Question about Sony DAV-S400 System
Power protector on sony surround sound system
The power protector is popping up on my sony surround system-there is no button on the remote for it-where is it located?
  • Anonymous Mar 23, 2009
    No help for you I'm afraid, but for what it is worth I have exactly the same problem with my DAV S400. It means I can't play CD's at all - even on a volume setting of of 3 or 4 !! DVD's play and sound fine though - but seeing the reply to your own enquiry I'm going to buy a new non-Sony set-up, and start again.
  • Anonymous Mar 16, 2014
    My Sony surround sound system won't switch from vedio to sat
  • 10,594 Answers
Power protect is an error message that some thing is wrong in your sound system and requires qualified tech.
Normally that error message appears when unit got problem in amplifier output section, either it is speaker problem or some output chip is fried.
Posted on Feb 25, 2009
Thow do i get my sony dvd surround system to play it says push power protecter but i cant find it on the remote
power protector should be a button near the rear where the AC cord connects through the casing
Apr 07, 2011 | Sony DAV-HDX500 System
Does this model have Bravia sync?
Yes it does per SONY web site:
http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId=10151&productId=8198552921665164630&langId=-1#specifications
BRAVIA® Theatre Sync™ technology
Sony® created BRAVIA® Theatre Sync™ to go beyond basic digital audio and video transmission. Based on the HDMI-CEC function, BRAVIA® Theatre Sync™ will be included on select BRAVIA® Theatre home A/V systems and components. This useful function reduces the hassle and time consuming job of powering up, routing signals, etc. to the simple push of one button.8 Want to play your DVD on your Sony® A/V system? Easy, just push PLAY on the BRAVIA® HDTV remote and everything is taken care of for you. Even when the system is off! Want to change from TV sound to digital surround sound through your Sony BRAVIA® Theatre A/V system? Just one push of the Theater Sound button on the remote and voila, surround sound through your system. Want to power down everything once you've finished enjoying it? Push one button and the TV and A/V system powers down. BRAVIA® Theatre Sync™ helps make things a whole lot easier to operate.
Feb 02, 2011 | Sony BRAVIA KDL-40V3000 Television
Screen will go blank with no audio. It won't shut off with either the remote nor physically pushing button on TV. Only way to get it to turn of is unplug it.
This is a power supply problem, meaning either the power board has a fault or is detecting a fault from another circuit and shutting down. It shuts its self down to prevent further damage too the TV and prevent an electrical fire hazard. I know its probably something you don't want to know.....LOL but have a professional technician service the TV or take it back if its still under warranty.
http://tvtechwork.webs.com/
Nov 10, 2010 | Sony KDL40EX400 40 in. HD-Ready TV
5.1 Surround sound not working
Maybe the surround processor is having a bad day... My kenwood would do similar and a reset was necessary to correct. Have you tried resetting the system? On my Sony STR DE 597 this is accomplished by powering off. Then while holding the 2 channel button down (front face plate) power on. A reset message is displayed. Your model may be similar but check your manual or download the PDF of the manual from Sony's support website. Hope this helps
Sep 05, 2009 | Sony STR-DE685 Receiver
How do i connect to sky hd and sony kdl 40w 4710 and dav-is10 i have hdmi from skyhd to tv and hdmi from home cinema to tv what else is required as i cant get surround sound from tv
you need a Optical audio cable, run this from the back of your Sky HD box to the Surround sound. Not all Broadcast are transmitted in DD so press your i button on the sky remote and you will see this on the yellow bar above the program information if it is..
Might be worth running a set of White and Red audio cable from the HD box to the Surround sound as well that way you can just mute your telly and have the lot coming through the surround sound system.
Hope this clears things up for you
Little Dish Fitter
Jun 05, 2009 | Sony DAV-IS10 System
Surround sound to work with sky+
hi yes it is....
wot u need to do is.....our red and white audio leads go from sky box to dvd box...we then put our dvd player onto video 1 using function button on remote
hope this helps
Feb 20, 2009 | Sony DAV-S300 System
Need Dish Network Code for Sony DAVHDX275 Audio System
Refer to page 82 in your Dish Network User's Guide......(Make sure Sony system is powered on and in DVD mode with a disc in the player).  Point Dish remote at Sony box -  Hold Aux until all buttons light up at top....press 2 - then STAR button* and then POWER button - then press the up arrow key repeatedly until Sony turns off - press # key to lock in code.
It took me awhile to get it to work....it will only work power, mute, and volume - not dvd play functions. Refer to page 85 to make the Dish remote control the Sony box volume by default.
Good luck.
Jan 25, 2009 | Sony BRAVIA DAV-HDX267W Theater System...
TV Zoom mode
Change the batteries on the remote, point the remote at the Sony, and hold in the power button for 5-7 seconds. Then depress and re-press the power button - see if you can get the tv remote to respond again.
Then, always try the quick reset:
How to perform a power reset on a Sony® television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
May 16, 2008 | Sony KV-32FS13 TV
Sony DAV-S400 System Logo
838 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
