Question about E-Machines eMachines Desktop PC
Computer frozen at boot up menu
When you turn on the computer it freezes at the beginning page when the big E appears and it say BIOS Settings and boot up menu... however when you push f12 or f2 nothing happens. The PC it's self makes a load buzzing noise that's not usually made.
  • Thomas F. Schneider May 11, 2010
    Open the side of the computer . Turn it on and see if al the fans are running. If not , replace fans. Did this happen all at once or were you having problems and symptoms? If yes, what were they that lead up to this?
  • 21 Answers
HI Dear, You need lil bit patience and wait for computer response if it will not work after one min then off it and open its casing on the board near the internal power buttons option u will see the jumpers put out one the once then restart cpmputer and agian trun off it and insert the jumper and start the computer if it wil not work again then i will suggest u that show your computer to an expert that can see your computer physcally thank your very much bye.
Posted on Feb 25, 2009
  • 1,602 Answers
IS THE SOUND YOU HEAR CONTINUES OR IS IT BROKEN UP,
1 BEEP MEANS YOU ARE HAVING MEMORY CONFLICKS, IF YOU HAVE 2 PEACES OF RAM REMOVE ONE AND RESTART THE COMPUTER, IF YOU GET THE SAME RESULTS THAN TURN OFF THE MACHINE REMOVE THE RAM AND PUT IN THE OTHER PEACE OF RAM THAN RESTART THE MACHINE, IF YOUR SECOND PEACE OF RAM DOES THE SAME THING YOU CAN RULE OUT A MEMORY PROBLEM IT IS VERY UNLIKELY YOU HAVE TWO PEACE OF BAD MEMORY, OUT OF CHANCE SEE IFANYONE HAS A PEACE YOU CAN GET IT LOANED TO YOU TO TEST THERE RAM ALSO.
TRY TO REMEMBER THE LAST THING YOU WERE DOING WHEN THIS PROBLEM START TO HAPPEN, UPGRADES, INSTALLING NEW DRIVERS, DRIVERS UPDATES, INSTALLING NEW INTERNET PROVIDER, LIKE FIREFOX, OR ADD ON EXTIONS OF THE PROGRAM, INSTALL NEW PEACE OF HARDWARE, HARDWARE IS EASY JUST REMOVE IT AND REBOOT AND THAN REMOVE DRIVER OR PROGRAMS INSTALLED.
IF YOU NEED MORE HELP YOU CAN CONTACT ME THROUGH THIS WEB SITE
ROD
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
May 04, 2015 | Acer Aspire Computers & Internet
How to boot from usb on a powerspec
PowerSpec computers, as do all personal computers, have a motherboard inside that provides power and support to every piece of hardware that makes up the entire machine.
When your computer is first turned on, a small chip on the motherboard that houses a small piece of software called the BIOS (Basic Input/Output System) fires up before anything else and directs the startup processes for the rest of the computer.
By entering the BIOS settings, you can alter these startup procedures and control the power flow to certain components or stop them from starting up entirely.
The BIOS settings are only recommended for advanced users, as an improper change can stop your computer from starting up. Shut Down
Shut down your computer completely.
Do not make it hibernate or reset.
You need a fresh startup to enter the BIOS settings.
Waiting Period
Wait about 10 or 15 seconds after shutdown to allow the computer to become completely dormant.
Rebooting
Turn the computer back on and immediately begin pressing the "Delete" button on your keyboard at regular intervals (every two seconds).
Eventually the BIOS settings appear.
The display will look monochromatic and antiquated when compared to a modern Windows display.
This is typical of the BIOS setup screen.
Using the BIOS Menu
Using the keyboard arrow keys to move around the BIOS menu advanced bios features press enter change your first boot device to USB press "Enter" to select options once they are highlighted.
Press escape then press f10 to save to cmos to restart
and
Don't make random changes to the BIOS, as an improper setup can render your computer effectively useless.
Mar 10, 2014 | Computers & Internet
Default boot order for emachine laptop 732
Step 1:
All computer systems go through a set of instructions called the Basic Input/Output System (BIOS) when they are turned on. The BIOS checks all of the hardware and software installed on the computer to make sure they are working properly before loading the operating system. You may need to access the BIOS menu periodically to find out the current version of the BIOS you have if there are upgrades available. The command you use to access the BIOS settings on an Emachines computer will vary depending on the specific model you have.
