Question about HP Compaq nc6320 Notebook
Bios password dear all, when i switch on my computer, its prompt me to enter a correct password. but i have never set up any passoword on it. i have alread removed the cmos batery for some seconds and it did not solve the problem... that´s why i need your help in this issue kind regards, ?ngelo
  • 203 Answers
If you have never set a password and you brought it from new then the password would be blank. try just pressing enter when it asks for the password.
Posted on Feb 25, 2009
    President:
  • 2,653 Answers
You'll have to contact HP Tech support, they'll tell you that you're going to need to either send the laptop in or find a local authorised service provider who can remove the password.
Here's their contact info:
http://welcome.hp.com/country/us/en/contact_us.html
Best of luck!
  • RescueTechLA
    RescueTechLA Feb 25, 2009
    That's a really good suggestion revskank, I always forget to mention that one.
    Keep up the good work!
How can i have the password bios of laptop dell E6420
f you are running Dell servers, it is recommended to enable BIOS password. This is will prevent accidental changes done to Dell BIOS settings by others who get physical access to the server.
You can setup two different types of passwords in Dell BIOS:
System Password: This will be prompted before the system can boot up, and load the operating system.
Setup password: The system will prompt for this password only when you are trying to access the BIOS settings.
Depending on your situation, it might be a good idea to enable both the system and setup password at the BIOS level. I recommend that you at least enable BIOS password.
Press F2 for System Setup
When the Dell server is booting up, press F2 to start system setup, from where you can change Dell BIOS settings.
BIOS System Security
From the Dell BIOS main menu, scroll down to "System Security" and press enter.
Password Not Enabled
From here, you can see that both the System and Setup password is not enabled by default.
Enable System Password (and Setup Password)
Scroll to "System Password" and press enter, which will prompt you to enter the password that you like to set for the system. Please understand that if you set this password, you have to enter this password everytime you start the system. Do the same thing for Setup Password.
Don't forget this bios password. If you forget, then you have go through the painful process of resetting the Dell BIOS password.
Password is Enabled
Once you've enabled both the password, from the "System Security" menu, you'll see that that both system and setup password is enabled as shown below.
password is set
System Password Prompt (During Startup)
From now-onwards, anytime you start the system, it will not load the operating system, unless you specify the system password as shown below.
12345
Setup Password Prompt (To Access BIOS)
If you press F2, to get to the BIOS, it will prompt for the setup password as shown below. If you don't enter a valid password here, you cannot access the Dell BIOS settings anymore.
Dec 16, 2014 | Dell Latitude E6420 Laptop Computer...
Tip
Toshiba Laptop BIOS Password Removal
<span><b>ESC Key BIOS Password removing procedure</b><br />1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the Esc key. The computer will display the "Password = " prompt.<br />2. Enter the correct password, and press the Enter key. The computer will display "Valid password entered, system is now starting up. Check system. Then press (F1) key"<br />3. Press the F1 key. The BIOS setup program will appear.<br />4. Using the arrow keys or the tab key, move to the password field, and highlight REGISTERED.<br />5. Press the spacebar, enter the correct password, and press the Enter key. The Password field will change to NOT REGISTERED.<br /><b><br />F2 Key BIOS Password removing procedure</b><br />1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the F2 key. The unit will display the "Password = " prompt.<br />2. Enter the correct password, press the Enter key. (You may need to press the F2 key after you hit the enter key.)<br />3. The BIOS setup program will appear.<br />4. Using the arrow keys, move to the Security tab, and to Set User Password.<br />5. Press the F5 or the F6 key to navigate to the Password section. Enter the current password at the Old Password prompt, and press Enter. At the New Password prompt, press Enter (without typing anything into the password field). At the Confirm Password prompt, press Enter again (without typing anything into the password field). The password should now be removed.<br />6. Press F10 to save and exit from the BIOS Setup program.<br /><br />In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.<br /><br />If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.</span>
on Jun 09, 2011 | Computers & Internet
Tip
TRICKS AND TIPS ON HOW TO ACCESS THE BIOS/CMOS WHENEVER YOU FORGOT THE PASSWORD
BIOS PASSWORD ARE USED TO SECURE YOUR COMPUTER BY PREVENTING OTHER USERS TO ACCESS YOUR COMPUTER'S BIOS SETTING OR MAKING IT UNBOOTABLE REQUIRING PASSWORD.
But in some cases, some people forgot the password.
HERE ARE THE TRICKS AND TIPS ON HOW TO ACCESS THE BIOS/CMOS SETTING WHENEVER YOU FORGOT THE PASSWORD.
