Question about Lexmark X1240 All-In-One InkJet Printer
No power! I was reorganizing a room, disconnected
No power! I was reorganizing a room, disconnected everything, went to put it all back together and I have no power. I hooked the printer back up exactly how it was and it does nothing. Any ideas?
  • 1 more comment
  • leslie_erin Feb 25, 2009
    This is correct, nothing on the back, just the hookups for power and usb.
  • Thomas F. Schneider May 11, 2010
    If I were you I would consider opening it up and see if the power supply has a fuse on it, and may have been disloged in the move..
    You have the electric cord connected to an outlet and to the printer and their are no switches on the back of the printer, correct?
  • 54 Answers
If there is no power means than no problem
Posted on Feb 25, 2009
Sharp er a470 was changing faulty power cord and disconnected the keyboard, now after I put everything back together it won't come on. Checked power with multimeter, everything seems to be fine
Did you wear static protection while you were working inside? That's not for YOU, it's for the electronics. They're wicked sensitive to static.
BUT... it might also be the case that you just didn't plug everything back in perfectly. Go back inside, wearing static protection, and doublecheck every connector inside. EVERY connector, even if it's on the other side of the board.
Jul 26, 2014 | Computers & Internet
Installed new automatic transmission shifter cable. Got it on the car and works but something is not lined up. I got it hooked up to the transmission and to the shifter. When I shift through the gears they...
Set your park break and put the shifter in another gear and put the cover on. There may be a slight curve in the shifter to allow enough room. If everything works without it you can`t be off with the cable.
Feb 02, 2011 | 1999 Chrysler 300M
Hp pavilion a350 - when turn it on the fan runs but nothing else starts what to do?
take out the battery
disconnect power source
then hold down power button for approx 60 - 90 seconds
then put everything back together and you should be back up and running
Oct 16, 2010 | Computers & Internet
Tv went grayscreen, flickering. turned off, then
When you had gray screen and flickering you had only one problem - color wheel. After "putting everything together" you have totally different problem, caused by multiple possibilities like: forgotten connectors, cut/jammed cables/wires, lamp not being inserted properly, lamp door not being set properly, disconnected color wheel, etc. Try to open rear cover and redo what you have done. Remove optical block, check everything visually and slowly put everything back. If still no luck - then only skilled TV repairman may (or may not) help.
Mar 10, 2010 | Samsung Televison & Video
Itunes messed up my external hardrive
I doubt that iTunes really moved/reorganized files on your computer.
iTunest may have created its own "Table Of Contents", presenting a "view" of all your files.
Open "My Computer" and open your external hard-drive.
The files should be in "your" order.
Open "My Documents". Open "My Music".
If iTunes really did "reorganize" your files, there's no way to "go back", because "Windows System Restore" does not automatically created time-stamped backups of your 'My Documents' folder (nor of any external disk-drive -- where would it put that much data???).
Jan 02, 2010 | Seagate Free Agent Go Small 12 GB USB...
Nintendo ds shell replacement
you may have something that is touchign the screen, or the wiring may have been disconnected accidentally. try taking it apart and putting it back together again.
Jun 02, 2008 | Nintendo DS Console
Desktop E-Machine in suspended mode.
capacitors loose their power within 10 seconds so 20 seconds with the power turned off or completely disconnected and the c mos shorted will do the job in 20 seconds
May 09, 2008 | E-Machines eMachines T3830 PC Desktop
Lexmark X1240 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
