Question about Linksys Ultra RangePlus Wireless Routr Router
Hooking up a Linksys dual range router to a 2 Wire cable modem
I recently purchased a Liksys dual range router that is designed for gaming and media transfer to go along with the Linksys Media Center Extender that I bought. The 2 Wire modem that I have is a cable modem that hooks up to my 2 desktops in the house wirelessly. It is my understanding that I have to hook up to the modem with an ethernet cable directly to my computer so the software that came with the router can preform the appropriate test to see if the internet connection will work. When I plug a wire into the back of the modem there is no connection to the internet. What am I doing wrong. I called AT&T tech support but they told me they can't help me even thought they supplied the modem, because it is a 2 Wire product and not their equipment.
2nd, the desktop that I want to extend my media center to living room from is in another room away from the router and modem. Once the internet connection is resolved will I be able to connect to the modem and the router wirelessly, or does the router need to be wired to that specific desktop.
  • Chuck May 11, 2010
    if your 2 wire modem is wireless and has 2 ports do you need the Linksys router as well there? If not then put the linksys router in the other room with the desktop (media center). But before you can connect wirelessly you must go into the configuration pages and set all your wireless id's and such as well as the security settings and all have to be the same as the 2 port modem.
    you stated this The 2 Wire modem that I have is a cable modem that hooks up to my 2 desktops
    what is this modem model #. if it is wireless all you need is a bridge or access point the router you have will work but just overkill that is if you modem is wireless.
  • 496 Answers
Ok once your internet is resolved you shouldnt need to have any computer hard wired to the router but it should go like this cable from your wall to the modem, then cable from modem to the router, after that you can go wireless all the way just make sure that its all secure and encrypted dont want the next door neighbor stealin your internet
Posted on Oct 01, 2009
3 Suggested Answers
SOURCE: WRT54GS V6
leave the wireless router settings unsecured then place the range expander as near as possible to the router. press autoconfig buttons and observe the lights...
Posted on Jan 17, 2008
  • 59 Answers
SOURCE: how can i configure Linksys Wireless range extender
hi ,
i went through the problem ur facing and the only solution that comes into my mind is that u will have to do the wireless settings on the router and copy the same settings on the range expander as well .... no changes.... and do remember that range expander at that time should be connected to the router at that time with the help of an ethrnet cable .....
ity would be working like a horse then ...
Posted on Oct 25, 2008
Problem cannot to i-cable router
Power off Cable Modem, PC, router, and then disconnected them. Directly connected Cable Modem with PC (Don't connect the router) and power on Cable Modem. When Cable Modem is ready with LED lamps under normal status, also power on PC and try to access Internet service. If Internet service is resumed, please study the router setting of Cable Modem which referred to router's user manual.
Apr 21, 2013 | Linksys by Cisco Linksys EA6500 Smart...
I have to internet subscription.I connected it to the router but when i tried to connect the router to my laptop, i cant browse to any site (internet connection is very ok).
The router that you have is a Dual-Wan router, specifically designed for hooking up 2 cable modems at the same time to the same router. If you do not have such a set-up I would recommend purchasing a Netgear Wireless-N router for $40 at Walmart, or any store really. The Dual Wan routers can be finicky at times, and is overkill for any normal use of internet bandwidth.
May 17, 2011 | D-Link DI-LB604 Router (DILB604)
I'm having problems not only with registration but also connecting the router.
Kindly follow the below steps to setup your router, this will help
LinkSys Router Setup Physical Setup of a LinkSys Router Each model of LinkSys router will differ slightly, but the general design is similar across all models. Therefore, the setup is similar across all models.
  1. Attach the antennas to the router (if your LinkSys router support wireless)d
  2. Plug the Ethernet cable from your broadband Internet provider into the port labeled "Internet"
  3. Plug another Ethernet cable into one of the available ports
  4. Plug the other end of that same cable into an Ethernet port on your PC
LinkSys Router Configuration LinkSys routers now ship with a Setup Wizard which is intended to simplfy basic configuration tasks.
We do not recommend the LinkSys Setup Wizard for two reasons:
  1. The Setup Wizard is not significantly easier that the regular configuration menus
  2. If you use the Setup Wizard, you will end up learning two interfaces for your LikSys router instead of just one
Instead, we recommend simply starting your web browser and jumping into the configuration.
