Question about Packard Bell (181379) Motherboard
I have a Tiny n19/Green900 17" laptop with a screen problem From top to bottom just left of centre there is a second 2.5" block of information with ghosting from a previous page(the up/down scan lines in the block appear to be alternate i.e.twice the width) ,the main screen has all the correct colour and informaton,and there is no problem with an external monitor. Can any one suggest where this extra information may be coming from.
If the external monitor is clear and the laptop isn't, then that tells you that there is a problem with the laptop hardware itself, particularly it could be your laptop screen inverter is failing or is getting loose. Try opening it up at a dealer or repair center and have them check or if you're qualified to do it yourself, you can but I think it most likely has to do with your screen's inverter.
Have you also checked your video drivers?
Posted on Jan 05, 2010
I have tiny n 19 laptop. the video card is gone,i looking for the video card. please help me!
Posted on Dec 29, 2009
Set time on TIMEX 1441 sports watch
To set your watch:
1. Press the top left button while the screen shows the time. The seconds should begin to flash on the screen. 2. Press the bottom left button to switch between seconds, minutes, etc. 3. To increase a number press the bottom right button 4. Press the top left button to stop changing/confirm the time you have set.
This is the general way to set most watches
Mar 30, 2011 | Timex Watches
How can I switch my Garmin Nuvi back to English Language
Hi, I own a nuvi as well and the menu structure is as follows
the icons as follows and their location on the screens
1) spanner - bottom right of screen
2) spanner - top left of screen
3) mouth - bottom centre of screen
4) box on top right of screen
Mar 19, 2010 | Garmin nuvi 1300 Car GPS Receiver
Blocks puzzle # 57 in Nintendo DS 50 Classic Games impossible?
  1. Top Icon right (3 moves)
  2. Left Icon left (1 move)
  3. Sedond Left Icon left (1 move) clears 2 Icons
  4. Left Icon right (1 move) clears 3 Icons
  5. Top Left Icon left (2 moves) ends up on bottom
  6. Middle row Second Icon left (2 moves)
  7. Middle row Third Icon left (2 moves) clears 2 Icons
  8. Middle row Second Icon right (1 move) ends up on bottom
  9. Middle row Right Icon left (4 moves) clears 3 Icons
  10. Top Icon left (1 move) clears 2 Icons
  11. The Rest Is EASY!! (2 moves) clears 4 Icons
Jan 24, 2010 | Nintendo DS Lite
I have tiny n19 wireless has stopped working says turn on switch i cannot find it any ideas
ensure your button lock is not set to on. usually to switch on you have to hold one if the buttons in for a few seconds and then it should start try each button in turn.
to switch off it is the same just hold the button until it goes off.
Nov 17, 2009 | Computers & Internet
Bottom of the screen displaying top of screen.
well the problem is in your graphic card!
then buy ney one for your laptop...
BUT i'm not sure about your problem about screen or video card.
Aug 27, 2009 | Dell Latitude E5400 Notebook
Puzzles 130 Too Many Queens 5 --- 132 Princess's Escape
puzzle 130:Assuming on a chess board 8x8 that each square is numbered 1-64 top left to right.Place a queen on each of these squares 3,13,18,32,33,47,52 and 62 bobs yer uncle
Mar 09, 2009 | Nintendo Professor Layton & the Curious...
Dishwasher Problem...
You are right. The plastic screw needs to be removed. I have a Quiet Guard 4. My procedure is as follows:
1. Remove baskets. Need to pop off the 'keepers' at the ends of the top slidding shelf supports.
2. Remove bottom washing arm. Unscrew (Gently but firmly) the centre post. Lift arm assembly out.
3. Remove overhead conduit. One screw at back, one at top.= (Philips #2 bit). Rotate whole assembly 45 deg right (Clockwise) and lift off of centre post.
4. Remove centre post (Pull straight up). Remove 4 screws (Star T-20 bit). Lift the whole plastic assembly out. Pop off the screen and clean,
5. Remove cap over cutter/chopper. There is one screw at the left front (Star T-15 bit). Remove screw and cap (Needs some wiggling to free it up). Remove cutter and filter (this is the water blocking problem). It is on a spring loaded pin. Pull the cutter blade foreward and lift the filter disc straight up. Clean thoroughly. I ran a 'quick rinse' cycle with everything out to chean the inside.
Hope there is enough of a similarity to be helpful.
Dec 08, 2008 | Dishwashers
Cect p168 change language accidently changed the language cant get it back
  1. Click the "Home" icon on the bottom of your touch screen, which is the first icon from the left (the tiny picture that looks like a house).
  2. On the left-hand side, click the fourth icon from the top, second from bottom (the one that looks like a picture of internal clockwork). This will be "System".
  3. Click the first icon, also a picture of internal clockwork. This will be "Settings".
  4. Click the second option from the top. This will be "Phone Setup".
  5. Click the third option from the top. This will be "Language". Select the very first option, in this case, will be "English".
Oct 03, 2008 | Cell Phones
The screen of my laptop comes up with squares and small circles on reboot
Normally I would say this was a driver issue, however ,since you reformatted and reloaded your op system and it still does the same, I'm going to say it's either the inverter or the screen. Check the connections to make sure they haven't worked loose.
Jun 21, 2008 | Packard Bell (181379) Motherboard
Replace Screen on HP6515
Ok, to disassemble - remove four screws on back (#7 torx required). Then remove battery cover, battery, and SIMM card. Next peel the (on mine lower left portion of the) Warranty Void if removed sticker, and using a tiny phillips head screw driver, remove the screw revealed. Next, slide a thumbnail or plastic flatbldae screw drriver around the seam on the sides of the unit, to release the two pressure tabs on the sides and top. Then pull the top away, eventually freeing the bottom. Now, there is a system board exposed. There are three screws (tiny phillips again) two on the bottom and one at the top that can be removed, allowing the system board to be removed. Note that there are two ribbon connectors on one side - I didn't remove these. There's also a small plastic connection I did remove, then the system board will remove to the side allowing access to the back of the screen and keyboard assemblies.
Aug 23, 2007 | HP iPAQ hw6515 Pocket PC
Packard Bell (181379) Motherboard Logo
419 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
