Question about HP OmniBook XE3 Notebook
My screen is flashing
My screen on a hp omnibookxe3 is flashing on and and it dims the cord is connected it does the same thing i thought is battary but is not can some help me
  • 54 Answers
Ok if it is connected with ac power means u can get bright image but still if ur not getting means then press fn one key will there along with that press up arrow key
Posted on Feb 25, 2009
Monitor Flashes Then Goes Very Dim
Check and replace the inflated capacitors on the power/invertor board. The generated 12 volts are unstable and protection cirquit turns the invertors off to avoid damage to the IC
May 16, 2015 | HP 2311x 23-Inch LED Monitor - Black
When computer using battery power, screen dims. Prior to today, when power cord was hooked to computer, screen would brighten noticably but now stays at the same level of brightness as if only on battery...
Just a few things to check which I guess you have tried.
Is the system running on battery or charger > maybe charger problem.
Have you tried to manually brighten the screen? Think that is Fn + F7 or F8
If you have tried these already, possible backlight in LCD issue.
Aug 12, 2010 | HP Pavilion dv2718us Notebook
The monitor wont work
plug back to vga and setup multy screan c
Jun 25, 2010 | Sceptre X9G-NagaIV 19" LCD Monitor
Hp 9000dv laptop was dropped, screen is now very very dim
hi
which monitor u have
let me then only i can help u
May 25, 2010 | HP Pavilion dv9000t Notebook
When the power button is pressed the light flashes for a few seconds and the system stops and not working. but the charge light in the side is glowing and not in the front side
Light flashes cause battery is critical low.
Try to unplug and then plug in cord again, until front lamp lites on.
If you continue to have this problem, post and I will explain how I solved mine.
Well I had problem that sometimes after plug in or out, battery goes from 100% to 3%, I thought it was battery or adapter, but it was software. I did ask HP about it, they said they had customers with such problem.
You might have same problem.
Nov 16, 2009 | HP Pavilion Dv3-1075us Notebook
Gateway screen flashes bright and dim
Usually the connection is one wire down the middle and their is another wire wrapped around it.
You can try to do a soldering job with heat shrink material around it, but if you don't know the procedure, it can damage the laptop.
Look at the charger and the amperage it needs as well as the voltage. You can actually just buy a new one as little as 80 dollars.
Aug 09, 2009 | Acer Aspire 5500 5570-2609 Laptop
Cant get in.
to remove the bios code take out the small watch size battery on the mother for like 2 minutes it will reset the the bios password
Dec 08, 2008 | HP OmniBook XE3 Notebook
Acer Aspire 5600 wont turn on.
Ther is only one thing that you have not tried I think. Try to remove the CMOS battery from the motherboard for about 15 minutes and reconnect it. It's a small lithium battery.
Nov 25, 2008 | E-Machines T1360 PC Desktop
Dim screen
A New Backlight, or new bulbs for your backlight..
Jun 09, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Backlight Issue
Sounds like a hardware problem.
Sep 11, 2005 | HP iPAQ HX4700 Pocket PC
HP OmniBook XE3 Notebook Logo
55 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