Once your web browser is open, go to the URL http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password.
Logging in to a LinkSys Router
The username is either blank or "admin" and the default password is "admin".
Once you are past the login screen, you are able to access (and change) a plethora of configuration options for your router.
Don't be worried by the enormous number and variety of options, your LinkSys router ships with default settings that enable it to work right out of the box in most environments.
From here the configuration options that you choose are largely up to your own personal preference.
If this is a wireless router, we recommend that you consider setting an SSID to identify the router as your own and configuring WEP to encrypt your wireless traffic.
Let me know if this will help
Regards
I can provide you more on Linksys router as i work on them :)
All the best
Nov 29, 2009 | Linksys Wireless-G Broadband Router
I have broadband cable service. My cable modem ic connected to a Linksys Dual band wireless router. My computer is then connected to the wireless router on USB port 2. My Link sys VOIP is connected to the...
First unplug your router, then unplug your modem and for 10 seconds. Next plug the modem back in and wait it to reboot(on mine this a series of 4 lights that light up in sequence, when the 4th light stops flashing, reboot is complete). Finally plug your router back in.
Sep 09, 2009 | Linksys Ultra RangePlus Dual-Band...
Hooking up the linksys wrt54gv8 to my modem
grab the cable that goes out from your modem (the network cable) and connect it to the "Internet" input at the back of the modem
Aug 27, 2009 | Linksys Wireless-G WRT54G Router
I've connected the cat 5 wire from my cable modem to the linksys cable router with 8 ports but it does not give access to the internet on the other computers that are networked. If I let it find an...
hey, you need to create bridge between your cable modem and router and you need to give one static IP in the router. kindly note you need to keep cable modem and router in the same class eg-( cable modem ip is 192.168.1.2 then router should be the same range.) and provide gateway of your ISP in the router.
Jun 09, 2009 | Arris SURFboard SB5120 Modem
Reseting "Bridge mode" in RCA DCM 305R cabel modem
you can't set teh modem to bridge mode, however, you can set the router to bridge.
The linksys should have bridge mode configuration in the uer guide.
connected the 2 router together
configure the IP address of the liksys to be inthe same subnet as the moem, but out of the range of the DHCP of the modem. ie. DHCP address 192.168.0.2 through 192.169.0.100, the linksys should have the IP address as 192.168.0.200
disable the DHCP on the linksys
setup the wirless just the way you would if ti was the modem.
connect from the modem LAN port to the LAN port on thelinksys. leave the WAN port open.
Dec 30, 2008 | RCA Thomson Digital Cable Modem (DCM305R)
Setting Up a Wireless Network
You can still use your existing Linksys router with your cable modem. In fact the router your have is designed to work with DSL/Cable Broadband connections.
1. Make sure to properly connec the devices in your network. Modem will be connected to the Internet port of the router. Then, laptop will be connected to one of the 4 Ethernet ports of the router. For initial setup of your router with modem, you need to hardwire laptop to the router.
2. Press and hold reset at the back of the router for about 15 seconds.
3. After 15 seconds turn off the router and then turn off the modem. Wait for a minute.
4. Power on modem and wait for the lights to be ready.
5. When modem lights are on, turn on router.
6. There should be 4 lights on. Power should be steady green. Internet, WLAN and Ethernet port.
7. Checked if you have Internet connectivity on your laptop while it is wired to the router.
8. If Internet is working, disconnect laptop from wired connection to the router and check available wireless network that laptop can detect.
9. The default wireless network name that the Linksys router broadcasts is "linksys". Connect to it which is an unsecured wireless network.
10. Once you are successfully connected, check Internet.
Hope this helps!
Nov 16, 2008 | Linksys Wireless-G Broadband Router
No internet signal between router and desktop pc.
have you plugged everything in with the modem off and the router off?
have you tried unplugging the linksys for a sec then plug it back in?
also have you checked the pin connection on the plug on both the computer and the router?
what are the lights indicating?
Oct 14, 2008 | Computers & Internet
Linksys Ultra RangePlus Wireless Routr Router Logo
680 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
