Question about Avus A450-3001 Micro ATX Mid-Tower Case
Computer Case wiring
How can I tell the correct orientation for the connectors coming from the front of the case to the Motherboard?
  • dsnation426 Feb 25, 2009
    What I need to know is the colored wire (red,blue,green) the + lead?
    Problem Solver:
  • 5 Answers
1st step the size and the design of each and every connectors and circuit are unique
2nd observation the connectors or the power have cords uses a lump design which while moving yours fingers u will definitely have a sense that it is not plane and a line is been feeling in between and its always carried and placed in the downward direction for any help ... u can mail me at my id krishna_aks@rediffmail.com
Posted on Feb 25, 2009
Need instructions for replacing and wiring Motherboard
Luckily that is pretty easy with modern motherboards.
1. Remove power and unplug all devices hooked to computer.
2. Open case.
3. Write down the location and orientation of all wires connecting to old motherboard.
4. Disconnect all wires from the case that are plugged into old motherboard.
5. Uncrew the screws holding the motherboard in the case.
6. Carefully remove old motherboard.
7. Install new motherboard and secure it to the case (probably using the same screws as the old MB)
8. Refer to diagram you made earlier to plug in all the wires to the proper places in the new motherboard.
9. Check and make sure the new motherboard works before closing the case.
10. If everything is working correctly, close up the case and you are done.
Nov 10, 2013 | Computers & Internet
Wiring on power up 5511atx
they need to be attached on the motherboard front panel connector correctly what is your motherboard brand and model?
Jun 19, 2008 | Power Up 5511 (TC3J-4032 P) ATX Mid-Tower...
I have disconnected all th ewire from my motherboard and i have installed all wire but unable to connect pw button,reset button,HDD led wire and anothed LED wire please tell me how can i install them in...
Locate the case connector pins on your motherboard. This will be a bank of two rows with 10-12 pins in each row. Each pin will be about 1 cm in length.2 Locate the power lead behind the power button on your computer case. The lead will consist of two thin wires, usually white and black, held together by a small plastic cap.3 Examine the underside of the power lead for an arrow or dot. If one is present, the marking signifies the first pin. This must correspond with the first pin on the motherboard, which will also be indicated by an arrow, dot, or number. If no markings are present, the lead can be installed in either orientation.4 Place the lead over the power pins within the pin bank. The correct pins will be indicated by a diagram on the motherboard, or by a picture in your motherboard's instruction manual.5 Connect the power cable to the back of your computer, and turn the computer on.
  • Oct 14, 2011 | ASUS P5PE-VM Motherboard
    I have a ECS A740GM-M Motherboard in an Asus TX-381 case. I can't get the 2 front usb ports to work. What am I not wiring up right?
    Make sure you are putting the front usb header connector on the proper USB pin connection on the motherboard. You should see nine pins in 2 rows together. Check the manual that came with the motherboard to find the correct pins location.
    Apr 07, 2011 | Apex Computer Technology TX-381 Micro ATX...
    How to link case wires on the mother board? I've lost the manual and i don't find any stuff on chaintech website...
    hi
  • Locate the case connector pins on your motherboard. This will be a bank of two rows with 10-12 pins in each row. Each pin will be about 1 cm in length.
  • Step 2 Locate the power lead behind the power button on your computer case. The lead will consist of two thin wires, usually white and black, held together by a small plastic cap.
  • Step 3 Examine the underside of the power lead for an arrow or dot. If one is present, the marking signifies the first pin. This must correspond with the first pin on the motherboard, which will also be indicated by an arrow, dot, or number. If no markings are present, the lead can be installed in either orientation.
  • Step 4 Place the lead over the power pins within the pin bank. The correct pins will be indicated by a diagram on the motherboard, or by a picture in your motherboard's instruction manual.
  • Step 5 Connect the power cable to the back of your computer, and turn the computer on.
  • Jun 30, 2010 | Chaintech 9PJL APOGEE Motherboard
    Need schematics for hp pavillion dv7-1130us. Need to take back off because the exhaust fan's fin is rubbing against case.
    It would be much easier to remove the SIDE cover than the BACK cover.
    Turn the computer off, and disconnect the AC power.
    Once you do, you can see the 4 screws connecting the case-fan to the back of the case, and the wires running from the fan to a power-connector on the motherboard.
    Carefully note the "orientation" of the plug that connects the wires to the motherboard. Then, gently pull on the plug, to disconnect it.
    Take a screwdriver, and undo the 4 screws.
    Buy a new fan, and reverse the process to install the new fan.
    Dec 30, 2009 | HP Computers & Internet
    Which wires are positive on the front panel of case
    Don't forget it is about pairs. You never gonna see a pair {Red with Yellow}
    RED = +
    Black = ground (minus)
    yellow = +
    white = ground (minus)
    green=+
    black=ground (minus)
    Jan 12, 2009 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
    How to connect usb cables inthe front panel to motherboard Gigabyte GA-6VM7A+
    look in manual for the computer case ..will identify which cables are for which front panel source..then in manual (online or paper) you route to your motherboard for USB/sound etc.... good luck
    Nov 10, 2008 | Intel Motherboard
    Gigabyte GA-8INXP Motherboard Problem- front connector pins
    If the wires from the reset switch is white/blue the blue wire is positive, Hdd red/white red is positive power Green/white Green is positive etc. The wires on the speaker connector will be red/black/black/white - red is positive. The colored wire is always positive. On all GA mb's the positive connection is always towards the back of the MB and are marked with a + on the base of the pin as you can see on the photo. Hope this help.
    Sep 19, 2008 | Gigabyte GA-8INXP Motherboard
    Pluging in extra usb ports/Mic and headphone jacks from the tower
    Answer me this. You're case is an Antec tower? The motherboard is the Asus P4P800 SE ? Is this correct?
    If you have you're manual you can see what goes where on the board for front panel connector page. 2-31. (This diagram shows you how to connect the front mic & speaker).
    To connect the Antec's front USB ports plug the case USB front connectors onto USB56 & USB78 shown on page. 2-30. Most case wires are already set within their USB connectors & the Antec's front USB connector should fit right on the mother board's pin's. If you need you're user manual, download from Asus by clicking on this link. http://support.asus.com/download/download.aspx?modelname=P4P800%20SE&SLanguage=en-us
    Good Luck!
    Mike
    May 19, 2008 | ASUS P4P800SE Motherboard
    Avus A450-3001 Micro ATX Mid-Tower Case Logo
    335 people viewed this question
    Top Avus Computers & Internet Experts
    David Payne
    David Payne
    Are you an Avus Computer and Internet Expert? Answer questions, earn points and help others
