Question about Xerox DocuColor 12 Color Copier
Cant machine to do any thing it powers up and thats it
I have a dc40 pro and it says falut number 6-240
    Scholar:
  • 136 Answers
You have error in the " Optics" section of this copier, anytime you get an Error that starts with a 6 then the number means you have an error in the optics, which means your scanner isn't moving or the carriage isn't finding the home position or is not moving at all, If you don't know what your doing then don't screw with it call an independant guy who fixes Xerox's your going to pay an arm and a leg if you don't have a service contract with Xerox.
Posted on Mar 05, 2009
The floor brush on my dyson DC40. As come unscrewed om ome side I've tried screwing it back in but it won't stay in
The plastic it screws into is stripped. Fill the hole with quick set Epoxy and install the screw before it set completely..
Oct 11, 2016 | Dyson DC40 Multi-floor Vacuum DC40
Hi, My attachment extension hose has lost suction. Help!
Hello, this is Ava with Think Crucial.
There could be a number of reasons why your hose has lost it suction. It could be that the hose is damage. If not, then you may want to check the hose for any blockages and make sure the the hose is fitted correctly at the machine. You may also want to check the inside of your u-bend cover for any blockages. Please make sure to unplug your machine from the power before doing this.
Incase your parts needs replacing, you may order replacement parts for your Dyson vacuum by clicking on this link: http://www.thinkcrucial.com/collections/vacuums/collection-filter-fits-vacuum-dyson
As a special offer here is an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Think Crucial Customer Care
Oct 01, 2016 | Dyson DC40 Multi-floor Vacuum DC40
My Dyson works perfectly well with the base plate. As soon as i use the hose part it tends to loose all power and i cant even stretch the hose properlu
The hose is blocked, so you have very little suction at the end. The vacuum in the hose is pulling the hose shorter. With the vacuum turned off, push a broom handle through the hose to dislodge the blockage.
May 11, 2016 | Dyson DC40 Multi-floor Vacuum DC40
How to replace the reset button on a dc40
Hi Raymond, it's Jack at Dyson.
DC40 doesn't actually have a separate reset button, as the brush bar reset mechanism is built into the on/off and brush control switches on the machine's upper body. If possible can you confirm exactly which machine you have, and which part you're trying to replace?
Alternatively if you'd prefer, you're welcome to contact our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Oct 31, 2014 | Dyson DC40 Multi-floor Vacuum DC40
My dyson dc40 stays upright, i cant get it to go down..can you advise?
Hi there, it's Jack at Dyson.
If your DC40 won't recline into the normal vacuuming position, it's likely an object has been accidentally vacuumed up and is jamming the internal changeover valve. Our video guide shows how to check for and resolve this:
I'm confident this will get your machine up and running again, but if you'd like some further help from our experts after giving this a try, please call us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Sep 29, 2014 | Dyson DC40 Multi-floor Vacuum DC40
MY DYSON DC40 VACUUM DRUM WILL NOT SPIN.. NOT GETTING FULL POWER
Please be assured it's normal for the dust and debris inside your DC40's clear bin not to spin. In fact in the bin base you'll notice 4 ribs, known as 'baffles'. These are engineered to catch the debris and force it to settle at the bottom of the bin. This helps to keep the debris out of the airflow, which can then pass through the mesh shroud and into the cluster of smaller cyclones where the finest dust particles are captured.
However, if your DC40 doesn't seem to be picking up as well as it should be, this is likely to be easy to resolve. Our online Support guide will walk you through each troubleshooting step: http://www.dyson.co.uk/support/dc40/dc40-animal/my-machine-is-not-working/machine-not-sucking-up-well
If you haven't washed your DC40's filters recently, this should also be done. DC40 has 2 filters engineered to last the lifetime of the vacuum, and these should be washed at least once a month. Use cold water without detergent, and allow both filters to dry completely for at least 24 hours before replacing them.
This should help restore full performance to your DC40. However, our experts are on hand to help if you have any further questions, and you can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Aug 11, 2014 | Dyson Vacuums
Dc40 back wheels keep engaging
DC40's stabiliser assembly is engineered to retract automatically when you lower the machine into the vacuuming position. When you stand the vacuum upright after use, the wheels will extend and lock into place to support the machine. You'll hear a click as the machine locks upright. This is shown in the image below.
I'm not quite sure from the details you've provided when you feel the wheels seem to be engaging incorrectly, but I would encourage you to get in touch with our experts directly so we can take some further details.
You can reach us by calling the Dyson customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1800 239 766 (AU).
Feb 01, 2014 | Dyson DC40 Multi-floor Vacuum DC40
Not sucking strongly enough
Hi Neil, it's Jack at Dyson.
If your DC40 isn't picking up as well as it should be, it's likely there will be a blockage that you may have missed. The most effective way to check for this is to follow the steps shown in our online Support guide: http://www.dyson.co.uk/support/dc40/dc40-multi-floor-complete/my-machine-is-not-working/machine-not-sucking-up-well/both-checks-checking-wand-and-hose-step-1
We'd also recommend washing both filters, which should be done at least once a month in normal use - the video attached should help. Use cold water without detergent, and allow at least 24 hours for them to dry before replacing them.
If you'd like some further help after you've given this a try, please call our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Jan 05, 2014 | Dyson DC40 Multi-floor Vacuum DC40
Xerox DocuColor 12 Color Copier Logo
75 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
