Question about Zenith C27A24T 27" TV
Locating the input
I finally found a way for me to access the video option from the menu button (remote and front of tv). Select source menu and if you have the main source as anything other than video - select the black button on the right to find the video option.This set of arrows are towards the bottom of the remote between menu and quit. Select video and you will be good to go.
Note: This is how my tv/pip/remote is set up. I do not know if it will work for you but it is worth trying. I'm finally happy. Nobody could figure it out so i want to share it with you. Happy Playing to you! :)
    Scholar:
  • 85 Answers
Thank you very much for that information.but you yourself tried this information before confirming. thanks for that information.
Posted on Feb 25, 2009
How do I get to my HDMI channel?
It isn't a 'channel' it is a connection port. Once a cable box or DVD / blue Ray player is plugged into it, you choose the port using the Input button on your remote and scroll through them.
That set has 2 HDMI connectors on the back panel, right side, more or less by themselves, to the lower left of the antenna jack.
See the link. In the cluster of 3 photos, click the center one, then zoom it. Source(s): http://www.crutchfield.com/S-QWOJIeQP36Y... kg7or · 4 years ago
All the info on the television including manuals and inputs can be found here,
ftp://ftp.panasonic.com/television/howto/combo_connections_howto.html
58 Class 58 0 Diagonal 1080p Plasma HDTV with Anti Reflection
Jan 01, 2016 | Panasonic Televison & Video
How do I use the video source button? I can see the different video inputs I can select on the screen after hitting the button but I can't move the cursor to select a different video source an
On Most TVs I have messed with, Hit the input or source button muliple times to cycle throught the different inputs. Also make sure there is an active device on the input for the TV to recognize it. Good luck
Jan 03, 2015 | Televison & Video
Accessing input (source) codes on Sylvania TV
NO. As there is no Menu button on the front panel of this tV, you must have a remote control to do input selections.
Jun 08, 2012 | Sylvania Televison & Video
Which button on the remote control is for switching from TV to AV (VCR)?
The TV/Video button on the original remote for the KDL-26S2000 should let you cycle through the inputs on the TV. This button is at the upper left of the remote. (However, if you have set the system to Skip inputs, you may need to remove the skip option.)
There is also a TV/Video button on the front of the TV. It's the second button from the left on the panel (it's just to the right of the menu button).
To reset the input list, press Menu and navigate to Settings. Select the Setup sub-menu and then select the Label Video Inputs. Give the input any label other than skip.
Some TVs work best if the TV is turned on and set to that input source before you turn on the source device.
For additional information and pictures of the menus, see the manual. It is available from Sony support: http://esupport.sony.com/US/perl/model-home.pl?mdl=KDL26S2000&template_id=1&region_id=1&tab=manuals#/manualsTab (see the Manuals, Specs and Warranty tab). The direct link to the manual is http://www.docs.sony.com/release/KDL40S2000.pdf .
I hope this helps.
Dec 31, 2011 | Sony BRAVIA KDL-26S2000 26 in. LCD HDTV
Can not figure out how to use the video output on the tv, we dont have a remote for it and there is no video button on the tv, just wondering how we can get the tv to show the video output
Press the "menu" button on the front (near the middle of the panel) then look through the menu for the input or source or tv/av selection.
Select that option and then select which source you want to display. Done! :D
Hope this helps, and here is the DL link for the user manual if you need it:
http://www.funai-corp.com/6pdf/om/EWF2004.pdf
Nov 23, 2010 | Emerson EWF2004 20" TV
Input select sttting
Normally, your TV or VCR is probably set to display the television channels you watch, through a standard cable input. In order to play your Nintendo using the A/V cables, we need to tell your TV or VCR to switch from the normal tv channels, and instead display the signal coming in from the A/V cables of your Nintendo system. There is no one particular way to do this, as it varies between brands, but below is some information that may help.
Quick Tip: Grab the original remote control for the TV or VCR you have plugged your Nintendo into, and look for a button that could be labeled:
  • TV/Video
  • Input Select
  • Line or Line In
  • Source
  • AUX (auxiliary)
  • EXT (external)
  • any other button that seems to indicate it would switch between the TV signal and the game system.
If the above tips did not help, it is possible your Input Select is a little more difficult to locate. Here are some other common ways to access an Input Select:
  • A button on the front of your TV or VCR located behind a door or a hidden panel, or located on the original remote control that came with the device. If you are using a universal remote, it may not work when pressing the "input select" button. If it does not work, try to locate the original remote.
  • A high or low end channel. Try channel surfing through every channel, even the ones that do not normally broadcast a TV show. Many times the input select is a high channel such as 90, 91, 92, 93, 99, or even 999. You should also try low channels such as 0, 00,001, 1 or even 2. For some televisions, you may need to manually select these channels by using the keypad on the TV or remote control.
