Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Sony 53 inch projection screen with hourglass picture
I have a Sony KP53S25 projection screen that works fine when first turned on but after a few minutes the left and right sides bow in like an hourglass. If I turn it off and back on it is fine for awhile but always returns to the hourglass picture. I've been told that it is a convergence issue. Is that adjustable or do I have to replace a part(s)?
  • 4,234 Answers
For your information, the problem as you describe it is not a convergence problem. It is what is called a "pincushoin" problem. The D board contains the circuit to address this.
Dan
Posted on Feb 26, 2009
  • 10,594 Answers
If you are familiar with TV repair, have electronics basic knowledge, good soldering skills and tools then check dry (cold) soldering joints at D board of this TV. Resold all lose connections there and check picture.
Still no joy then you need to replace D board.
Posted on Feb 25, 2009
Where is the fuse located on a KP53S25 Sony TV?
hello there should be a glass fuse in the power supply also beware in a lot of sony sets there are soldered in fuses aswell. and circuit protectors i hope it helps
regards
shaun
Feb 05, 2010 | Sony KP-53S25 53" Rear Projection...
I have a 2000 Sony 53 inch projection tv that turns on but there is no picture.You can see the video display but is scrambled.
It could be an issue with yoru DMD board, which are micromirrors, those are the ones that form the image. discountdashmerchantdotcom
Jul 30, 2009 | Sony Televison & Video
Sony KP53S25 rear projection TV - Horizontal lines on display
try this link
see this link and try to understand the blink codes.
this will surely help you
May 31, 2009 | Philips 60PP9202 60" Rear Projection...
Tv screen will not stop blinking
It sounds definitely like a faulty power connection via the video cable from the inside. If it blinks a while then turns black then shows the picture, it would have to be that it's not screwed on properly, thus taking more time for it to get a full charge and then properly function. If you still have the warranty, any electric repair/retailer shop can fix it for you.
May 04, 2009 | Sony KP-53S65 53" Rear Projection...
52 inch projection sony
Check settings on main screen go into menu to change settings///also you can try resetting it by unpluging for five min....replace plug ...now PUSH AND HOLD thepower button for 10 seconds
Dec 13, 2008 | Sony KP-53XBR200 53" Rear Projection...
Sony KP53V45 53 inch
two three-pin voltage regulators near the left side (looking in from the back) bend over from the heat and short to a ground rail. Check and straighten them with the power off and the unit unplugged
Mar 09, 2008 | Sony KP-53V45 53" Rear Projection...
52 inch sony rear projection t.v.
Whining sound most likely is a bad flyback transformer. You are probally looking at a 350-450 bill depending on the repair shop. If your picture was "great" go for it. If the tv has a lot of wear let it go. Nothing the repair shop does to fix your problem will make your picture better than it was before it went out. Somthing to contemplate.
Feb 05, 2008 | Televison & Video
Big screen troubles....
It is either going to be a shorted blue CRT (picture tube) or a driver board for it. I suspect the CRT itself.
Apr 17, 2007 | Sony KP-53S35 53" Rear Projection...
Sony KP 53S65 53" rear projection TV contrast issue
While the root of the problem is likely the picture tubes aging, I'm sure it would benefit from a cleaning and adjusting. After the dust is cleaned from the lenses, the screen controls could likely be lowered to get the blacks you desire. An experienced tech would be able to do this for you.
Jan 03, 2007 | Sony KP-53S65 53" Rear Projection...
Sony KP53S25
your problem is a defect with the b+ going to the crt driver transistors such as a capacitor off the High voltage tranformer or could be a coil or resistor that changed value in the filiment curcuit. This is another hard one to say without more info. if yuo dont do any troubleshooting or dont have the know how then Im thinking its best that you call a pro.. Good Luck
May 03, 2006 | Sony KP-53S25 53" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
97 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
