Question about Sony STR-DE845 Receiver
I have a Sony STR-DE635. It has a switch on the front for speakers A, B, and A+B. Normal. When I am on speaker A only, it works fine. B does not work. A+B works, but only through the A speakers. Now, running through the demo mode, static comes through the B speakers, so it's not the connections. When I swith from A to B, I hear a clicking noise in the back, like something has actually switched. Here's the cool part, on B, if I press in on the front by the switch, the sound will work for a second or two, but i have to keep pressing in. Does anyone how I can fix this?
  • 336 Answers
Check for bad solder connections on the speaker switch or where the speaker switch board connects to another board. Not an uncommon problem with some Sony receivers.
Posted on Feb 26, 2009
Where do i find an A/B speaker switch
It's probably not the switch. These models have a common problem with the solder connections between the switch pcb and display pcb going bad. You need to resolder these connections, and your problem should be solved.
Jun 17, 2013 | Sony STR-DE635 Receiver
Right front channel not working
try to check balance adjustment if working.
Apr 16, 2010 | Sony STR-DE475 Receiver
Sound only some out of 2 speakers at a time. I need all 4.
Here you go buddy:
http://www.docs.sony.com/release/STRDE685.pdf
May 19, 2009 | Sony STR-DE685 Receiver
Sony STR-DE635, Sound from left surround speaker but not right
first turn the actual volume up on that channel on the reciver then make sure your speaker wires in the rear are using the same lenght each
May 18, 2009 | Sony STR-DE635 Receiver
Receiver clicks and rear speakers stop working
Maybe, it worked for me. my rear speakers workt ramdomly, often not. so i re solder the relay for the rear speakers, now it works fine everytime, a hole movie and some random on and offs, it can't do any harme to try=)
Dec 09, 2008 | Sony STR-DE635 Receiver
Bought some replacement speakers and the reciever seems to get ver hot!
Hello! Yes, you need to worry when a Sony gets hot!! You probably have replaced factory 8 ohm speakers with 4 ohm speakers. Look on the back of your new speakers and see what they are. Then look at the rear of your receiver by the speaker terminals and there will be a sentence like "8 Ohm minimum per channel". If your Sony says " 8 ohms " you need to use 8 ohm speakers.
Also, are you a using low level signal ( audio out ) to drive your sub or are you using high level ( speaker line )??? I'd use low level. Good luck!!
barneyluc
Oct 09, 2008 | Sony STR-DE635 Receiver
Sony str-de875 amp. one speaker louder than the rest
hi. i have a sony amplifier. i plug the speakers in like normal. i turn it on and the right side speeker works fine. but you half to crank it up all the way just to barely hear the left speeker. we switched speakers and its still the same effect. we think its the amp itself. we tried our balance settings. it was fine. but right now its just playing one speaker louder then the left one. can anyone help me?
Apr 03, 2008 | Sony STR-DE875 Receiver
Sony STR-DE635 Receiver-no sound at all
sorry my expertise is in appliances, youl need to repost you question to another tech
Mar 21, 2008 | Sony STR-DE635 Receiver
Turn your volume down,press the tape monitor button.then turn up?
Mar 20, 2008 | Sony STR-DE635 Receiver
Sony STR-DE845 Receiver Logo
275 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
