Question about Konica Minolta PagePro 1350W Laser Printer
Printer error keeps flashing and I can't print any documents
  • KIAAAL Mar 26, 2009
    Occasionally had this problem when running under W98SE, but much worse under VISTA. I did two things: re-installed using the mfg. disk and changing the parallel cable. I was trying many things, so am not sure what helped. But you might try those.
I had the same problem on my laptop. I changed USB port and it solved the problem.
Posted on Apr 16, 2009
HP Deskjet 5650 - Troubleshooter keeps saying paper is low or out.
How to use the solutions in this document To resolve the issue, try each solution in this document, and then use the steps in this section to print a self-test report. This step determines if the product hardware functions correctly. When you have resolved the issue, and the product successfully prints a self-test report, there is no need to continue troubleshooting. Print a self-test page Follow these steps to print a self-test report.
  1. Load plain paper in the paper tray.
  2. Press the Power button (c01602202.gif ) to turn on the product.
  3. Press and hold the Power button (c01602202.gif ).
  4. Press the Resume button (c01678098.gif ) four times. The self-test page prints.
c01733891.gif IMPORTANT : Try to print a self-test report after every solution even if the solution resolves the issue.
Mar 28, 2013 | HP DeskJet 5650 InkJet Printer
NOT PRINTING, ERROR KEEPS FLASHING
Turn off the printer, reconnect the power plug and clear the waiting documents to be printed in the printer task manager.
Dec 18, 2009 | Citizen CBM 1000 thermal Printer
Canon IP3000 fault
Here are a couple of documents related to your problem (appears to be a print head error);
Error code synopsis;
www.decopac.com/resources/PDFs/iP3000%20Error%20Codes.pdf
Full product manual;
www.soft-manufaktura.ru/manual/hp/iP3000sm.pdf
Doesnt look terminal, at worst may need to replace the Print Head.
Hope this helps.
Dec 09, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Error light keeps on flashing blue light at the
These are your possibilities based on your error.
Front cover is open
Close the front cover of the printer.
Fuser cover is open
Close the fuser cover located behind the back cover of the printer.
Paper jam
Clear the paper jam. See Paper jams and how to clear them on page 85. If the printer
does not start printing, press the Go button.
Memory full
The printer memory is full and the printer cannot print full pages of a document. See
Solving print problems on page 97.
Print overrun
A print overrun occurred and the printer cannot print full pages of a document. See
Jun 14, 2009 | Brother HL-2170W Laser Printer
Error flashes
I've read several posts on the "red flashing error light" on the Brother HL-2170W. I have mine hooked to a mac - but I'm sure the pc is the same way. One other previous post said look for a paper jam. Well, there are only a few places to look...and I found no paper jam UNTIL I removed the toner cartridge and looked UNDER the cartridge and VOILA, there was a paper jammed underneath. I removed it and I'm back in business. Normally paper jams when it is almost out of the printer and you can locate it by opening the back of the printer. Well, this one was "sneaky" and hid completely underneath the toner cartridge.
Hope this helps someone else...
May 25, 2009 | Brother HL-2170W Laser Printer
Document wont print
It could be a hardware issue.
Check first if the printer is working fine. Keep on holding down the paper button while you turn the printer on. Let go of the paper button when the power light starts to flash. if it printed out a color test pattern successfully, check if you are using the corrrect driver.
Tell me more if you need assistance in trashing and re-installing the proper driver for your printer. Include the full version of the operating system you are using too.
Goodluck.
sherlyn c.
May 23, 2009 | Epson Stylus C66 Photo InkJet Printer
Printer light blinking
Customer Support SUPPORT"; //--> print.jpg Print | email.jpg Email | --> pagelink.jpg Link null.gif KnowledgeBase 433-75x75.gif Product
Product
--> Lexmark Z615 Country / Region:
Country / Region:
--> United States Language:
--> Language:
English Need to download
a driver?
--> Save my information--> Lights Flashing on the Lexmark Z815/ Z816 Color Jetprinter ID: ENUS17112 This document does not apply directly to your Lexmark Z615
  1. First count the number of times the light on the front of your printer flashes.
  2. Then refer to the table below for information about the error condition and recommended recovery procedures.
    Number of Flashes Error Condition Error Recovery 2 Carrier Stall:
    The movement of the print cartridge carrier has been obstructed. Remove any objects blocking the carrier path.
    4 Print Incomplete:
    The print cartridge carrier stopped in the middle of a print job due to obstruction. Remove any objects blocking the carrier path.
    12 Cartridge Short:
    The printer has detected a short circuit in a cartridge.
    1. Turn the printer off.
    2. Open the front cover.
    3. Turn the printer back on.
    4. Remove the color cartridge.
    5. Close the cover. If there are no flashing lights, the color cartridge is short-circuited.
    6. Remove the black cartridge and then reinsert the color cartridge.
    7. If there is no error indicated by flashing lights, the black cartridge is short-circuited.
    8. If you continue to receive an error indicated by flashing lights, both cartridges are short-circuited.
Apr 22, 2009 | Lexmark Z640 InkJet Printer
Dell printer 1700
First unplug power cord and plug back after 10 mins.
If problem persists, then it is probably a toner error, if the toner is nearly finished. In this case you will see the led flashing only when is printing. Sooner or later the printer will start printing blank or faded pages and you will need to change toner
When is not toner, with same symptoms as above, it can be drum error, in this case printer will keep printing but shows flashing light, at a certain point you will need to change drum kit.
If light flashes and printer does not print, then it is either paper jam inside, or one of errors above at final stage, or one of the door not well closed (check them all), or printer faulty (fuser, heads mechanics etc.), in this last case call service.
Mar 21, 2008 | Dell 1700n Laser Printer
Printing Dillema
Flashing resume light also can mean:
1. cartridge is missing or an incorrect print cartridge is installed
2. cartridge is out of ink
3. dirty cartridge contacts
4. paper jammed
Check are cartridges firmly snapped into place and not empty. Use water to wash copper on cartridges if contacts are dirty.
Oct 30, 2006 | HP DeskJet 690c plus InkJet Printer
Konica Minolta PagePro 1350W Laser Printer Logo
165 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
