Question about Xerox Phaser 8200 Laser Printer
Error code 15.004.45.172027 on Phaser 8200
Need bulb replacement instruction
  • 23 Answers
I would suggest calling a service agent and have him bring a paper pre heater.
Posted on Feb 27, 2009
Phaser 8200 error code
I think I had this error once. Could be your bulbs (one or both) are out or are on their way out. I had to replace mine. They are 150 watt halogen bulbs. When you open it up, do you see lights on the side peering in?
Jul 02, 2009 | Xerox Phaser 8200 Laser Printer
Xerox 8200 printer error 15.004.45. How do I
If this is your first rodeo, contact www.inktechnologies.com. They can walk you through it and provide the parts.
Jun 28, 2009 | Xerox Phaser 8200 Laser Printer
Phaser 8200 Error 15,004.45:102501
Yes, that is a common problem, and not real hard to fix, but takes probably an hour to an hour and a half to repair. For someone that has never done it before that is.
First what the code means. That is a failure of the drum to heat up. The drum heaters are simply 2,, 150 watt Halogen lamps, mounted in a reflective heater. One or both of those bulbs has burned out.
The way you can tell is, turn the lights off in the room or office the machine is located. Then. looking on the right side cover, there are fan vents, opening up into the machine. Turn the machine on, and wait a minute or two, then look in that fan slot and see if you see a glowing in the machine. You won't. But that is how you know those lamps are not coming on.
You will want to replace both bulbs since you are taking that assembly out. I strongly suggest the Sylvania Halogens that are rated for 130 volts and are vibration protected. You can get them at Lowes or Home Depot, anywhere that sells Halogen lamps. You dont have to get the Sylvania ones, but they sure are the best if you can get them. The cost to fix it yourself is less than $20.
If you want, E-mail me at rak458@aol.com and I will send you the instructions on the repair. I dont have the manual. I will type it out step by step. Makes it easier I think.
May 19, 2009 | Xerox Phaser 8200 Laser Printer
Phaser 8200 error code 15,004.45:119696
If you take your time, Its not really hard, Just time consuming. I can send you written instructions.
May 17, 2009 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8200 Error Code 15004.45:18370
unless you know how to service preheater/drum heater then you have no choice but to ask the qualified person to do it for you....
YOu can read more details baout the failure at below link..
http://etech.maiila.com/xerox-phaser-8200-drivers-software-manual-and-troubleshooting
Apr 22, 2009 | Xerox Phaser 8200 Laser Printer
Error 15 004 45 37888
From the service manual:
15,004.45:
TCD_THERMISTOR_
SLOW
Most likely cause is a failed drum heater. The head to drum gap
should only be checked or adjusted on the Phaser 840. The
Phaser 850, 860, and 8200 have a pre-adjusted head.
In other words, you need to replace the drum heater.
Thanks and please take a moment to rate as fixya.
Mar 13, 2009 | Xerox Phaser 8200 Laser Printer
Phaser 8200 15,004.45:50425 error
There are 2 150 watt halogen lamps that heat the drum that are blown out. Thats your problem. If you want to try to replace them let me know.
Feb 23, 2009 | Xerox Phaser 8200 Laser Printer
Error phaser 8200
This error message is related to the drum heater malfunctioning. It is basically 4 small halogen bulbs that warm up the image drum. Sometimes one or two of the bulbs will blow causing this error. The part # is 650-4228-00 Drum/Paper Heater assy. It is not extremely difficult to change, however you need torx bit screwdrivers to remove the components, also there is a very delicate paper sensor that needs to be removed, so you may want to have a technician replace it.
Hope this helps!
May 20, 2008 | Xerox 8200/DP Thermal Printer
Xerox Phaser 8200 Laser Printer Logo
78 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
