Question about Delphi Audio Players & Recorders
I have a delphi delco xm radio in a semi.it does not p/u signal.lost signal from radio to xm receiver.part #12216460 prod id 2003. i was told it could be a 1 amp fuse. question,where is the fuse?
KaeZoo
  • 156 Answers
SOURCE: No Signal on my XM Radio
Where did you place the XM antenna on the vehicle? It's possible you have a defective antenna, but you can try a different mounting location. It needs to be on the outside of the vehicle, preferably on a large metal surface.
Posted on Jul 30, 2007
SOURCE: my delphi xm is frozen
I pressed the volume + and mode/power button simutaneously and this seemed to reset the unit and allowed the download to progress and allow the unit to power off
Posted on Jul 20, 2008
Hold the volume button down and press the mode button at the same time.
Posted on Dec 25, 2008
e-Guru
  • 3917 Answers
SOURCE: My Delphi skyfi3 xm radio
Hi
Hold down "power" and "volume up" at the same time to do a reset. You need a 'firmware update' from the Delphi website. Also, you can call Delphi for help too.
What you need to do is simultaneously hold the VOLUME UP button as well as the MODE button. This will reset the unit.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 20, 2010
TOLhamRadio
  • 509 Answers
SOURCE: Problem with the Delphi SKYFi3
Common problem with SkyFi3 units. You have to press the Volume UP button and hold it while you press the POWER button; this will 'reboot' your radio, then you can try it again to get it to go off.
You will need to update your firmware on the radio using the baby USB cable and the unit plugged into your computer WITH the battery recharged FIRST. Also, go to the www. xmradio dot com website and download the SkyFi3 FIRMWARE update. Then you need to download the "firmware update" into your SkyFi3. If this doesn't fix your lockup problem, you need to call DELPHI customer support, and they can tell you one more 'master reset' method. After the firmware update, it might take 2 or 3 'restarts'. Again, press and hold the Volume UP and PWR at the same time to reset a 'locked-up' SkyFi3. Regards, John
Posted on Oct 06, 2010
ID 4Z9AB0MC activated 2 days ago. Cannot select channels. Thumbwheel only displays 3 channels, ch.0,1,247. When pre/dir is pressed and a channel is selected, the selected channel number flashes...
Use plug-in power supply and leave on channel 1. Call XM (1-800-XM-RADIO) and ask them to "refresh" your radio. WAIT 1/2 hour, then check your channels. Make sure you have a decent signal too (can hear Channel 1 okay) before you call XM for the 'refresh signal' for your new radio.
Dec 21, 2009 | Delphi MyFi SA10113 XM Radio Receiver with...
No audio through car radio
is your car radio and the xm receiver tuned to the same frequency?
Aug 31, 2009 | Delphi SKYFi XM Radio Receiver
My Delphi Roady XT receiver will not maintain the signal. Does not work even I replaced the antenna. Works for a about 5 minutes before losing the signal
I had the same problem with my xt two years ago. I had two other roadys' at the time and they both worked with that antenna so I called xm customer service explained what was happening and they sent me a new receiver for $10. They told me that those units aren't worth trying to repair. Maybe you'll have the same luck I did. Give em a shout. Good luck.
Aug 19, 2009 | Delphi Roady XT XM Radio Receiver
Delphi SKYFi3 XM Radio Repeater
You begin by setting up your existing (((XM))) antenna the one that came in your home kit (not included in repeater package) in a location that gets good reception of the (((XM))) signal. This may be outside, or on a south facing window sill. This antenna gets plugged into the rear of the Delphi (((XM))) Radio Signal Repeater Transmitter. A power jack is right next to the antenna connection, and should be plugged in and to the wall with the included power supply. There is also a "PWR OUT" selector switch on the rear of the unit which allows you to control the strength of the signal transmitted from the unit.
Once the power and antenna are attached, both blue indicator lights will light up on the face of the unit. The blue antenna indicator will light up only to signify that the antenna is attached correctly. It does not let you know whether your antenna is in a location receiving a good (((XM))) signal or not. You will have to look at the signal strength indicator on your (((XM))) radio receiver do determine best location for the (((XM))) antenna.
Once you have this setup, place the Repeater Antenna close to your existing (((XM))) Radio and plug it into your antenna jack on the (((XM))) radio cradle. This connector is identical to your (((XM))) Home Antenna provided with all Boom boxes and (((XM))) home receivers and kits so compatibility is guaranteed. The Repeater Receiver Antenna does not require any separate power connections. Hope this helps!
SATELLITE RADIO WAREHOUSE
Jul 10, 2009 | Delphi SKYFi3 XM Radio Receiver
Xm radio
Looks like my company is going to purchase a new fm radio for the company truck, I should be able to plug the xm radio into it.
Jun 03, 2009 | Delphi SKYFi XM Radio Receiver
Lost manual
Here is a link to a PDF of the Manual at Delphi:
http://ppd.delphi.com/pdf/consumer/MyFiUserGuide.pdf
Jan 20, 2009 | Delphi MyFi SA10113 XM Radio Receiver with...
Lost the user manual
go to google.com and type skyfi2 xm radio manual. you will find the manual there as a .pdf file.
Dec 23, 2008 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
Delphi MyFI
I have the same problem, and only the same few channels are shown on the channel access screen and they all have + signs.
Aug 21, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
Great signal, so sound
My XM Boombox is also white and it is a Belkin. The folks at Delphi told me the receiver in the boombox is screwed up which over time also screws up the Delphi receiver. Belkin is sending me a new boombox and Delphi is sending me a new Roady XT.
Mar 01, 2008 | Delphi Roady XT XM Radio Receiver
XM reciever FM transmitter problem
hi Mr.Frazier....is the xm radio hardwired installed? if it's a yes you have to go to a professional(bestbuy, retailers) to have the connection check.. the problem is not within the xm radio..it's on how it was installed or set up...
If the radio was not built..well, that's much better we just have to check the audio connection from you're xm to fm radio (make sure to check if what band it is connected..such as AUX,CD etc.) if there's a sound but you're only getting preview channels..refresh must be send on the radio...you can call xm to ask for that OR do it online at www.refresh.xmradio.com and type in your 8 digit radio I.D just have to follow the activation instruction faithfully...Godbless!
Aug 26, 2006 | Delphi Roady2 SA10085 XM Radio Receiver...
Top Delphi Audio Players & Recorders Experts
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