SOLUTION1. RESET THE BIOS PASSWORD USING DOS COMMAND PROMPT.
1. Go to start menu and choose RUN. For other operating system like Windows 7 and Vista, just use the search bar and type the command prompt. Right click mouse and run as administrator.
2. type the word "debug" and press enter
3. type the code "-o 70 2e" and press enter
4. type the code "-o 71 ff" and press enter
5. type the letter "q" and press enter
6. type the word "exit" and press enter
7. try to restart your computer and it will remove the bios password.
SOLUTION 2. TRICK THE COMPUTER TO GENERATE BIOS PASSWORD.
Some computer can generate bios password when you enter 3 different incorrect bios password. Below message will appear:
Password check failed
Fatal error...System halted.
CNU9117K31
Use the last line as password. CNU9117K31
SOLUTION 3. USE BACKDOOR PASSWORDS
AWARD BIOS
AWARD SW, AWARD_SW, Award SW, AWARD PW, _award, awkward, J64, j256, j262, j332, j322, 01322222, 589589, 589721, 595595, 598598, HLT, SER, SKY_FOX, aLLy, aLLY, Condo, CONCAT, TTPTHA, aPAf, HLT, KDD, ZBAAACA, ZAAADA, ZJAAADC, djonet
AMI BIOS
AMI, A.M.I., AMI SW, AMI_SW, BIOS, PASSWORD, HEWITT RAND, Oder
OTHER PASSWORDS:
VOBIS & IBM - merlin
Dell - Dell
Biostar - Biostar
Compaq - Compaq
Enox - xo11ne
Epox - central
Freetech - Posterie
IWill - iwill
Jetway - spooml
Packard Bell - bell9
QDI - QDI
Siemens - SKY_FOX
TMC - BIGO
Toshiba - Toshiba
In TOSHIBA BIOS, just hold left shift key during booting process.
For IBM APTIVA BIOS, press both mouse repeatedly during the boot.
SOLUTION 4. CLEARING THE CMOS JUMPER OR DIPSWITCH SETTING.
Go to your motherboard and look for jumper should be located near bios chips or near the battery. THere is usullay 3 pin switch two of them covered with this jumper.
Procedures :
1. Turn off your computer.
2. Unplug the power cable from the power supply unit.
3. Wait for 30 mins to be safe that your motherboard is fully discharged.
4. Locate the jumper.
5. If there is 3 pin switches, the jumper shows would be in 1-2 position. Just place it in 2-3 position with a few seconds and then return it back to normal position 1-2 position.
6. If there is only 2 pin switch, just remove the jumper with a few seconds and then place it back to normal.
7. Connect all the connection and restart your computer. It it will reset the bios setting.
SOLUTION 5. REMOVING THE CMOS BATTERY
If the jumper switch solution doesn't work, try this solution by removing the cmos battery.
Procedures:
2. Remove power source cable.
3. Go to your motherboard and remove cmos battery.
4. Wait for 30 mins or more before returning it back.
5. Place the battery back correctly
6. Plug your power cable and start your computer and it is done.
GOOD LUCK AND I HOPE THIS WILL BE HELPFUL FOR OTHERS.
on Dec 19, 2010 | Computers & Internet
Bypass bios setup password hp pavillion
Step 1:
All computer BIOS chips have a backdoor master password designed to be used in the event that you can't remember the password you set yourself or by a tech support agent who is fixing your machine. These passwords are set at the factory level and do not change, no matter what model of computer you own. You will use this password to bypass the currently set password in the event that you need to access your HP BIOS but cannot.
Turn on your HP computer. Strike the "F2" keyboard key. Your HP computer will attempt to load your BIOS. You will be prompted to enter your current password. Type "merlin" into the password prompt and hit "Enter." This is the backdoor BIOS password for HP brand computers. You will now bypass the user defined password and the BIOS screen will load as normal.
How to Reset a BIOS Password
http://www.tech-faq.com/reset-bios-password.html
Mar 11, 2013 | HEWLETT-PACKARD Hewlett Packard Pavilion...
I have a toshiba tecra a8 pta83e when i switch my laptop on a black screen comes like DOS and written on (alert: system protection failure! password= ) so can u help me and...
You must have set up a password in bios for protection as it appear.
Follow below steps to fix it:-
Shutdown Tecra
Press ESC and Power button together
Enter the passwords if prompted
Press F1 to enter the BIOS
Select the password field (it shows Registered)
enter bkspc or space
enter your existing password
press enter
It prompts for New password
Just enter
Repeat for verify
Now password is Unregistered
Can be repeated for any password field
Hope this helps
Regards,
Sunil
Jan 26, 2018 | Toshiba Tecra A8-EZ8311 Notebook
I am trying to restore my laptop to factory settings coz I had a virus and as soon as i had pressed F10 after the Windows logo it is asking for a password. But I do not have one. Can you help?
