Question about Bosch 24 in. SHY56A05 Stainless Steel Built-In Dishwasher
I have a bosch shu33a dishwasher and its not draining at all. it washes the dishes but the water wont drain out
  • 10,865 Answers
Remove the lower front panel and you will see the drain hose leaving a tiny pump and heading out of the dishwasher space into the sink space where the drain line is attached to your drain line.
Remove the clamp on the drain line closest to the little pump and then unscrew the pump. you are looking for an obstrution in the form of a piece of broken glass, a bone, or something else which is preventing the pump from pumping the water into the sink drain.
please rate my answer as a fixya!
Posted on Feb 25, 2009
Not Rinsing
By cleaning it out, you cleaned the bottom where the water is drawn in and food particles collect, right? Are the sprayer arms working good? The holes on them are not clogged with anything? How does the dishwasher drain? I mean do you have an air gap or does it drain directly into the disposal or sink pipe. Sometimes without an air gap, the disposal will send junk into the drain line if the check valve is not working properly, thus giving you excess food in the dishwasher.
Jan 12, 2008 | Bosch 23 in. SHU33A Built-In Dishwasher
E:25 on bosch dishwasher ?
Bosch E25ErrorThe drainpump is blocked or restricted by debrisPossibly something stuck/jammed in the wash or drainpropeller, remove filter mesh at the bottom of the dishwasher. Carefully remove any excess water and debris jammed near the propeller caution there may be glassor debris near or where the water drains-out.Removeand clean the spray arms, they may have food debris jammed, rinse in hot runningwaterMaintainerWash Runa wash with a tablespoon of powder, without any dishes on the hottest settinge.g. intensive, 65C, if you have a 70C this will be more effective.
Apr 09, 2012 | Bosch Dishwashers
Water not draining after wash. Checked the troubleshooting guide and none apply to problem. It seems like the pump isn't running.
Have you purchased a new food waste disposer for the kitchen sink area? If so, make certain if you are draining the dishwasher directly into the food waste disposer, that you have removed the plug from the food disposer. Or you may be correct that the water pump is inoperable due to an obstruction or basic malfunction. Contact an appliance service company.
Apr 14, 2010 | Bosch 23 in. SHU33A Built-In Dishwasher
Wont drain check everything push drain botton still wont drain
i call a repairman in it was the drain pump thank you for your help NOT what a joke this site is have a good day boys
May 18, 2009 | Bosch 23 in. SHU33A Built-In Dishwasher
Bosch SHU33a won't drain
Try pouring in enough water to cover the screen in the bottom of the dishwasher, maybe a 2 quarts or so, then run the drain cycle. This should prime the pump and at least tell you wether the drain pump is working or not. Just a trick i've heard and worked for me, not my area of expertise however.
Jan 05, 2009 | Bosch 23 in. SHU33A Built-In Dishwasher
My dish washer won't stop trying to drain
my dishwasher would fill up and start draining when washing watt should i do
Nov 24, 2008 | Bosch SHU9925UC Built-in Dishwasher
Bosch SHU33A won't drain
I believe you, but did you check the nipple on the drain where the hose connects?
My sink drained OK, and when I took the dishwasher hose loose from the sinkdrain it drained great into a bucket.
When I stuck a screwdriver down where the drainhose connects to the sinkdrain, I felt all kinds of resistance. Its now cleaned out and the dishwasher drains again.
Hope this is your problem otherwise you may need a new pump.
Apr 07, 2008 | Dishwashers
Not cleaning dishes
sounds like you are not getting enough or any water a check the water level when it fills... let me know
Apr 05, 2008 | Bosch 23 in. SHU33A Built-In Dishwasher
Bosch dishwasher model #shu33A
your dirty water backed up into the washer (which it shouldn't do) and probably clogged something in there,..i would recommend getting it flushed out somehow, not sure how,.....next time, your washer drain hose should go up under the sink as high as possible and then back down to drain,....this settup makes it hard for drain water to go back into washer,....it's instructed in any dishwasher manual
Mar 06, 2008 | Bosch 23 in. SHU33A Built-In Dishwasher
Bosch 24 in. SHY56A05 Stainless Steel Built-In Dishwasher Logo
293 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
