Question about Sony FD Trinitron WEGA KV-32HS510 32" TV
Tv shuts itself off randomly
Model #kv-32hs420 shuts itself off standby timer light flashes when we turn tv back on but power light never lights up.
  • 790 Answers
Hi
you have defective power oscillation in power section
this needs to diagnose for a qualified technician
Thanks!
Posted on Feb 25, 2009
Sont tv model#kv-32hs420
Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206. Check this link for more details.http://electronicshelponline.blogspot.com/ Pull up older posts. Blinking codes to Sony TVs are given in detail.
Jun 05, 2013 | Televison & Video
Stand by timer sony triniton color tv Model kv-32hs420
How many times the standby button blinks before going OFF at one time switch ON?
Apr 17, 2012 | Sony FD Trinitron WEGA KV-32HS420 32" TV
KV-24FS100 TV shutting off
How many times the standby light flashes in between switch ON and going OFF?
For more details about this fault, visit this site, and call older posts.
Type in this link address, [without brackets] either to Google Search Box or into the Address Bar to your browser and press Enter. It has all the details about blinking codes of Sony Sets.
electronicshelponline(.)blogspot(.)com
In name [Electro-Help]
Apr 16, 2012 | Sony FD Trinitron KV-32HV600 32" TV
Tv shuts off on start up and light flashes six times
more loose inside your tv that is a reason for your tv shut off you need to resolder the printed board
Jun 24, 2010 | Sony FD Trinitron WEGA KV-32HS420 32" TV
Why does my Sony 57" Hi-Scan 1080i? 16:9 Projection Television keep turning itself off. I turn it on and after 10 min it shuts itself off I can turn it back on but the longer it is on the quicker it shuts...
Sounds like a heat problem. Check to make sure that if it has a internal fan that it is working, and clean any dust build up, most projection tv's have fans, usually the number of flashes indicate a code that repeats.
Mar 16, 2010 | Sony KV-28FX60 28" TV
Canno turn the tv on.
You probably have a main or high voltage power supply problem; the latter produces the 20,000 plus volts for the CRT and gets its voltage from the main supply. It's difficult to say which is at fault without a few measurements.
Feb 14, 2010 | Sony FD Trinitron WEGA KV-32HS420 32" TV
Tube does not turn on
If TV model is Sony KV-32HS420 then mostly it requires to replace 2 ICs on DZ board, let me know if you can replace ICs on circuit board and know about TV repair to provide you more technical info.
Thanks.
Sep 16, 2009 | Sony FD Trinitron WEGA KV-32HS420 32" TV
Blinking/standby timer
Sony Trinitron TV. Worked well last evening. Now picture won't go on. When power is turned on, standby/timer red light flashes, but picture or sound does not work.
Jul 01, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Assistant
is this electricity pocket plugged up to a timer ? or take the tv back to the shop... lost the receit just look for the same tv on computer
Feb 20, 2008 | Toshiba 28N33 28" TV
Blinking Standby Light
KV32hs500 tv won't turn on. Standby light blinks 7 times, stops and then 7 more times, etc.. The tv will usually come on after about 2 hours or so of being off. Plays fine when on but once it gets turned off the problem happens again. Any suggestions? T.V. is 5 years old.
I have a similar problem . mine blinks 6 times or 7 sometimes also,and comes on with sound ,no picture for about 2 seconds then shuts off. Anything?
Jan 31, 2008 | Televison & Video
Sony FD Trinitron WEGA KV-32HS510 32" TV Logo
408 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
