Hello i have an acer 32" lcd tv . when the tv is turned on the "acer" logo comes on the screen (normal)but for about one second then the screen goes black and only the sound continues. I tried playing a dvd and get only sound as well.
  • 203 Answers
Shine a torch onto the screen when it goes black.
if you can see what is meant to be showing then you have a faulty backlight or backlight components.
easy and cheap fix if it is a backlight, around £15..
if not then come back and i or someone else can help you to run through a few more tests.
Posted on Feb 25, 2009
    Top Expert:
  • Televison & ... Master
  • 77,499 Answers
This problem is caused by a shorted main circuit board high voltage circuit, the cost to repair is around $400-600
    Brigadier General:
  • 3,614 Answers
theres a possible problem on the lcd screen backlight,
  • micromaster
    micromaster Feb 25, 2009
    Make sure you are outputing YPbPr to YPbPr or RGB to RGB.
    Another potential cause is a faulty cable.
I have an element 32" HD LCD TV. I turn it on and it goes to the blue logo screen, but then all of a sudden it just goes black after 2 seconds. No sound or picture. Help?
If you have a blinking led on the front panel, we will need the sequence of blinks.
If not, you should have the power supply checked.
May 12, 2014 | Televison & Video
My Dynex 32" LCD tv seems to turn on and off
The blue light merely indicates that power is getting to your TV. It has internal power supply problems.
Nov 30, 2013 | Dynex 32 in. LCD Flat-Panel HDTV
FLX3211b when plugged in the red power light comes. Then when the TV is turned the red light turns blue and stays on. The Element logo appears for a couple seconds then the screen goes black. There is a...
the transformer for the backlight is usually what fails on the elements especially if the logo comes up briefly then the screen goes out. I would check the transformers.
Apr 04, 2012 | Element Electronics FLX-3211B 32 in. LCD...
Can't get rid of LED TV logo on Samsung TV
Apparently it's on demo-mode so you have to go to 1. Set up 2. Plug and play 3. Then change to home instead of demo
Jan 27, 2012 | Samsung 32 UN32D4000 LCD TV
32" flat screen Westinghouse TV
Hello, it sounds like you need to replace the inverter board on this unit. I would recommend opening the unit from the back cover, get the part # for the inverter board (long green board normally running accross the edge of the TV) and go to www.shopjimmy.com, they should have it in stock and if not you can try www.invertercentral.com, they should also have it.
Oct 23, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
At power up tv displays Acer logo then goes to black
will not turn off power with out unplugin it
Mar 01, 2009 | Televison & Video
Acer al1916 monitor goes black
You probably have a few dodgy caps on the power board inside. It's an easy fix if you are confident around electronics.
If not, pop it off to your local TV repair shop and have it taken care of now before it gets expensive with a complete failure.
Hope it helps =)
Apr 09, 2008 | Acer AL1916W 19" LCD Monitor
Screen powers up then goes blank after 2 seconds
Hi, was there a resolution to this? I am experiencing the same problem with LCT3285TA purchased at Radio Shack in Media, PA. Radio Shack has refused to service the unit and has put me over to Akai for the manufacturer's warranty. I'd like to know what to expect and if this problem with the Logo coming up and the unit shutting off/restarting can be easily fixed, thanks.
Oct 30, 2007 | Akai LCT3285TA 32 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
