Question about Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool duet ht flashes F 20
After about 20 mins my waher beebs and flashes f 20 what does this mean???
  • Nikki Nicholson May 11, 2010
    What is the model of the unit? Each unit has different error codes. If it is a duet sport it is no water detected and you water level control has failed. The failure is from over soap usage. Replace the control located on the right hand side of the machine and you problem should be solved.
  • 5,911 Answers
"F20" is a No Water Detect error code. Some of these error codes can be erroneous, however. The first step in troubleshooting any error code on these washers is to, first, unplug the unit for AT LEAST 30 minutes in an attempt to reset the CCU. If the error code returns after a reset, then you know you have a real problem. The following link explains the error code:
http://www.fixya.com/support/r1491905-f20_error_code_whirlpool_duet_kenmore
This is one of the more involved error codes to try to resolve because there are so many causes. I suggest you start with the simple things first. Make sure the water inlet hoses are unclogged and water flows freely through them. You can determine this by turning off the water and removing each hose from the back of the washer. Place them in a bucket or position the washer where you can place them inside the wash tub and turn the water back on. Both hoses should have free unobstructed water flow. It is common for the sediment screens at the end of the hoses to become clogged if you live in an area the uses well water, or if you have hard water.
Next, Make sure you don't have a siphoning problem. This is causes by placing the drain hose too far down in the standpipe. This creates a vacuum and the washer constantly drains as it tries to fill. If you pull up on the drain hose and hear a sucking noise, you have the drain line positioned too far in the standpipe. You need to keep an air gap in order to allow proper drainage.
Then, check the drain pump for obstructions. There is a clean out reservoir that you can remove the access the pump interior. Use the instructions I provide to perform these steps.
These are the simple items that you can easily rule out, first. Follow the remaining tips I provided you and if you still have questions, let me know before rating the solution. I hope this helps you.
Posted on Feb 26, 2009
Whirlpool duet ht will not agitate or spin
Front load washers don't "agitate". Did you mean it doesn't tumble during the wash cycle? I need more information. Complete model # and a more detailed description of the issue.
Mar 16, 2014 | Whirlpool Duet Sport HT WFW8400TE Washer
Code F 33 on whirlpool duet waher. Sevice guy
i think that has to do with not filling .. does water enter machine. is it filling slow?
Apr 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet ht. Model# ghw9250ml1.
replce the board located on the top right side of the chasis
Feb 11, 2010 | Washing Machines
I have a whirlpool duet ht and at a certain place in the cycle I get an H & F signal flashing....what does that mean? And how do I fix?
You can find fault codes here.
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
Not sure which problem your having but this might get you started.
Dec 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet frontload washer not draining on automatic cycle
Try unplugging for 10 min. This will reboot the system and clear the curcuit of all power. Replug the washer and select spin to drain. Selecting too many cycles in a short period of time can confuse the little brain in the curcuit just like a power surge does after a storm. Clear the brain and start from scratch.
Apr 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet HT GWH9300P Suds then F2
This means that the drain time has exceeded 8 minutes and the water valves have turned off. After 4 minutes the suds error is displayed then 4 minutes later the F2 error.
Potential causes
1.Check drain hose for kinks or cloggs
2.Check electrical connection at the pump and make sure the pump runs.
3.Check inside of pump for foreign objects
4.If none of the above fixes the machine replace the pump.
Nov 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
WHIRLPOOL DUET HT FRONT LOADING WASHER
This is a strange problem. I work on these all day, and never have a problem getting these boards. Might want to try and calling local part houses for this part.
Oct 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet ht. pops code f 2
f-02 means long drain. remove panel below door. pump will be in center right in front of you. remove cap and clean out pump. unplug washer first ofcourse
Nov 17, 2007 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
431 people viewed this question
Dan Webster
Dan Webster
Sal De
