Question about Hoover V2 U8130-900 WindTunnel Bagless Upright Vacuum
Broken vac i stepped on the release and it broke
  • 294 Answers
The pedal release lever should be available through a Hoover dealer at a minimal cost.
Posted on Mar 01, 2009
Tip
I have a Bissell Total Floor vacuum. The handle release pedal broke so now the...
If your Bissell upright vacuum cleaner is not cleaning like it did when it was new, then you need to provide a bit of maintenance or service. I will tell you how you can do this maintenance to your Bissell vacuum.
First, make sure that your floor vacuum is unplugged. Then you can work safely on your Bissell bagless vacuum.
If your Bissell upright vacuum is losing suction, then the next thing to check is the canister. It is very easy to simply forget to dump the canister.
The while you have the canister out, check the filter inside the canister to make sure that it is not plugged full of dirt. This filter can be difficult to access, but a little persistence will pay off. When you get the bottom of the cup open and remove the filter, use a bit of soapy water to wash out the filter. You can then reassemble the filter into the bottom of the canister.
On the left side of the vacuum there is also a HEPA filter Bissell has there to help filter the air even more. Remove that, clean it also and replace it.
The hose is the next thing to check. You can completely detach the hose from the vacuum. Check the hole at the bottom where the hose hooks up to make sure the hole is not plugged. Then stretch out the hose and run something like a coat hanger through it to make sure that there are no obstructions inside the hose. You should be able to hold the hose up to a light and see right through it.
The last thing to check is your Bissell vacuum belt. If the belt is too loose it will slip and not spin the brush properly. Bissell belts can be purchased online easily, or in many grocery stores. If your Bissell upright cleaner has a slipping belt, it may also be because of strings, carpet pieces, etc… getting wrapped around the brush. Remove the vacuum brush and cut off everything that is wrapped around it. Always be careful of the vacuum belt after you have just used your vacuum. The belt will be very hot just after use.
These steps will help you to get your Bissell upright vacuum cleaner working like new again.
on Nov 08, 2010 | Vacuums
How to release the handle on a big upright Dyson
On most older models there is a footpedal to release the handle. Some you put your foot on the front of the nozzle housing and pull back on the handle. On newer models you just pull back on the handle.
Jun 21, 2017 | Dyson Vacuums
I broke the Air flow adjusting knob and can not get air to release on my Musting 255 can you help.
replace them you can get them from guarantee vacuum and sewing center
Mar 17, 2014 | Vacuums
Handle release has stuck down and want release handle
http://canada.bissell.com/FAQs_and_Answers.aspx go to web and see all information, video, troubleshooting, questions, and fix it.
God bless you
Sep 22, 2012 | Vacuums
Stand up lever is plastic, broke when stepped on to release handle, can it be repaired, replaced with a better one, plastic breaks too easily?
The pedal release can be replaced but the base will need to be checked for cracks as well. if the base is broken most common is the socket the pedal release snaps into. some of the plastic parts have been made with better materials
Oct 20, 2009 | Hoover Ultra U6430-900 WindTunnel Bagged...
Canister will not release
I've done that.
There is a stem that runs down the center of the cyclone that releases the bottom. You didn't get that stem back in place. The only thing you can do is pry it open, hope is doesn't break, and put that cyclone back together correctly.
I've never broke one, but I had to pull pretty hard. Thought I was going to.
Good Luck
Nov 24, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Replace release button on kirby 3
I assume you are talking about the release on the handle pivot. Unhook the bag so it is out of the way, take the hanle off, take the top cover off, then there 2 screws holding the handle oivot asm, take them out, replace witht he new one, making sure that the the piece that hangs down meshes with the transmission. Then reasmble.
Oct 02, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Hoover V2 U8130-900 WindTunnel Bagless Upright Vacuum Logo
76 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