Access the Start menu and click "Shut Down." Select the "Restart" option. Wait for the Emachines logo to appear on the screen as the computer begins booting up again. Press the "Tab" key when the logo appears and see if the computer switches to the BIOS menu. Press the "Escape," "Delete," or "F2" keys if the "Tab" key doesn't take you to the BIOS menu screen. Use the right arrow key to highlight the "Main" entry and press Enter. Scroll down to the heading labeled "BIOS version." Check the long string of numbers and letters under the "BIOS version" heading to locate the current BIOS version your Emachines is using. Press the "F10" key to exit the BIOS menu screen and finish booting up the computer's operating system.
Access/Enter Motherboard BIOS http://michaelstevenstech.com/bios_manufacturer.htm
Feb 22, 2013 | eMachines Computers & Internet
Dvd drive not seen in bios
Your computer's BIOS is an critical part of your system when it comes to hardware integration. This especially true when it comes to setting up hard drives and optical DVD drives. You can access your BIOS settings menu during the boot process of your computer. Different computers have different protocols when it comes to accessing the BIOS settings but many can be accessed by pressing "F1" or the "Delete" key before the operating system is loaded up. Consult your computer's documentation or pay close attention to your boot prompts displayed on the screen to enter the BIOS settings menu.
Turn on or restart your computer system. Press the appropriate key during POST in order to load the BIOS settings screen. You will have a short window of opportunity to press the appropriate key before the operating system loads. Search your BIOS menu settings for the appropriate menu concerning your attached hard drives and CD/DVD drives. If you are not sure where to navigate, consult your computer's owner manual. Check the drive menu to see if your DVD drive is listed. Many BIOS manufacturers give the user the option to scan for attached drives if the component does not appear to be listed. If the DVD drive does not appear after the hardware scan, turn off and disconnect your computer, take off the case cover and double check the data and power connections to the drive. Check the jumper settings on the back of the drive if it is of the IDE variety; SATA drives do not have any jumpers to set. There are three jumper settings for IDE based DVD drives: "Master", "Slave", and "Cable Select". Make sure the jumper is set to "Cable Select". Put the computer back together and plug it in. Turn on the computer and re-enter the appropriate BIOS settings menu. If the DVD drive shows up on your drive list, your computer has recognized it properly. Enter the boot settings menu of your BIOS. Change the boot order of your DVD drive to the first position so the computer will read it first during start up. This step is optional; however, you may wish to have this arrangement in case your computer needs to be started from a DVD boot disk later.
Feb 12, 2013 | Acer Aspire 5742Z-4200 Notebook
WIndows doesn't load ,frozen, internet connection problems
For that when you power up the computer press F1 or F2 or del or ALt+F2 key to enter in bios.
Then go to boot menu and set first boot device as your harddrive.
Also disable boot from lan in advanced menu.
Disable SATA in bios.
Then save settings and exit then check.
Let me know if you need further assistance.
Thanks for using FixYa.
May 14, 2010 | Acer Aspire One Netbook 8.9" Notebook
My laptop freezes on the main start screen
enter to bios set up then disable the f1 and f2
May 01, 2009 | Computers & Internet
Gateway mx3215 freezing on init boot
Corrupted driver or faulty hardware perhaps.
May 08, 2017 | Gateway FPD1975 19" LCD Monitor
Hp pVILLION DV 1000
This error message may appear when the computer BIOS is set to boot from a network and cannot find a bootable operating system on the network or on any of the storage devices included in the notebook PC's boot path.
The following steps are for most HP Pavilion and Compaq Presario Notebook PCs. The boot order can be configured on the Advanced tab in the BIOS settings menu. The steps to modify the boot order may vary depending on the model of your computer. On most HP notebooks the boot order can be configured using the following steps:
  1. Turn on or restart the computer.
  2. While the display is blank, press the F10 key to enter the BIOS settings menu. NOTE: Some notebook PCs use the F2 or F6 key.
  3. Use the right and left arrow keys to select the Advanced tab.
  4. Use the up and down arrow keys to select Boot Order .
  5. Follow the on-screen instructions to change the boot order.
Reset the boot order to the default settings Use the following steps to reset the boot order to the default settings:
  3. Press the F9 key to reset the BIOS to default settings.
  4. Press the F10 to save the changes and exit the BIOS settings menu.
I think it will you to fix your problem.
If still have problem then tell me more about it.
Thanks
Iqbal
Mar 18, 2008 | HP Pavilion Elite M9060N PC Desktop
After 18 month the computer will not go into POST on a re-start but will start normally when completed turned off.
simple. clear the CMOS by using clear cmos jumper setting or remove the cmos battery and put it again and then change the bios settings as per ur machine configuration.
Feb 23, 2007 | Foxconn NF4UK8AA-8EKRS Motherboard
E-Machines eMachines Desktop PC Logo
102 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
