Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
I have a Coleman furnace model number 7681-8171/b. Most everything has been replaced on this unit from the circuit board to the flame censor including the firebox which was on the recall list. The unit will sometimes work correctly but in the mornings the house temp. will only be about 60 degrees even though the Thermostat is set on 70 degrees. The flame sometimes holds and it works well but other times the flame comes on then kicks off shortly afterwards. This furnace has been nothing but problems since almost day one.
  • 462 Answers
Short of being able to look at everything Its impossible to say exactly what the trouble is. Does the board have a blink code showing and a legend that says what this is? What fuel are you on NG or LP? What does the flame look like (if you can see it) IE a lot of yellow, Some orange and Blue...?. Did anyone else look at the system and the thermostat? Does it have AC or HP on it too?
The only 1 thing I may be able to offer is this. On your thermostat (if it is not electronic) there is a needle pointer that points to a number it should be around .4 to .7 if set to a lower number the thermostat will cut the unit off well before it completes a heat cycle.
Posted on Mar 11, 2009
Coleman mach furnace wont stay running. i turn the thermostat down until i hear it click, then i turn it back up to get the furnace to kick sometimes and sometimes not. blower will always kick on...
Hi, I don't know if you are still having a problem, but it sound like the flame sensor on the unit is dirty and need to be cleaned. If it has a automatic pilot, it will have a flame sensor. Its made of porcelin with a metal rod coming out the end, laying next to the pilot flame. Just 1 screw holds it in place. Remove it and clean the tip with steel wool or a piece of sanding cloth. If you don't have this set up, I would need more info on the unit, model and serial number. You may also have a faulty thermostat, but I do believe it is a flame sensor.
Nov 21, 2011 | Coleman Mach III Air Conditioner
I have a Coleman model # FC32A3XN1A. The code is flashing 10 = Gas flow with no call for heat. There is also water in the bottom of the furnace below the circuit board. I also hear what sounds like water...
Turn everything off your coil is frozen over and destroying the furnace. The furnace has water on the flame sensor and it thinks the gas is on but it isnt. The water is grounding out the flame sensor. If there is no water damage to the circuit board all you have to do is dry your flame sensor off and you should be fine. Now for the frozen coil you have a freon leak most likely or an air flow issue but you have to thaw the coil out completely before you can find out the problem. Check your air filter is it clean make sure your blower inside the furnace is rotating. If all these things check out ok you have to get the A/C charged with freon you have a leak. If this help please rate me and do a testimonial.
May 23, 2011 | Heating & Cooling
I have a coleman furnace it comes on the electric igniter glows red the gas comes on then the blower starts and the fire goes out it gives 2 different code for this 1 is ignition failure and the other is...
I would have the ignition control board replaced. That is what tells the gas valve to come on and if there is flame or ignition it will keep the gas on if the flame sensor gives the board a signal that the burner is lite. By you shuting power off and on to the furnace it resets the board and it will go through its cycle again.
Feb 10, 2011 | Coleman Heating & Cooling
Gas furnace; flame will not stay on
Clean the flame sensor with a green scotch brite pad. Check all ground connections from the circuit board to the furnace cabinet. Check for a proper ground to the electrical box. Make sure polarity has not been reversed.
Dec 26, 2009 | Coleman Heating & Cooling
Coleman evcon dgat090bdd. New ignitor won't heat up.
Looks like 4 flashes might be high limit fault on this furnace. (I don't have a manual for this furnace, just searched online for the code meaning) Is the unit running flame at all? Is the unit running flame for a while then shutting flame off before desired temp is reached? Does the main air fan turn on to circulate air through your diffusers? Does it feel like the unit has much air flow out of the diffusers if the fan is running? Is your air filter clean? If it is infact your high limit switch, it is usually caused by not having enough airflow through the furnace and overheating occurs.
Hope this helped, let me know if I can assist you further :)
Jan 16, 2009 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
524 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
