Question about Sony Playstation 3 (PS3) Console
Ps 3freeze every time io start my ps3 it just freeze. it is not taking me to the main menu. i tried reseting it and ever removed the hard disk to format it it did not ask me if i want to format, any solution. thanks
    President:
  • 2,653 Answers
It's not going to ask you if you want to format it. Windows won't even detect it correctly because of the file format.
Check out my common PS3 problem and repair guide for tips and suggestions for more details.
Pay close attention to # 3.
http://rescuetechla.blogspot.com/
Please feel free to email me any other questions and please don't forget to rate!
Thanks!
RescueTechLA
Posted on Feb 25, 2009
Unit freezes in play, red ring of death, will not eject disk
The PS3 has a special Recovery Menu, which you can access in the following way:
1. Turn off Playstation 3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION 3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION 3 System
From the above select option "Rebuild Database". After PS3 has executed this DB rebuilding operation, the disc games will be visible again in the menu.
Thank you !!
May 25, 2010 | Sony Playstation 3 (PS3) Console
Ps3 starts up and quickly freezes at the Sony insignia part. Shut it off and restart and it freezes at the same spot.
Ensure that you are not starting PS with disk inside, if disk is scratched or bad, or PS lens is dirty you can get same problem when you start PS with disk inside.
Aug 20, 2008 | Video Game Consoles & Games
Wont start messages comes up saying correct hard disk not found
your hard drive may be dying. or the file system may be corrupted.
before you get a new hard drive there are some tricks to try.
#1 remove the HDD and boot it up without it in, then turn off and put the HDD back in and boot again.
#2 rebuild the file system in the recovery menu
#3 rebuild the database in the recovery menu
To get to the recovery menu you need to press and hold the power button when the ps3 is in standby mode untill you hear a double beep then release. sometimes the ps3 will go back to standby mode before it does the double beep if it does just release the button and press and hold again real fast and wait for double beep.
here is what mine does
ps3 standby(red light) press hold power...........beep...............beep.........standby again, release hold............beep..................double beep ..release power button.
from the recovery consol you can rebuild the file system and database sometimes when they are corrupted it has same symptoms as a dying HDD.
P.S. rebuilding the file system and database will not lose any of your ps3 data, other options will though like the restore ps3 and format HDD.
if the above tricks dont work try updating the firmware, if your at the current firmware you can re-install it from the recovery menu as well using a usb memory stick or a cd with the firmware on it.
if all that doesnt help it looks like its time to get a new HDD, but at least you can upgrade it to a bigger ps3 now. any sata laptop HDD should work. i think a 160gb HDD is only $50ish.
Oct 08, 2009 | Sony Playstation 3 (PS3) Console
Wont load!
Try going in to the playstation diagnostic menu. This is accessible as follows:
Make sure you have the controller charger cable plugged in and your controller plugged in before you start. While the PS3 is off press and hold the power button, the PS3 will start, beep 3 times and then turn off again. Once it's switched off take your finger off the power button for a second or two then put it back on, listening out for two beeps, then remove it. On the screen it will ask you to plug your controller in and press the PS button, do so and you'll be presented with 6 options.
The first one you want to try is restore file system, this will check your PS3 for any errors on the hard drive, and correct them if they can. This may take a little while but let it run through and see if it works.
If not then move on to the next option, but BACK UP YOUR DATA BEFORE DOING SO, the next step will wipe your PS3 clean! Repeat the process above until you get to the menu and then select "Rebuild database".
Try these two first and let me know if it helps! :)
Aug 04, 2009 | Sony Playstation 3 (PS3) Console
My ps3 freezes in the main menu Yea i have the same problem... when i turned on my ps3 and was gonna log into my psn it just freez up.. so now i'm stuck at the  "Log in Naddepusen" (psn) with the wave...
**USE A FLASHDRIVE FIRST TO BACK UP YOUR SAVED GAMES**
Settings > System Settings > Restore PS3™ System
Delete all hard disk content and restore the system software to its default settings. Follow the on-screen instructions to perform this operation.
After the operation has been completed, the initial setup screen will be displayed. Follow the on-screen instructions to complete the operation.
Notices
  • When you perform this operation, all data on the hard disk will be deleted. Also, the system software will be restored to its default settings. Be careful not to accidentally delete important data as the changes cannot be undone. Data loss or corruption is the responsibility of the user.
  • Do not turn off the PS3™ system during this operation. If the operation is cancelled before completion, the system software may become damaged, and the system may require servicing or exchange.
  • During this operation, the power button on the system front and the PS button on the wireless controller are not active.
  • You cannot use this feature to go back to an earlier version of the system software.
  • You can shorten the formatting time by selecting [Quick Format] from the hard disk format methods. However, in this case it may be possible for some deleted data to be restored if a specialized tool is used. Select [Full Format] when formatting a hard disk that contains important or sensitive data.
May 29, 2009 | Sony Playstation 3 (PS3) Console
Ps3 freezes before getting to main menu!!
I had the same problem bud. I rushed and contacted sony but the next day my friend told me a great solution tht safed me 150 $. Well basicly your ps3 is lika a PC. All you nerd to do is to get to the hard drive menu. By holding the power button for 10 sec but do that for 3 times. That will take you to the blue menu. From there just reset your hard drive and wola brand new.
Ps Same thing happend after i downloaded the house app. booo to the house lol
Jan 20, 2009 | Sony PlayStation® 3 (60 GB) Console
When I switch on my PS3 it says that the hard disk is corrupted and to proceed to press OK. So I pressed OK and it loaded, turned itself off and the system restarted itself. But nothing seems to have...
you already have a corrupted hard disk.the best possible solution for that is to replace it with a new hard disk.corrupted hard disk causes the ps3 to freeze bcoz it cannot the load the data that the ps3 needs to boot properly.hope this one solves the problem
Dec 21, 2008 | Video Game Consoles & Games
Try Accessing the Ps3 Recovery Menu
Turn off Ps3
Once the system has been shutdown, re-press your finger until you hear 2 consecutive (quick) beeps
You will be prompted to plug in your controller via usb and then hit the ps button
The recovery menu will pop up
Recovery menu
* restart system
* restore default settings
* restore file system
*rebuild database
*restore ps3
*system update
Now I was not sure which one to choose. I clicked restart system and that did NOT work so I clicked restore ps3 and lost everything but it DEFINITELY WORKED!!
Nov 02, 2008 | Sony Playstation 3 (PS3) Console
Game Freezes
It seems that your system is having trouble writing data to the HDD. Have you tried switching hard drives with your brother? It can be a corrupt sector or the entire disk. Try to format the disk and try again or switch your hard drive with your brother's or if you have the cash, buy a new hard drive for your ps3. Regards. Hope it helps.
PS: If you try using your brother's hard drive in your PS3 you will have to format it so I suggest you do a backup.
Dec 03, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
26 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