I have older Toshiba laptop A15-S1292 running XP SP3. Problem is every time it start, before anything can be seen, it ask for password. I know the password, but I do not know how to romove the...
Jun 01, 2011 | Toshiba Satellite A15-S127 Notebook
How do i rmove a bio password out of my toshiba satellite m305-s 4910 laptop
B I O S P A S S W O R D
Setting the BIOS Password
There are two main varieties of BIOS used in Toshiba notebooks, each with its own unique method for setting and disabling a password. First, determine which type of BIOS is used in your notebook model, as follows:
Immediately and repeatedly tap the Esc key. If the message "Check System and press the F1 key" appears, then follow the "Esc key BIOS" procedure, below.
If the computer ignores the Esc key when it's powered-on, or if you see an invitation to press the F2 key to enter the BIOS Setup utility, follow the "F2 key BIOS" procedure, below.
Almost all Toshiba notebook computers will respond to either the Esc key or the F2 key when they're first powered-on. The Toshiba HWSetup program (found in the Windows Control Panel) may also be used for setting and disabling the BIOS password. See the HWSetup procedure, below.
To set a BIOS password, start the BIOS Setup program and enter a new password into the password field, per the detailed instructions below. Once a BIOS password is set, it will be necessary to enter it whenever the computer is started, restarted or reset. Choose a password that you can reliably recall, or make note of it in a secure location. If you forget the BIOS password, only a Toshiba Authorized Service Provider can remove it.
ESC key BIOS Password setting procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the Esc key, until the message "Check system. Then press (F1) key" appears on the screen.
2. Press the F1 key. The BIOS setup program will appear.
3. Using the arrow keys or the tab key, move to the Password field, and highlight NOT REGISTERED.
4. Press the spacebar, and then enter a new password at the "Password = " prompt. Press the Enter key.
5. Enter the password again when the Setup program prompts for it, and press Enter. The Password field will change to REGISTERED.
6. Press the End key and then the Y key to save changes and exit the BIOS Setup program.
F2 key BIOS Password setting procedure
2. The BIOS setup program should appear. If Windows starts, shut down the computer and try step 1 again.
3. Use the arrow keys to move to the Security tab.
4. Use the arrow keys to select "Set User Password". (This 'User Password' is equivalent to what is otherwise called, in this document, a 'BIOS Password'.)
(It may be necessary to set a supervisor password before setting a user password. A Supervisor Password may be thought of as a backup mechanism -- if a User Password is forgotten, the Supervisor Password will allow access to the computer. The next section describes how to set a Supervisor Password.)
5. Press the F5 or the F6 key to navigate to the Password section. Type in a new password at the "Password = " prompt, and then press the Enter key.
6. Enter the password again when the Setup program prompts for it, and press Enter. The password field will now change to indicate that a password has been entered.
7. Optionally, set the Password on Boot feature to 'Enable'. Otherwise the computer may not prompt for the password at startup.
8. Press the F10 key to save changes and exit the BIOS Setup program.
HWSetup BIOS Password setting procedure (This method works for most notebook models.)
1. In Windows, click Start, then Control Panel (or Start, then Settings, then Control Panel).
2. In Control Panel, click on the icon for HWSetup or Toshiba Hardware Setup.
(If neither of these icons are present, download and install the Toshiba utilities for your model from the Service and Support Website, or use the appropriate BIOS Setup procedure above.)
3. Click on the Password tab.
4. Click to select Registered. Alternately, there may be a choice for User or Supervisor Password. Select one or the other
5. Enter a new password at the "Password = " prompt, and press the Enter key.
6. Enter the password again when the HWSetup program prompts for it, and press Enter. The Password field will now say REGISTERED or SET.
8. Close the HWSetup program.
_______________________________________________________________________
Removing the BIOS Password
Follow one of the procedures below to remove a BIOS Password. See the section 'Setting the BIOS Password', above, to determine which type of BIOS your computer has. Once the password is removed, the computer will no longer prompt for a password when it's started. Removing the BIOS Password requires you to enter it first. If you cannot recall the BIOS Password, only a Toshiba Authorized Service Provider can remove it.
HWsetup BIOS Password removing procedure (This method works for most notebook models.)
4. Click to select Registered. Alternately, there may be a choice for User or Supervisor Password. Select one or the other.
