Question about Kenmore 46462 Front Load Washer
Under counter dishwasher door "squeaks".
Would like to eliminate loud squeaking noise associated with the hinges of my dishwasher. Have tried forced air cleaning of hinges and application of "Houdini" with little success. Perhaps I have to be able to remove the door in order to clean the hinges properly before applying the right lubricant (whatever is recommended). I'm baffled at this stage.
  • Anonymous May 09, 2009
    kenmore model #665 door squeaks
  • 117 Answers
The door hinges will have to be replaced. They have been updated to prevent this. Read about it here and good luck.
btw I have used Vaseline applied to the cables to eliminate this issue.
http://www.servicematters.com/docs/doc_main.htm
http://tclaundryrepair.com/
Posted on Feb 25, 2009
How to stop a squeaky door
Spray a little wet type contact cleaner or WD40 onto the hinges.
Apr 25, 2014 | Vehicle Parts & Accessories
Bottom of door makes loud squeaking on opening. I can't figure out how to lubricate. I'm wondering if removing the plastic molding on the bottom inside of the door would allow me access.
Yes by removing the inner door liner from the outer door panel you should be able to gain access to the door hinges,between the part of the hinge on the door and the hinge part on the tub is a plastic bushing that probably worn causing that sqeeking noise.
GENE
Oct 15, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Back door makes terrible squeaking noise when
When you open your door you will see a flat bar that slides into the door while opening and closing. It is located between the two door hinges. There is a rubber on the door where the flat bar slides in and out, remove that rubber and you will see little rollers in the door, those rollers need to be oiled, preferably with engine oil. Oil the rollers and work the doors back and forth, the noise should abate.
Feb 21, 2010 | 2005 GMC Envoy
Frigidaire dishwasher door squeaks when opened and closed
I had the same problem and this worked like a charm:
http://www.blog.applianceoutletservice.com/2008/12/frigidaire-dishwasher-door-squeaks.html
All you'll have to do is take off the kick plate, actually remove the cords, and lubricate with soap (lower tech than spray silicon, but it's worked so far...)
Aug 22, 2009 | Frigidaire PLD4555RFC Dishwasher
Squeak - Squeak
if it is kitchenaid/whirlpool unit it has 2 nylon ropes that connect door hinges to the springs on either side of door hinges.these ropes slide over plastic wheels and with time it stars making noise.just cln those wheels and apply little bit of regular bearing grease on those plastic wheel.noise wil go away.to do this u have to pull the unit half way out to access those wheels on lhs and rhs lower front end corners of the unit.good luck.
Aug 15, 2009 | Dishwashers
How to get to the door cable and pulley that
You need to pull out the dishwasher from under the counter and it runs along the bottom on each side.
Jun 30, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Squeaking noise
Noise from dryers can be eliminated through the following checks
* Level the dryer
* Check the drum belt
* Check the drum support rollers
* Check the idler pulley
* Check the glides
* Check drum bearings
* Check the blower
* Check the baffles
Apr 10, 2009 | Maytag Dryers
Squeeking, swaking door springs
Hi there
Thats a common problem with sprung door hinges, get some WD-40 lubricant spray and spray the spring until the squeaking stops.
Good luck and thanks for using Fixya!!
Feb 19, 2009 | KitchenAid Dishwashers
Door drops when opened
your door's hinge link is broken
Pull your dishwasher from under counter (you may need to disconnect hoses and power connnections, so turn off power at the circuit breaker). Look for the broken rope-like item and replace it. Use the other side as an example on how to re-install the link. Attach link to spring, hook spring back into frame/chassis, threaded link through pulleys, attach other end of link onto door then reinstall dishwasher under counter. My replacement link package came as a pair, so replace both at the same time. The other side may still be attached and functioning, but will most likely show signs of wear.
Dec 13, 2008 | KitchenAid 24 in. KUDS01FLSS Built-In...
Squeaky door
On our KitchenAid dishwasher we had the same problem--a REALLY loud squeak as it opened. The sound comes from the nylon rope slipping along the plastic pulleys. We've had the DW for about 3 years and the noise has gotten worse over time. I was determined to win the war against the noise and am happy to say I fixed it today.
The trick is to use a dry lubricant on the cord and on the pulleys. I used Dry Graphite by Gunk. It comes in an aerosol spray can and once the stuff dried the squeak was gone. I'll let you know if it comes back...
May 16, 2007 | KitchenAid 24 in. KUDS01FLBL Built-in...
Kenmore 46462 Front Load Washer Logo
335 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
