Help please... I have this camera that always have a message says "memory card error please check the card", I check the white tab on the card and it is unlocked and I tried another card. It never seem to work could some one help me?
SOURCE: I have a Panasonic DMC
I think the problem may bethat you are using a 4Gb card. The manual says not to use a card larger than 2Gb.
SOURCE: bought 8gb memory card - error message
Hi, I suspect that the SD card is to big for that camera as that camera is a lower end camera. You should try the SD card in a camera that is known to be able to handle such a huge card.
SOURCE: sandisk sdhc 4gb memory card wont work with my
You need to format the card in the camera to optimize it.
SOURCE: My Lumix DMC-FS5 camera had locked memory card,
Move the slide switch on the side of the card.
SOURCE: can't access photos
Insert the card...go into the menu and scroll to "copy". Follow the directions for copying the internal memory to the memory card.
Testimonial: "life saver! cheers mate! great help! x"
