Question about Canon PIXMA MP780 All-In-One InkJet Printer
Doesn't print only copies PIXMA780
Doesn't print only copies PIXMA780 Installed new USB cable but they can't recognize the port?
    Problem Solver:
  • 6 Answers
Hi BabyM. I think you need new firmware update...Here is Canon site..: (Select your pc's OS before download)..Also can live chat with tech/support too...
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=10444
If you have Vista..Just run "Add printer mode and let window search for correct printer port.
Good luck.
Posted on Feb 25, 2009
Downloaded drivers for a new Samsung M2830DW and will not print. Computer does not recognize printer. Help???
Dear
Some times the front usb port arnot work. try to connect the /replace the usb cable to the usb port mounted on motherboard(back side panel of pc), It also may happen the usb port may disabled due to virus. Also you can unistall the driver during power OFF of the printer after uninstall successful power ON the printer, it will show NEW HARDWARE FOUND at the right right bottom of the pc screen ,If you OS is win 7 and connected to internet the driver automatically installed, otherwise you can load the driver cd and install the driver.
Also it can be checked at control panel-add hardware.
Thanks.
Feb 26, 2015 | Samsung Office Equipment & Supplies
Installing hp 1510e, plugged cable, wiil not recognize
then try to install manually, under Windows click add new printer,...
then find your printer on list and choose it.... and install it....
use drivers either to load by Windows automatically, or use path to your CD with software and drivers
Jan 13, 2014 | HP Deskjet 1510E Inkjet Multifunction...
My HP Deskjet F380 has the latest printing software installed; it spools and is attached to my laptop in the correct USB port; but it doesn't print. The message is "no connection." It printed...
Verify that the USB connection is fully inserted in the back of the printer itself. If all is well there, try to think if you've run any updates on your laptop recently, or installed any new software that could be conflicting. If yes, try removing the new software or recent updates, and try a test print. If this still does not work, try disconnecting the printer, powering down your machine, starting it back up and then reconnecting the printer to the USB port. Sometimes you have have a glitch in the USB port that causes your computer to stop recognizing a device seemingly out of nowhere. If none of the above seems to help, it might be as simple as a USB cable that's become faulty. Hope this helps!
Nov 19, 2010 | HP DeskJet F380 All-In-One Printer
My printer will print and copy but won't scan. It
First, do you have the full-featured version of the software installed (installed on the computer before connecting the printer to the computer)? Second, do you have the all-in-one connected to a print server or USB hub? These can block the two-way communication needed for scanning. Try a direct connection. Also try a new USB cable and a different USB port (if you have any signal loss issues, it matters more with the scanner).
I hope this helps.
Mar 22, 2010 | HP PhotoSmart C4280 Laser Printer
Konika Minolta 2400W can not connect. Clearly Windows XP sees it, and the driver is installed etc. When I plug or unplug the USB cable, Windows plug 'n play notices the difference. And the USB cable works...
Everytime you disconnect and reconnect the USB cable to a different port, unfortunately, Windows creates a new and distinct copy of the printer. You can see this by looking at the Windows Printers folder. The solution is when you change around USB ports, right click on the printer icon that is actually the active one (the other copies will be grayed out) and Set to Default. Then you can delete the other invalid copies. Then in the Minolta status software, go to the Display menu and Select Printer to change which printer is monitored to the correct copy. It's very stupid that Windows Plug n' play does this, but it does. So avoid change around USB ports on your Konika Minolta printer.
Jul 19, 2009 | Minolta magicolor 2400W Laser Printer
New Dell Inspiron connected to HP 820Cse printer. Won't print.
I've not worked with one of these cables before, but here's what I would do: Right-click on the printer icon and go to properties. You'll be looking for the tab that says "ports." Open that tab and see what port the computer thinks it's using for the printer. Chances it says it's using a parallel port, but it is in fact, using a USB port. I can't tell you which to choose without looking at what you see, but I think you might find one that makes reference to a USB port with a parallel connection of some type. Try clicking on that and see if your situation improves.
Feb 24, 2009 | HP DeskJet 820Cse Printer
Connecting USB cannon mp610 printer to computer
You need USB A-B cable and use the USB jack lying on the back-right corner of the printer (not the front one - that is for connecting cameras).
Sep 02, 2008 | Zebra LP 2844 Thermal Printer
Lexmark x3550 printer
The issue which u r facing is" Communication issue"
Make sure u have installed the lexmark printer software...or else download it from the lexmark website(lexmark.com)..choose the s\w for ur operation system( Xp or vista(32bit or 64bit))...
If s\w is installed...
Check the USB cable..try different port...
Clear all the docs in the printer folder...
Remove the power adaptor and replung..restart computer..
When u unplug and replung the usb cable doesn ur computer give a pop up "found New hardware" ?
U can also try...
Uninstalling the s\w....disconnect the USB cable..reinstal the s\w and connect the cable when it prompts to...
Jun 09, 2008 | Lexmark All-in-One Printer with PictBridge
Lexmark X4270......All in one....computer recognized it two days ago, but today it isn't doing anything. Can you help me?
When u unplug and replung the usb cable doesn ur computer give a pop up "found New hardware" ?...If it doesnt..then (Check if USB printing support,USB composite device are present in the Device manager...i.e Right click on "my computer" ikon-go to PROPERTIES-Hardware-Device manager-Click the plus sing near and check in the list )
U can also try...
Jun 02, 2008 | Lexmark X4270 All-In-One InkJet Printer
Printer will not print
Some thoughts.
When you plug it into the computer that it will not print to, Does it tell you there is a new USB device found?
2. I am sure you have tried different USB ports on the computer.
3. Right click your printer to access the properties on the driver and select Ports and see if that somehow was changed.
4. Just delete the printer from the "printers" page in control panel.
Then click add printer and search for it.
5. Make sure the computer does not have a firewall that is blocking the printer.
6. Make sure there is no job error in the print queue.
7. Be sure the printer is selected as the "Default" printer. If there is another printer loaded on the computer, is the wrong one selected?
8 Make sure Print Pause is not selected.
I do suspect once you open the properties on the driver page you will find the problem. Unless of course your USB port or ports on the computer have failed.
Dec 14, 2007 | Samsung SCX-6320F All-In-One Laser Printer
Canon PIXMA MP780 All-In-One InkJet Printer Logo
71 people viewed this question
old marine
old marine
