Question about Sony KP-65WV700 65" Rear Projection HDTV
Convergence problem for a sony kp-65ws500 projection tv 2002 (serial number 9012594). flash focus will not line the tubes up. Can someone tell me how to tell what i need to replace
  • Susan Albert
    Susan Albert Feb 25, 2009
    actual model number is kp-65ws500
  • kaptaindonut Mar 23, 2009
    This convergence adjustment was helpful, thank you. I can play a movie from my laptop s-video just fine, but snow otherwise. Is my tuner shot? Can I replace it with something better? Thanks, Kaptain
  • Sony Master
  • 3,459 Answers
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
77ea520.jconvergence problem for a sony kp-65ws500 - f0900cb.jpgh_mi
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips convergence problem for a sony kp-65ws500 - 2c07611.png should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
5convergence problem for a sony kp-65ws500 - 65af323.jpg class=
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Feb 28, 2009
My sony kp 65ws500 has a all red picture. It looks fine otherwise. nothing i have tried has changed the color of the screen at all. Please help.
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors pictures shadows or 3D pictures look alike?Yes.The tv convergence board it dead.The tv convergence board must be replacing the 2 STK convergence ICS and some or all of it resistors too.To fix the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Mar 02, 2011 | Sony KP-65WS500 65" Rear Projection...
Sony kp-ws500 has very fine red and blue horizontal lines across screen tried adjusting convergence, and it didn't do anything
Red and Blue Tube screen drive controls needs to be turned down some, tubes are over driving causeing drive lines.
Sep 16, 2010 | Sony KP-65WS500 65" Rear Projection...
I have a Sony KP-65WS500 from 10/2002. There are thin red arcing lines across the screen when the scene is dark or black.
This tv have a problems known as a convergence problems,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 16, 2010 | Sony KP-65WS500 65" Rear Projection...
Sony KP-65WS500 Rear Projection TV About a week ago the left side of the screen started to a slight blue halo over faces, hands, and some of the white letters were light yellow. I adjusted the convergence...
Thats a convergence failure issue. The Sony Type 1 convergence repair kit available from www.tvrepairworld.com is the kit your model uses. The kit contains the parts and the CD with instructions.
Dec 20, 2009 | Sony KP-65WS500 65" Rear Projection...
I am having a convergence problem the flash focus did not work
The Sony Type 1 convergence repair kit from www.tvrepairworld.com should repair that issue. The kit contains the parts and CD with instructions
Oct 29, 2009 | Sony KP-65WS500 65" Rear Projection...
Turns off after 30 seconds
i think the convergence amps are weak, or the akb circut has caused the tubes to go bad, google your model number to see if it is in the tube problem. sony made some projos w/ bad tubes in them. tv lasts only three or four years,no cause i had one
Jul 10, 2009 | Sony KP-65WS500 65" Rear Projection...
Double image ( Ghost image )on Sony KP-65WS500
Replacing the Convergence ICs should fix the problem. They are located on the Deflection board. Sony has used a couple of different ones over the years I think they are STK-392-120's but please do not hold me to it.
Hope this helps,
Skyassoc
Jun 25, 2009 | Sony KP-65WS500 65" Rear Projection...
KP_65WS500 Tube numbers
Here is the part number for the blue tube B 07MVC61, the Red is R 07MVC61, and the Green is G 07MVC21. The number to contact the company that makes the tubes is 1-800-241-5005 Ext 143
Jun 15, 2009 | Sony KP-65WS500 65" Rear Projection...
Sony KP-43HT20 convergence problem
Replace STK-392-110s or 150s upgrade with 180s replace both ics.
Jan 04, 2008 | Sony KP-43HT20 43" Rear Projection...
Sony KP-65WV700 65" Rear Projection HDTV Logo
1,567 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
