Question about Konica Minolta bizhub 250 All-In-One Laser Printer
Connect through ethernet connection
This printer connected through a server to service a number of computers we have recently moved office and have downgraded to one computer which is not connected to the server. is there any way of using like a plug and play option through the ethernet connection. It will not pick up the printer when i go to add printer on the control panel
    Sergeant:
  • 268 Answers
The only thing you can do is connect it to your new network''s router....from that point you would have to install the printer, and specify the IP address of the printer, then you will be able to print. Actually, every computer on your network will be able to print from it.
If that is something you want to do, let me know and I can give you a step by step for configuring your computer to print to that copier.
Posted on Feb 25, 2009
  • Chris Callo
    Chris Callo Feb 25, 2009
How can i networked my kyocera taskalfa 180
You only have a usb 2 connection.
You can hook it to one p.c and share out the printer to other p.c.s.
You could invest in a router that has provision for sharing out a usb printer connected to it.
You could invest in a USB printer server. see http://www.dlink.com/us/en/home-solutions/connect/print-servers/dp-301u-10-100-ethernet-usb-print-server. However you need a ethernet network already in place with your other computers. You can connect your other p.c's via ethernet and use a network switch device to connect all devices to one another if you do not have a network or use a wireless Router and wireless adpaters or p.c's but no more than 4 p.cs on wireless.
Aug 31, 2014 | Kyocera Office Equipment & Supplies
Hp officejet 7310 all-in-one printer wireless connection
reset the printer .
and start over in the manual.
no PC stated,
no statement of what works and what dont ,togethe
do you have a router, ? if yes is it theres or yours?
seems call them get teh unstated laptop working first.
first with ethernet cable, that must work first.
ask them , if its their router and their modem.
if all that is yours, your hardware, then you need to tell what it is
first to get connected. make and model..
i guess you now have cable modem.
to get the router working it needs to be setup to the new cablem modem turning off all DSL modes, and using direct mode.
the printer is here.
for any setups , and resets , are all there. to read.
https://support.hp.com/us-en/product/HP-Officejet-7300-All-in-One-Printer-series/391181/model/391183
Sep 30, 2017 | HP Officejet 7310 All-In-One Printer
I have an hp 1320 laser jet printer but it cant be recognized by all the computers in my office. i have tried to change both usb and parallel cables but nothing is happening . what could be the problem?...
Have you connected it via Ethernet and installed the software on your office's server? If not then you will have to set it up as a USB or parallel on one pc and then all the other computers on the network will have to print to the IP address on the network of the PC it is connected to and then set up each machine to access that printer.
Aug 24, 2011 | HP LaserJet 1320 Printer
After moving to a new house/ new state, I can not get my HP 2035n to connect wirelessly to the router. It will print from any of our computers, but must stay connected to the router. I can find no...
The HP P2035N doesn't have a built-in wireless ethernet connection. It has a wired ethernet port. To connect to a wireless router, you need the HP Jetdirect ew2400 802.11g Wireless Print Server or the HP Wireless Printing Upgrade Kit or a similar device (note: not all third-party wireless print servers will work with the HP printer). Did you have something like this and misplace it during your move? If you did, try to find the print server to use the wireless option. Otherwise, continue wired ethernet option since it is working.
HP support for the printer (manuals, set up infomation, and drivers) is available here: http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3662025&lang=en&cc=us .
I hope this helps.
(HP models with a W at the end of the model number have wireless capabilities without any additional hardware.)
Apr 30, 2011 | HP P2035N LaserJet Monochrome Printer
Hello, How do I connect my Epson stylus PHOTO px700 to my laptop?
NETGEAR’s 54 Mbps Wireless Print Server with 4-port Switch allows you to connect one or two printers to your existing wireless network, without using unsightly Ethernet cables. Simply place your printers anywhere in your home or office that works best for you, plug them into the print server’s USB ports, and the Smart Wizard set-up function automatically guides you through configuration. Then you can send your business documents to a high-end color printer, and your kids’ homework to a black-and-white printer. The print server also acts as a wireless Ethernet bridge, connecting a cluster of up to four PCs and laptops without requiring dedicated wireless adapters. I t employs powerful WEP Encryption and WPA-PSK to keep your wireless network secure, and interoperates with all standard b and g wireless devices. All this in a sleek, space-saving stand-up case.
Mar 22, 2010 | NetGear WGPS606 (WGPS606NAR) Print Server
I wanted to set up the printserver wirelessly but everytime my computer searches for the printer server, it only registers in the wizard if i connect the WPS54G to the router. If i do this, i am able to...
The printer and print server has to be connected to the wireless router by a network cable for you to print wirelessly from the laptop.
If possible connect a long network cable between the print server and the wireless router or move the router next to the print server and printer.
You maybe able to use a wireless repeater/extender but is it worth the added costs and complication. The extended range would invite hackers unless you secure your system.
Aug 01, 2009 | Linksys Wireless-G WPS54G Print Server
Connecting to Linksys as Router for Canon Image Runner 3300I
You can connect by using a hub. Then wire the hub to the machine and from hub to the stand alone pc. Still you have ot do some pc configuration to make the system running.
May 22, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Print server won't speak to printer
If I am correct, you are connecting the print server to the Xerox with a parallel cable.  If so, you are printing two different ways when you connect with an ethernet cable.  When you connect the printer with an ethernet cable you are probably printing TCP\IP to the IP Address of the NIC Card (in the printer).  When you connect with a print server, the print servers IP Address becomes the one you would use as the port for the printer object in Windows Printers & Faxes.
Oct 12, 2007 | Computers & Internet
Network Connection (LAN) for HP 650C
Plug it directly into the router and set the printer up on your Win2k/Xp as a network printer via the new printer wizard. The router will allow it to pull an IP number and you will find it on the network that way. It does not have USB because it was meant as an office printer and the option was network adaptor when purchased. If you look at the card in it, you can see it can be swapped out for another adaptor.
Apr 26, 2007 | HP DesignJet 750c plus InkJet Printer
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
246 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
