Question about Karcher Garden
Karcher 550m leaking
How do I dissasemble the above and replace the seals?
5 Suggested Answers
  • 46 Answers
SOURCE: karcher 520m oil leak
small engine shop should be able to obtain the proper gasket for you.....oil 20 weight fill untill you can see it at the bottom of the threads at the whole you pour it into!
Posted on May 25, 2009
  • 174 Answers
SOURCE: Karcher 550m down on pressure
Sounds like the unloader valve is stuck, or it is leaking
Posted on Jul 08, 2009
  • 92 Answers
SOURCE: karcher 550m has lost alot of its pressure,Why
Dear emmettbrickw,
Many of the models of Karcher machines, have a valve that under pressure...will compress and at the same time it will let water by-pass and circulating inside the head. As this valve compresses it also puts off a micro switch. This all happens when the gun is closed. This valve is called a SPILL VALVE or sometimes a CONTROL VALVE. Now for various reasons (example you store the machine with pressure in the system)....the seals of this Spill Valve get damaged. So you can have a problem in which the machine stays off....or a problem like yours...the machine continues running with gun closed. Your problem with gun closed...the spill Valve is not compressing and therefore not stoping the machine. At first when this happened it caused a fault also in your machine's valves. The gun was closed...pressure grew high...and this burst the intake valves for sure.
So my advice is that the spill valve must be renewed and also the intake valves. You must also check the Miro-Switch to see if it got stuck in the on position. If micro-switch is faulty, this also must be renewed. The Spill Valve is often located where you find a micro-switch holder with an electrical wire coming out. When you find this micro-switch...detach it from machine...then put on machine for a few minutes and press micro switch to see if machine stops. If machine stops...then at least Miro-Switch is OK. Always do these tests with electrical protective clothing, Shoes and Gloves!! Now if your machine does not have a micro-switch...then you have a spill valve which only by-passes water. This type of spill valve also needs checking and if need be renewed.
In a few simple words, the spill valve does all the work after one has opened or closed the gun. Sometimes by changing the spill valve only....the pressure will get back to normal. If not ...suction and delivery valves must be checked.
Regards,
Fulltech.
Posted on Jul 21, 2009
SOURCE: Karcher dirtblaster leaking at the end
If it's leaking it obviously has a bad seal or is broken. I would try to disassemble and see if it has a seal or not. Sounds like you could have a bad "O" Ring or some other type of seal leaking but I'd bet on an "0" Ring damaged or wore out. Dissemble it and see what is sealing it and proceed accordingly.
Gillight
Posted on Jun 26, 2012
Gillight
Jun 26, 2012 | Karcher K2.26 Electric Power Washer
Hi i have a karcher k4.91 and it is lossing pressure and leaking from inside the casing..what would be the likely cause.. many thanks
This could be a problem in the pump, the seals may have been damaged if it is an older machine through age. You could check a local karcher supplier/dealer and they should be able to replace that for you. Another problem maybe that an inlet elbow could be loose and does not seal correctly so it may need replacing.
These solutions depend on what area inside the machine the water is leaking from.
Jan 11, 2011 | Karcher Garden
Karcher K2.26M water leak
I have the same Problem, the leak is from the seam of the Manifold housing. There is a small crack in the seam. A manufacturing defect.. A New Manifold Complete Replacement K2.26* Part # 97501760 is $61.03, about the half the price what I paid for this pressure washer at Walmart... :( If under 1 year old, and you can find a receipt,Karcher will replace the whole Pressure washer under warranty.
Jul 03, 2010 | Karcher K2.26 Electric Power Washer
I have a Karcher KB5050 it started to pulse when the trigger stopped
Is there water leaking from the bottom ? If so, then you have a leak in the pump. Bad seal or crack in the Pump.
If under 1 year old and have a receipt, Call Karcher for a warranty replacement.
May 14, 2010 | Karcher 1750 psi Electric Pressure Washer
Just started using my kb4040 and water i s leaking
Sounds like the water seals are bad. For Karcher parts go here: LINK
Jan 18, 2010 | Karcher 1750 psi Electric Pressure Washer
Jul 08, 2009 | Karcher Garden
Karcher 520m oil leak
May 24, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
1,049 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
