Question about Ryobi Garden
Ryobi pcn3335 chainsaw chainbrake will not release fully
Chain becomes fully free only when brake handle is pulled hard back to release and is held.
  • David Ford
    David Ford May 11, 2010
    I cant find anything under PCN 3335. It sounds like the chain is not locking in the open position which could be an adjustment or a lot of debris in the cover not allowing full expansion. Give me the model number and I will try and find more info for you
Hi i have a ryobi 4545 with the same problem ( the brake will only release if i pull it back hard ) i have had a look but can not see any means of adjustment ...hope you can help.
Posted on Apr 29, 2010
  • r_rowe2
    r_rowe2 May 19, 2012
    Had no end of problems with the same problem, new brake band and lever mechanism did not fix it. Ended up shortening the spring about 3mm, this worked and the brake still works fine when engaged.
    President:
  • 2,220 Answers
1. Is there a Homelite/Ryobi dealer/authorized repair facility near you? If yes I'd try them they may repair it.
2. Any major chainsaw seller/repairer may be able to repair it... there will be a fee.
Lou
I own a few chain saws without chain brakes. I also own and use good PPE.
Posted on Sep 05, 2009
When engine is running the clutch will not turn. What could the problem be?
Sounds silly but have to activated the chainbrake by accident.? The black handguard by the top handle is the chainbrake.! Pull it back to de-activate the safety chain brake. It works by activating a brake band around the clutch drum, stopping the drive but the engine still runs, however if you try and rev it the engine will struggle under load because the clutch is trying to drive a drum which is being held by the brake.
Jan 07, 2016 | Poulan 14 Woodshark Chainsaw
Why won.t chain brake release
There is a "knee" mechanism in the side cover. It may have failed or is stuck. I would suggest pulling back on the chainbrake handle to almost break the handle, if it does not release pry the cover off of the saw. Then REPLACE the entire assembly side cover and chainbrake.
May 28, 2014 | Husqvarna Garden
Why does the chain brake not work?
1. What is the make and model of the saw?
2. Does it make any sound when you push the chainbrake handle towards the front (the bar and chain direction)?
3. The idea, and the way it works is that as the bar and chain get jerked upwards towards your face, your left wrist catches the chainbrake handle and pushes it forward thus engaging the chainbrake.
May 10, 2014 | Stihl Garden
Motor is working but chain is not running
If it has a chainbrake, make sure this is not engaged, grab the hand guard and pull it firmly back to the top handle, this should de activate the brake.
Oct 06, 2011 | Ryobi 18-inch Electric Chainsaw Chain Saws
I put oil in my new chainsaw, but it is smoking and the chain is not turning.
Sounds like the chainbrake is on, grab the hand guard and pull it fully back to the top handle until it clicks and the brake is off.
Sep 03, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Runs but the chain won't move? Poulan
This sounds loke the chainbrake has activated, grab the hand guard and pull it fimly fully back to the top handle until it clicks and the brake is of, now try again.
Aug 28, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Chainsaw is new but chain will not move. Is there a safety feature causing this, or what is the problem?
All machines today will have a chainbrake, this is normally a band that comes around the clutch drum to stop the chain in the event of a kick back, to unlock the brake, pull the hand guard fully back to the top handle until you hear the click of the brake loading, there will be an amount of force required to pull the guard back.
Feb 27, 2011 | Poulan 14" Electric Chainsaw
Ryobi gas chainsaw- chainsaw brake is stuck on. How do I release
You just have to pull the lever back, like it was on the saw, until it clicks/unlocks. It may be hard to do, but thats what has to be done.
Jun 11, 2009 | Ryobi Garden
Garden Logo
979 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
