Question about HP DeskJet 940c InkJet Printer
Printer does not print at all
Orange light on left continues to flash though I have installed new ink cartridges
  • 3 more comments
  • anne476 Mar 06, 2009
    thank you it is nice to know there is help out there. Problem solved.
  • emc07 Mar 13, 2009
    orange light on left blinks, will not print.Installed new cartridges
  • essenceangel Mar 25, 2009
    my problem is exactly to same. I changed the cartridge and still the light is still blinking. what do i do
  • lelethulele Apr 24, 2009
    Im using the windows 98,there is only information about XP and Vista
    the left light keeps flashing even after installing a new catridge
  • 3 Answers
Did u remove the cellotape that covers the printhead of the new cartridge?
Other solution:
if using XP: use the HP toolbox to prepare the new catridges for firsttime printing.
If using Vista, go to start-controlpanel-printers and rightclick on hp940C icon, choose properties, select services and do a cleaning and prepare job.
Posted on Feb 25, 2009
What causes orange light to flash 4 times?
It is related to a badly installed or empty print cartridge: http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#1600
1600 - Orange light blinking 4 times Description:
The ink cartridge has run out.
Resolution:
  1. Lift the printer cover up.
  2. Identify the ink cartridge that has run out (the ink cartridge flashes quickly at around 1-second intervals).
  3. Replace the applicable ink cartridge and close the cover.
  4. Press the [Resume/Cancel] button on the device to continue printing.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
1660 - Orange light blinking 4 times Description:
The ink cartridge has not been installed correctly.
Resolution:
  2. Check that the red lights on the ink cartridges are all turned on.
  3. If no red light is activated on a particular cartridge, check that the cartridge is securely positioned and adjust if necessary.
  4. Also make sure that the orange protective cap has been removed from the bottom of the ink cartridge.
  5. Press the [Resume/Cancel] button on the device to continue printing.
Feb 11, 2016 | Canon PIXMA iP3500 Printer
Colour and black ink cartridge flashing orange
They call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Oct 05, 2014 | Canon PIXMA MP495 InkJet Printer
Flashing light opposite ink symbol
Indicating cartridge faulty/exhausted, replace the cartridge..
Oct 11, 2011 | HP DeskJet F380 All-In-One Printer
Both lights are blinking and will not print
they call that flash codes or error codes. please count
Sep 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Green and orange lights flashing
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth.
Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Hope this help. Please Rate My Response! Thanks!
CF
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Aug 26, 2009 | Canon Pixma MP500 All-In-One InkJet...
Problem on a canon 3100
The Power Light Flashes Orange - Error Codes When an error occurs, the power light flashes orange. The number of orange flashes followed by a long green flash indicates the cause of the problem.
Two orange flashes: Out of paper, paper jam, or paper feed error
If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing.
Three orange flashes: Paper jam
If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing.
Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink
Replace the empty BJ tank and press the Resume button to continue printing.
Five orange flashes: BJ cartridge is not installed properly
Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely.
Six orange flashes: BJ cartridge (printhead) is not installed
Seven orange flashes: BJ cartridge (printhead) is defective
Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge.
Eight orange flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing.
The POWER light flashes orange and green alternately: Service error
A service error means the printer requires the attention of a qualified technician. Count the number of flashes. (You may be asked this information.)
Feb 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Put in new ink cartridge -- won't print
Try lifting up the cover. If the ink level is low in a print cartridge, the Print Cartridge Status light stops flashing. If the problem is not related
to low ink, the light continues to flash after the cover is opened. It might be that the new cartridge is defective. Check the connections and see if there isn't anything keeping it from making contact.
Jan 26, 2009 | HP DeskJet 920c InkJet Printer
HP Deskjet 6940 not printing after replacing ink cartridge
My HP Deskjet 6940 is not printing. The color (left) low ink light is dark and the black (right) low ink light is flashing. I replaced the black ink cartridge with a new one but the low ink light continues to flash. No tears/rips in the circuit strip and all the copper leads appear to be connected
Sep 29, 2008 | HP Deskjet 6940 InkJet Printer
Printer ripair
The BJC 3000 will flash two different colored lights in a pattern to signal several different errors. From the documentation I have the two colors are orange and green, could those be the colors you see? At any rate here is the code: Two orange flashes: Out of paper, paper jam, or paper feed error. If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing. Three orange flashes: Paper jam. If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing. Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink. Replace the empty BJ tank and press the Resume button to continue printing. Five orange flashes: BJ cartridge is not installed properly. Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely. Six orange flashes: BJ cartridge (printhead) is not installed. Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely. Seven orange flashes: BJ cartridge (printhead) is defective. Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge. Eight orange flashes: Waste ink absorber almost full. The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing. The POWER light flashes orange and green alternately: Service error. A service error means the printer requires the attention of a qualified technician. If you have any more questions let us know otherwise please don't forget to rate this post.
Feb 20, 2007 | Canon BJC 3000 InkJet Printer
HP DeskJet 940c InkJet Printer Logo
527 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
