Question about Canon ImageClass MF3110 All-In-One Printer
My size of print was changed from 100% to 125%. How do I change it back to 100%?
  • jljdahl Feb 25, 2009
    It is a text problem. I need to make regular copies and normally I can put it on the copier and print. Someone changed the copier to make a bigger copy and change something where now it always makes bigger copies. It doesn't change back to normal 100% anymore.
  • krishna_aks May 11, 2010
    is it a photo or a text
    1.if its a photo use windows xp picture manager to print the photo type
    2. if its a text then change the print option to fits to the page for 100%
    President:
  • 2,692 Answers
Why can't I print to my Ricoh Aficio SP C430DN from my Macbook Air?
You probably have a conflict between the paper size the machine knows is loaded and the document size being specified for printing on. Your Airbook is probably trying to send a document on a paper size the printer doesn't have. Net result is a document stored in the print queue that stops anything else being printed. Go full system reboot and clear out any and all waiting documents before trying again.
Sep 08, 2014 | Ricoh Aficio SP C430dn Laser Printer
How to change paper size from computer & not have to physically go to printer
when you are printing something get to the print area and before pressing the print button click on printer properties and then select the paper size from the list available
save then press the print button
it is only good for the job you are printing as the next job , it will revert to the default setting
Apr 14, 2017 | Canon ImageRunner 1025IF Copier with DOC...
The oil light remains on after an oil change/filter. The car is lexus 2000, Gs300. The milage is more than 100,125 miles. What is the prblem?
It depends. If you are talking about the RED oil pressure warning light, the problem is either that your engine has oil pressure problems or it has a defective oil pressure sending unit. If it is actual oil pressure problems, major engine repair or replacement will be necessary to fix it.
Aug 20, 2011 | Lexus GS 300 Cars & Trucks
I want to change the size of the printed letters, how can U do that? Can I do this with the printer or do I have to chanhe something on my PC
you will need to change the font size in the program in which you are trying to print from. If it is in Word or something similar go to the top and you will see font size, change it to the desired size. If it is from a web page that you are trying to print from you will need to go into your internet page and you will see the choices at the top that say page, safety, tools... etc. Click on Page and go down to text size and change the size of your text here. You can always change it back by reversing the steps above.
Nov 10, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
How do I change print sixe on Deskjet 722c?
usually you can change the print size in the print preview page setup menu.
in this menu you can scale your document down changing the print size.
otherwise, you can take your file in word or any document editing software and select all and change the font size for your entire document. These are two options for you which will change the print size on your printer.
Mar 26, 2010 | HP Office Equipment & Supplies
How do I change the print size my printer prints
The size font used by the printer is changed in the application that you are using to print.
Most applications have a fint setting that you can make the print larger or smaller.
Feb 07, 2010 | HP Photosmart 2610 All-In-One InkJet...
Change the print size
Go to you control panel, open and bring up Display (properties). Click on Appearance and check to see that "Font Size" reads normal. I tried it on my Computer just now and the change to extra large is frightening. :D
Jan 01, 2010 | Dell Computers & Internet
Whenever i change paper size from A4 to letter,
Don't set by using the "Print" option.
Go to [Start]
[Printers and Faxes]
right-click on the HP printer entry
! Don't select "Printing Preferences"! from there
Select [properties]
Select [Advanced] tab
Select [Printing Defaults]
[Advanced}
(I know, the screen looks the same, but it functions differently this way)
Change paper size to "Letter"
[OK, OK, OK]
*done*
Sep 25, 2009 | HP LaserJet 4350 Printer
We had problems to print legal and after 30 minutes of trying it finally printed legal. Now we cant go back to letter size so every document prints on legal paper. Can I get clear instruction on how we can...
When you say printing? Do you mean from the computer or are you making copies. If you are printing from the computer you need to change the paper size that you are printing to under the printers properties or the out put tray. If you are making copies just hit the reset button or just manually select another paper tray on the display pannel. Or if you have change a paper tray to leagal size change it back to LTR and make sure the paper is installed the correct direction.
Nov 26, 2008 | Canon imageRUNNER 2200
Printer font default
OKI printers tend to only print in the font size that you give it in the print options or the softwares printing properties that you are using, you will find that it just indicates the font size being printed if it changes back, this means it's set to 10 in the print properties or the actual programme print setting.
Aug 03, 2007 | OKI MICROLINE® ML390 Matrix Printer
Canon ImageClass MF3110 All-In-One Printer Logo
158 people viewed this question
old marine
old marine
