Question about E-Machines EMA IMPERIAL GV (845GV) TG3 eMachines (145119) Motherboard
Battery runs down
After installing new battery whin 1 month it begins to run down and time is off again had battery checked for max power 1st and installed. this is the 2nd battery i've tried same thing. is my motherboard shorted? james
    Problem Solver:
  • 5 Answers
In this case the battery is not getting recharged current so please check out the connections and reinsert all the available connectors ur problem will be surely be solved
Posted on Feb 25, 2009
Why is my nikon coolpix L20 battery exhausted even with new batteries
If you are using rechargeable batteries, It could be that your camera's battery charger circuit is defective. If your camera is out of warranty, the cheap solution would be to buy an external charger. Another possibility is that a short circuit or defective electronic component is drawing excessive current and draining your batteries. If that is the case, you will need to have your camera repaired. Nikon USA Repair Depot's number is 1-800-645-6687 9AM-8PM EST, Monday to Friday. They will tell you how to return your camera for repair and they will give you a free estimate if it is out of warranty.
Sep 01, 2014 | Nikon COOLPIX L20 Digital Camera
Mower runs new battery down then wont start again unless jumped.
Sounds like you have a problem with a regulator. Hard to tell without knowing what model of mower you own. You must remember that whatever is attached to your battery charges it while the motor is running. If the battery does not receive that needed charge, running the motor will certainly drain your battery.
Apr 17, 2013 | Garden
When i turn my steering wheel it makes an awful whinning sound. The first time this happened i put Lucas stop leak power steering fluid in and it stopped. that was mayb a month ago, and now it's doing...
You have a leak somewhere.. If filling the pump does not stop the noise then the pump is going bad. Be sure the leak is at the pump before you change the pump or else the new pump might go bad as well from being low on fluid.
Its likely that filling the pump back up should stop the noise though unless you have run it a while its empty.
Sep 14, 2011 | 2000 Pontiac Grand Am GT
Car does not like to start after it's been driven. When turning the key it will just click 4 or 5 times and than turn over very slowly. We replaced the battery as it was only at 6 volts when under a...
Offhand I would say you have a problem with the charging system instead of the battery itself. Check the voltage at the battery terminals without the engine running (it doesn't matter if the key is on or off), you should be reading around 12 volts with a good battery, and again with the engine running. With the engine running you should read somewhere around 13 1/2 to 14 1/2 volts. If not, then you probably need to replace the alternator. The reason it worked with the new battery is that it was fully charged to begin with and it took about a week to run it down to where it would not run the starter again.
Jul 15, 2011 | 1998 Chevrolet Malibu
Battery won't fully charge. Max charge seems to be slowly going down. First noticed charging light coming on intermittently but battery only reached about 93%. 4 days later and the max charging seems to...
It seems that the issues is with the battery itself, not the cppu.
To double check, you can do the following:
1. Disconnect adapter and run battery completely dead.
2. Reconnect adapter and let charge for at leasst 12 hours OR until battery displays 100% charge.
If it still won't charge to 100%, then you know for sure the battery is defective/worn out..
If you want to know more about this, look on wikipedia for: "Laptop Battery Lifespan" or "Laptop Battery Memory Charging".
But I'd say it's safe to assume that it's time for a new replacement battery for your Notebook PC.
Hope this helps!
Apr 14, 2011 | Gateway E-475M Notebook
Air pump on 2000 Jimmy
Maybe time to get warranty to fix the underlying issue.
May 28, 2017 | 2004 GMC Envoy
Dell Dim 8400 Issues
Hi Steve,
The problem that you are facing is most likely because of bad harddrive. As you have already replaced the RAM. To confim the same , run a diagnostics on the Hardrive. You can run the same in two ways .
Check if have the utilitu partision still left on the hardrive
1. Tap on the F12 key 5 - 6 times when you see the Dell splash screen , before windows starts to load.
2. Select Hardrive diagnostics or IDE diagnostics
If the above is no there , look for the dell Rescouce cd
1. Boot the system using the dell Resource Cd.
2. Select 32 bit diagnostics from the menu
3. Run a custom test on the hdd.
If the hardrive fails , replace the same, otherwise try swaping it connector cable with the optical cable.
Thanks
Proton
Oct 11, 2008 | Dell Dimension 8400 power supply ** FREE...
DUST BUSTER 7.2 POWER LASTS FOR UNDER ONE MINUTE??
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=859375
Generic problem for all Vacuums
Posted by bettedxx on July 31, 2008
DUST BUSTER 7.2 -- POWER LASTS FOR UNDER ONE MINUTE??
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The problem that people have with dustbusters is that when they 1st get them they need to say train the dustbusters to extend the battery life, the process is simple – when you 1st buy the dustbuster then you charge it up the 1st time and then you turn it on and drain the battery down to nothing, and then recharge the dustbusters again, and by doing that you have a larger battery life and it will run longer – but dustbuster and vacuums like that do not tell you and when people buy the item they just turn it on for a minute or two and then the battery does not get a “memory” as per how long it should run. By doing this the dustbuster will last and run longer and will have fewer problems. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 31, 2008 | Vacuums
Battery Problem
You need to begin using rechargeable batteries immediately. Look for nickle metal hydride (NiMH) cells that are at least 1800 mah and preferrably more than 2000 mah. Get two sets and a charger. Print this and take it with you. You can buy these at any electronics store. You'll need to charge the batteries before you can use them. And they don't really give you full life until they've been charged and discharged a couple of times. In other words, the first few times, you'll get a shorter life cycle before they run down. But you should see a marked improvement almost immediately.
Sep 13, 2005 | Sigma SD9 Digital Camera
Computers & Internet Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