5. Enter the current password at the "Password = " prompt, press the Enter key. If the HWSetup app prompts for the current password and then twice for the new password, simply press the enter key three times after entering the current password. By pressing the Enter key only, you are selecting no password.
6. HWSetup should now show that the password is Unregistered, which means there is no password set.
7. Close the HWSetup program.
Trus this is helpful. Please vote. :)
Dec 12, 2010 | YouTube Videos
My 9 year old computer is lock how do i unlock it if i forget his pass word
If you have another account on your laptop that has administrator rights, log in into that account and change the password for your account (click on switch account to log in). If you have an administrator account (even if you don't try putting in Administrator and leave password field blank) try using that account to reset the password, otherwise try one of the following:
- see this for XP http://support.microsoft.com/kb/321305
- or this for Vista/Win7 http://windows.microsoft.com/en-us/windows-vista/What-to-do-if-you-forget-your-Windows-password
- or if anything else didn't work you can use thrid party software from Hiren's Boot CD http://www.hirensbootcd.org/download/Hirens.BootCD.12.0.zip
Dec 01, 2010 | Acer Aspire One PC Notebook
Reset Bios Password
At command prompt type debug
you will get a - prompt where you can type the fallowing (<enter> means hit enter, not type enter*)
A <ENTER>
MOV AX,0 <ENTER>
MOV AX,CX <ENTER>
OUT 70,AL <ENTER>
MOV AX,0 <ENTER>
OUT 71,AL <ENTER>
INC CX <ENTER>
CMP CX,100 <ENTER>
JB 103 <ENTER>
INT 20 <ENTER>
<ENTER> just hit enter on this line
G <ENTER>
Q <ENTER>
Basic BIOS password crack - works 9.9 times out of ten
This is a password hack but it clears the BIOS such that the next time you start the PC, the CMOS does not ask for any password. Now if you are able to bring the DOS prompt up, then you will be able to change the BIOS setting to the default. To clear the CMOS do the following:
Get DOS prompt and type:
DEBUG hit enter
-o 70 2e hit enter
-o 71 ff hit enter
-q hit enter
exit hit enter
Restart the computer. It works on most versions of the AWARD BIOS.
Flashing BIOS via software
If you have access to the computer when it's turned on, you could try one of those programs that remove the password from the BIOS, by invalidating its memory.
However, it might happen you don't have one of those programs when you have access to the computer, so you'd better learn how to do manually what they do. You can reset the BIOS to its default values using the MS-DOS tool DEBUG (type DEBUG at the command prompt. You'd better do it in pure MS-DOS mode, not from a MS-DOS shell window in Windows). Once you are in the debug environment enter the following commands:
AMI/AWARD BIOS
O 70 17
O 71 17
Q
PHOENIX BIOS
O 70 FF
O 71 17
Q
GENERIC
Invalidates CMOS RAM.
Should work on all AT motherboards
(XT motherboards don't have CMOS)
O 70 2E
O 71 FF
Q
Note that the first letter is a "O" not the number "0". The numbers which follow are two bytes in hex format.
Using the jumpers
The canonical way to flash the BIOS via hardware is to plug, unplug, or switch a jumper on the motherboard (for "switching a jumper" I mean that you find a jumper that joins the central pin and a side pin of a group of three pins, you should then unplug the jumper and then plug it to the central pin and to the pin on the opposite side, so if the jumper is normally on position 1-2, you have to put it on position 2-3, or vice versa). This jumper is not always located near to the BIOS, but could be anywhere on the motherboard.
To find the correct jumper you should read the motherboard's manual.
Once you've located the correct jumper, switch it (or plug or unplug it, depending from what the manual says) while the computer is turned OFF. Wait a couple of seconds then put the jumper back to its original position. In some motherboards it may happen that the computer will automatically turn itself on, after flashing the BIOS. In this case, turn it off, and put the jumper back to its original position, then turn it on again. Other motherboards require you turn the computer on for a few seconds to flash the BIOS.
If you don't have the motherboard's manual, you'll have to "brute force" it... trying out all the jumpers. In this case, try first the isolated ones (not in a group), the ones near to the BIOS, and the ones you can switch (as I explained before). If all them fail, try all the others. However, you must modify the status of only one jumper per attempt, otherwise you could damage the motherboard (since you don't know what the jumper you modified is actually meant for). If the password request screen still appear, try another one.
If after flashing the BIOS, the computer won't boot when you turn it on, turn it off, and wait some seconds before to retry.
Jul 07, 2010 | Gateway NV5215u Notebook
HP Compaq nc6320 Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
