Question about ElectroVoice PA2400T Amplifier
I have boss amplifier can i use flush speakers of any other brand
I want to install new 16 flush speakers in two halls but amplifier is of boss with 300 w output. can i use any other brand of speakers or i must opt for boss brand
    New Friend:
    Problem Solver:
  • 5 Answers
According to my view you need at least 2600w amplifier to install 16 flush speakers with multiple port. To know more visit http://www.couponsbag.in/flipkart.com here you get complete installation technique and all latest amplifier.
Posted on Aug 08, 2014
Thanks for the info [IMG]http://couponsindia.net/imgs/signature_smiley.jpg[/IMG]
Posted on Apr 12, 2012
  • angel_talks
    angel_talks Apr 12, 2012
    thanks for the info http://couponsindia.net/imgs/signature_s...'>
    Genius:
  • 1,175 Answers
Hi....
You can use any brand but you need to be careful about how you connect the speakers....Say if theyre 8 ohms and you put 2 in parallel
then they equal 4 ohms etc.
If you put two 8 ohm in series they'll equal 16 ohms.
I would go to EV's website for more on speaker connections
Posted on Feb 25, 2009
What is the impedence rating for Boss BV9354?
Basically almost all aftermarket decks are 4 ohm. It is the standard for aftermarket audio.
Mar 08, 2012 | BOSS AUDIO SYSTEMS Car Audio & Video
How to assemble boss sub woofer,any?
If you have already bought the subwoofer, you will need to buy an enclosure for it. As well, you will need an amplifier and a compatible receiver for the amplifier.
Once you have all of these components, you will need to wire them all together. For this, you will need a pair of RCA cables to run from the receiver to your amplifier, a power wire to run from your amplifier to your battery, and wire running from your amplifier to your enclosure/subwoofer.
For a more in-depth tutorial on how to install your subwoofer, check here:
http://www.wikihow.com/Install-Subwoofers
Mar 01, 2011 | Boss R12 Riot Series Subwoofers (12 ;...
Power in no sound out
ALWAYS CHECK UR FUSES FIRST AND FOR MOST
Feb 10, 2010 | Boss AUDIO SYSTEMS CX250 Car Audio...
Hi, i would like to know if Boss is a good brand amp for my truck
it is ok. These amps are cheaper and are meant for use with lower quality speakers. So they do work but I would expect alot from it.
Oct 10, 2009 | Boss Riot 2500D Car Audio Amplifier
Boss audio
Either the radio is bad out of the box (Very possible with the BOSS brand) or you car has factory amplifiers that need to be turned on. This is aaauming ther sound system played prior to the installation of the new radio. Most vehicles you can power up the amplifiers simply by connecting the BLUE remote turn on wire in the harness, but can get tricky in some vehicles.
Post the year make, and model of your car, and I can shoot you some odds/info about factory amplifiers.
Aug 07, 2009 | Pioneer DEQ-7600 15-Band Car Equalizer
Why would i spend a 100 to 120 dollars on a car amp?
any amp will work with any speaker, you just need to make sure it is a mono amp if you are running 1 speaker and a stereo amp wither 2 or 4 channel if you are running 2 or 4 speakers, the ohm rating on the amp should match the speakers also, on the back of the speaker it has the ohm rating, most will be 8 ohm, but you still find some 4 ohm, depending on the speaker if it has a lot of throw (the in and out movement) you may want a higher wattage amp so you get clean sound, it is up to you.... if you are installing lower price amps to you may hear engine wine or noise while car is running so a grounde loop isolator installed on the system will remedy that... also with the amp the directions will tell you the ohm rating of the wire to use, follow that.... and keep the ground short and clean where ever you put it.. try not to go directly off the battery cause you will get a lot of noise... hope this helps..
Jun 23, 2009 | Pyle 2 Channel 4000 Watt High Power MOSFET...
Speaker amplifier calculation
for $85 i can sell you an Almani 900 watt 2 channel amp i would stay way away from those 3 brands they are all really poor quality and i can get you any major name brand cheaper.
I can get you a hifonics 4008 amp (800 watts peak 100 watts per channel rms) for $100 shipped with full factory warranty. you find an amp you like and i will get you a price. I am a factory wholesale distributor for most brands.
Jan 08, 2009 | Legacy 2 Channel 1600 Watt Bridgeable...
How do i hook up the speakers
connect each dual in series then parallel each sub
Sep 08, 2008 | Boss IQ 3KD.1 Car Audio Amplifier
How to hook up 2 10 inch speakers
For best results the output resistance of the amplifier must equal the combined resistance of the speakers. So if the amps says 8 ohms and you have two 4 ohm speakers you put them is series or if the amps says 4ohms and you have two 8 ohm speakers put them in series. If it says 4ohm and you have two 4 ohm speakers best to use only one. It Depends on the output resistance of the amps. It is usually written at the terminals where the speakers are connected.
ElectroVoice PA2400T Amplifier Logo
130 people viewed this question
Top ElectroVoice Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
 Grubhead
Grubhead
Are you an ElectroVoice Audio Player and Recorder Expert? Answer questions, earn points and help others