  • Found within an on-screen menu. Search the menu for words such as Input, Setup or Source. Select one of these words, and another menu will usually appear that asks you to select between TV and either AV, AUX or Line. Select AV, AUX or Line to display the Nintendo game.
If you are still unable to find your input select, you may want to consult the operation manual that came with your TV or VCR, or contact the manufacturer directly.
Nov 19, 2009 | Nintendo Wii Console
I signed on last night, asked a couple of questions, but the info sent to my e-mail didn't have anything to do with the questions I asked. Noticing in the forum, several people has the same problem:...
Howdy Mike-d. here, mikedee4@gmail.com
Hi CindyCee,
I have tried to post solutions, but they seem to be too long, so I will have to post more than once to get the info to you.
First part- the "Line-In" Video Source thing many people are having fun with. Try these options from the Samsung FAQs website.:
How Do You Switch Video Sources? spacer.gif Depending on the model TV you have, there are up to four ways to change the video source:
  • Through the on-screen menu controlled by your remote
  • Through the on-screen menu accessed through the Menu button on your TV's front panel
  • Through the TV/Video, TV/Component, or Source button on your remote
  • Through the TV/Video or Source button on the front panel of your TV
Your TV could provide any combination of these methods. Instructions for all the methods are below
Changing the Source Using the On-Screen Menu Controlled By Your Remote To use the on-screen menu of your TV controlled by your remote to change video sources, follow these steps:
  1. Turn on your TV.
  2. Press the Menu button on your remote. The Main Menu appears.
  3. Select Input, and then press the Enter button. The Input menu appears.
  4. Select Source List, and then press the Enter button.
  5. Press the Up or Down arrow button on your remote to select the signal source, and then press the Enter button on your remote.
  6. Press the Exit button on your remote to exit.
Changing the Source Using the On-Screen Menu Accessed Through the Menu Button On The Front Of Your TV To use the on-screen menu of your TV accessed through the Menu button on the front of your TV to change video sources, follow these steps:
  1. Turn on your TV.
  2. Press the Menu button on the front of your TV. The Main Menu appears.
  3. Use the Up or Down Ch button on the TV to select Input, and then press the - or + Vol button. The Input menu appears.
  4. Use the Up or Down Ch button on the TV to select Source List, and then press the - or + Vol button.
  5. Press the Up or Down Ch button on your TV to select the signal source, and then press the - or + Vol button.
  6. Press the Menu button to exit.
Changing the Source Using the TV/Video or Source Button On Your Remote To use your remote to change the video source, follow these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button. The current source appears on the TV screen.
  3. Press the TV/Video or Source button repeatedly to cycle through the available sources. Stop when you reach the source you want.
Changing the Source Using the TV/Video or Source Button On The Front Of Your TV To use the TV/Video or Source button on the front panel of your TV to change the video source, follow these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button on the front of your TV. The current source appears on the TV screen.
Part 2 -next
Jan 20, 2009 | Televison & Video
RCA F25645 25in TV.
I have this same TV. The DVD player is either hooked up to the video or s-video input. Go to the Menu (either through the remote or from the front of the TV) and select the Setup option. Go to the part where it asks if you want to use a DVD player. Select yes. Then select Video Input. Exit the Setup. When you hit the DVD button, it will switch to the Video input. The second step is to go into the Menu and select Channel, then go to Video Input Source. From there, select which input you are using for your DVD player, the S-Video or the standard Video (yellow composite cable).
Mar 06, 2008 | RCA F25645 25" TV
Zenith advanced system 3, can't access video 1 or 2
I just got the TV for free with no remote and had the same problem.  The solution I found is to connect two devices that are feeding live signal (a VCR, DVD player, or game console) to the RCA connector input on the back of TV for Video 1 and Video 2.  I then used the first menu option which I accessed by using the Menu key on the front of the TV and Adjust and Select buttons to scan for channels and detect the band for the reciever to use.  After doing this I changed the setting away from "Fixed" (I forget which setting) and turned the TV on and off.  I then found that by pressing Menu several times I would get new menus.  Before I had done that scan with more devices attached to the other ports I didn't get any other menus.  I also discovered that depending on which devices I had connected I would get a Picture in Picture feature.  It would have its own menu to select its source, but I would lose that feature if I changed the device topography of my setup.
Sep 09, 2007 | Toshiba 27AF42 27" TV
How to change from video mode to cable/Antenna Input without a Remote
Alot of Zeniths have menu for that, have you tried to press the channel up button?
May 15, 2007 | Zenith A25A11D 25" TV
Zenith C27A24T 27" TV Logo
71 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
