Question about Sony Cyber-shot DSC-N1 Digital Camera
Camera will not turn on.
I was taking pictures with a sony cyber-shot 10.1 megapixle. Then i was trying to delete the pictures by going into the setup option and the photos were not deleting so I shut off the the camera. Then went to turn it back on and it did not turn on. I tried many times now to turn the camera back on but nothing happens.Please help.
  • Sony Master
  • 890 Answers
Please make sure that the battery is fully charged. If the issue persists, try with different battery.
Posted on May 27, 2011
SOURCE:
Sony Cyber-shot takes lots of blurry pictures in
first thing you can do is to try reverting cam back to factory settings.to do that initialize the camera.it's under menu>setup settings>main settings1>initialize. after initializing,set cam to auto adjustment mode (green camera icon in mode dial). what to avoid when taking pictures:
1.subject too close (use macro if needed)
2.insufficient light
3.subject movement
4.camera movement (that's caused by you)
5.incorrect camera setting
5.incorrect camera operation
btw, before you take a picture,press the shutter button halfway down first to give the cam ample time to focus.you'll see a flashing green indicator on the screen that means cam is focusing.when the indicator stops blinking cam is ready for the shot.press shutter button all the way.review your picture.if still blurry, you may try changing iso (for dark or fast moving subject, note:the greater value the noisier the picture gets), metering mode and focus settings by going to the shooting menu (press menu when your in P or program mode). hope this helps.tnx:)
Apr 16, 2010 | Sony Cyber-shot DSC-S980 Digital Camera
I have a sony cyber-shot dsc-w55 cammera, and my daughter turned the dial that changes the picture modes to many times and now it only records on every picture mode...any ideas how to reset it?
Based on the information you provided, it seems that the Camera is in Burst or Multi-Burst mode.
You may Initialize the Camera as follows:
Initializing the Camera will reset the settings of the Camera to the factory settings including date and time. It will not delete any data saved in the Camera.
Set the mode Dial on Camera. then, press the Menu button on the Camera. Then, select the SETUP menu and select the SETUP 1 option of the Camera. Then, select the Initialize option to OK.
Good Luck!!!!!!!!!!!
Nov 18, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Sony Cyber-Shot DSC-T1 Digital Camera is taking weird pictures?
imager is going bad due to moisture. try using hair dryer to dry it out. if not flat rate to sony is around 120
Jul 12, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Sony cybershot dsc p200 user manual
Press Menu and go to setup, set date and time option to adjust it.
You can download user manual of DSC-P200 by clicking Sony Support. for further guidance.
Feb 11, 2009 | Sony Cyber-Shot DSC-P200 Digital Camera
I have a sony cyber shot dsc-n1 how do I delete all the pictures
Here's a little more detail... connect the camera to your computer; turn your camera on; switch cable connection to "camera"; in the pop up box select "Copy pix to a ... using Micro Scan & Camera Wizard" and press "OK"; in the next box select "advance users only"; Double click the "DCIM" file; double click the next file; and if you want all the pix gone select the first photo press "Shift" then select the last photo; right click either photo; then press delete. All gone.... Hope this helps.
Feb 09, 2009 | Sony Cyber-shot DSC-N1 Digital Camera
Deleting more than one picture at a time
Turn on your camera and go to menu select set up. Then select memory stick it is under the highlighted camera, Then click on format. Go to ok then click ok. Then your camera will read all data in memory will be erased. Then click OK. Now your on your way to a clean memory stick.
Jun 16, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Deletion of unwanted pictures
You need to right click on the photo and select delect.
When asked if you are sure select yes.
Feb 23, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
go to setup and then format... it will ask you to delete all pics.
Dec 31, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Why won't my Cyber-Shot DCS-P31 take pictures?
Actually, try manually turning off the flash and taking a picture. If the shutter works and takes a picture, then suspect that your flash is burned out. Unfortunately it's not a simple task to change a burned out flash tube.
Oct 20, 2007 | Sony Cyber-Shot DSC-P31 Digital Camera
Sony Cyber-shot DSC-N1 Digital Camera Logo
52 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
