Question about Technics Audio Players & Recorders
Volume erratic on technics sag76 model
I have an older technics SAG76 reciever, and the volume will suddenly go wide open even on a low setting. What is the fix, and could I attempt to repair it myself?
    Genius:
  • 1,175 Answers
Hi...
Buy some CAIG De-oxit.
It's made for cleaning contacts and controls.
You'll need to open the case ( UNPLUGGED)
and shoot some de-oxit into the volume control . There should be a **** or something to spray into.
You can get De-oxit at radio shack or partsexpress.com
Posted on Feb 25, 2009
Why is SSB reception (volume) extremely low?
If you have AN RF gain knob on this radio then turn it wide open.
Feb 12, 2016 | Radio Communications
Hooking up EQ to RECIEVER for a TECHNICS MODEL SH-8017
You'll need 4 connections total. On my integrated amp, I connected the four connections to all Line In and Line Out ports. And the other ends into the tape 2/EXTRA ports respectively.
Jul 19, 2013 | Panasonic Technics Stereo Graphic...
Turntable is playing quiet
Hi, if your not plugged into your amp via a dedicated phiono input, Ie CD or Aux then you need a preamp to boost the line levels. Cheers john. Styluscity
Oct 24, 2012 | Technics Audio Players & Recorders
I have to turn the volume wide open on my connex 3300 hpzx to be able to hear it . It recieves great but the volume is not load and i even tryed an extenal speaker on it
The RX wire could be broke in the mic cord. You will still get receive when you have the talk back is on, but it will be low. Try another mic.
Dec 21, 2010 | Connex 3300 240-Channels Base CB Radio
Erratic audio volume
Reinstall the driver
http://drivers-download-center.org/tag/erratic-audio-volume-driver
if the problem persists, check hardware
Jun 03, 2009 | Dell Dimension 9200 PC Desktop
My reciever volume cuts in and out and crackles when adjusting
You can CLEAN / LUBRICATEthe volume control know with a CONTACT/CONTROL cleaner, I use a product from Radio Shack, this works wonders on drum type electo mechanical devices which are basically volume control knobs, easy to do, just remove the round knob and spray into the openings with the small tube attached, and rotate in both directions, be sure to unplug the unit first, on a few occasions it is best to remove the front panel to acheive better coverage to the rheostat type volume body, anyway it always cures the crackling and distorting sound, I would give this a try before replacing the part.
Feb 14, 2009 | Technics Audio Players & Recorders
WON'T CHANGE CHANNELS ADJUST VOLUME OR SHUT OFF
If the volume buttons work when using the Radio, then the buttons on the Remote are fine.
Now if the volume on your TV is set to MAX and you can barely hear it.
The issue lies with your TV.. ()
Now if I understand correctly or if I am to assume you are using a Reviever.
If the reciever is used for all volumes... If this is the case.
I also assume the volume on the TV Speakers is set to off
Therefore when you use the Radio/DVD the volume control is using the Reciever volume.
and when you switch to TV it uses the TV volume thus the TV volume is not gonna work as well.
2 scenarios
1 The TV volume even at max is not giving you enough power to get the low receiver volume
2 the Receiver volume is at max and barely audible.. if this is the case just manualy adjust your TV volume to get it to a decent sound level.
Hard to explain but I know the 2 issues can be fixed.
Apr 21, 2008 | Logitech Harmony 550 Remote Control
Erratic volume on Technics SU-X911 amplifier (Class A)
its the ic that controls the + and - voltage and there are capacitors that have leaked all the caps on that board need changing could be expensive and time consuming but its the age of it . if i was going to do that job £200 plus\
Aug 24, 2007 | Technics SA-DX940
212 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
