Question about Canon IMAGERUNNER 6570 Copier
Replace Waiste Toner Container
Where is the container and do I have to buy a new one or just empty it our?? I have the Canon imageRunner 2220
    Sergeant:
  • 199 Answers
Replace Waiste Toner Container - 8c7d4fb.gif just empty waster toner container located in the front side of the copier
Posted on Feb 26, 2009
Our Canon ImageRunner 400S says to replace the waste toner container. However, I can't find in the manual how to do that.
Waste toner is located in drum unit, look for any cork on drum unit assy, open it, and empty waste toner.
Aug 03, 2010 | Canon imageRUNNER 400S Copier
Canon 210 S Message says to replace waste toner container - Where is it?
The waste toner is inside the drum unit it self. You can empty it out, but it is very messy. If it is full, you most likely will need a new drum unit soon. It is up to you.... Good Luck
Jun 03, 2010 | Canon imageRUNNER 210S Copier
THE WASTE TONER CONTAINER IS EMPTY BUT IT STILL KEEP SAYING TO REPLACE AND WONT PRINT
There is a sensor that registers the presence of toner in the plastic container. Remove the container and blow out the sensor. Also, the container has a plastic window that can get dirty with toner - clean the container and the plastic window which is part of the container head and screws into the container body. It is better to unscrew carefully and clean with soap and water. Allow to dry properly.
you can also get the service manual to help with future errors and the like from the link below but first try my suggestion:
Canon Service Manual
May 28, 2010 | Canon imageRUNNER C3200 Copier
Where is the waste toner container located and how do I replace it on the Canon 4570 imagerunner copier?
Remove the two screws that hold the front cover on. The waist toner is below the toner container.
May 18, 2010 | Canon imageRUNNER 4570 Copier
How do i replace the waste toner container on a Canon Imagerunner 4570?
The waste toner bottle is hidden behind the front cover of the machine. Just under where you fit the toner cartridge.
If you are competant with a screwdriver, remove this cover and you will find the Waste container. The screws for the cover are hidden behind a rubber bung.
Feb 02, 2010 | Canon imageRUNNER 4570 Copier
Canon ir 2016 problem E019
Product : imageRUNNER 2200/2800/3300(i)/2220N(i)/3320N(i) Title : E019
Error :
E019-0000 is displayed on the control panel.
Workaround :
This error code is the indication of the waste toner container being full or a problem with the detection mechanism. Actions to be taken are:1. Turn the machine off and check the waste toner container. If the container is full, empty the container. Clean the inside and outside of the container's neck with alcohol. Be sure that the neck is clear and not soiled with toner before placing it back into the machine. Turn the machine on and check to see if the code went away.
2. If the container isempty and the code is still displayed, check the neck of the container. Turn the machine off and check the container,if the neck is dirty, clean the inside and outside with alcohol before placing it back into the machine. Turn the machine on and check to see if the code went away.
3. If the machine still displays the code after the bottle is emptied and the neck clean; check the sensor, the sensor connections to and from the DC controller PCB for continuity, and the proper positioning of the sensor. Replace the sensor if it is damaged or excessively soiled with toner.
Apr 26, 2009 | Canon imageRUNNER 2000 Copier
Canon Imagerunner C3100
If you open the front door,the plastic container in front is the waste toner container .Remove that bottle and dump all that toner.Make sure the neck of the container is free from toner inside and outside.And put the container back in it's place.
Mar 29, 2009 | Canon imageRunner C3100 Copier
Where is the waste toner container in a Canon 5020i?
ok on the right side of the copier lower right cover 2 screws pakes the panel off behind it is a large plastic bottle pull it out empty it put it back in. then in this order touch these keys... add func// 2 & 8 at same time / then add func again screen should change to serv mode.. then in this order touch copier / counter / misc/ waste toner / clear /ok turn off and on good luck
Jan 02, 2009 | Canon imageRUNNER 5020i Copier
Waste toner container on canon imagerunner 330s
It is located below like a small box/ press beside the box to release /
www.justmanuals.com
Jan 10, 2008 | Baby Gear
Waste Toner Container
You must take off the back panel of the copier and you will see a box sitting on the bottom. You can empty it and should be ok
Apr 10, 2007 | Canon imageRUNNER 6020I Copier
199 people viewed this question
old marine
old marine
