top control is for focus and the bottom one is screen, or overall brightness. If these controls have been turned clockwise then you will have a bright, fuzzy picture with white lines (retrace lines) through it. Tune in a channel with white letters on the screen and turn the top (focus) control until the letters are crisp and sharp. Go into the menu and turn the contrast and brightness all the way down, and then turn the bottom control (screen) until you can just see the picture, just above the point where the picture is too dark to see. Go back into the menu and reset the contrast and brightness and the picture will be back to perfect.
Jun 28, 2007 | RCA 32V420T 32" TV
Sanyo DP19648 19 in. LCD TV Logo
94 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
