Question about Virtual Reality Black Vr3 Wrless Backup Camera W Color Monit
Wiring installation for back up camera monitor
I have a Innovage wireless back-up camera. The monitor has a cord that attaches to the fuse block. The cord has 3 wires; black, red, blue. I'm assuming black is negative, but don't know where to attach red and blue. Any help would be greatly appreciated.
Yes the black is ground, the red goes to a constant power in the fuse block , and the blue goes to the reverse wire to activate the monitor
Posted on Jun 08, 2009
  • 2 more comments
  • G Kla Dec 14, 2010
    I think the blue wire is to solid wire the camera to the monitor for long vehicles when the wireless doesn't work
  • ydoucet166 Apr 12, 2011
    You plug the blue wire on the positive ( + ) of your backup light
  • rmorain988
    rmorain988 Oct 31, 2013
    Avoid all of these complexities by using the truly wireless QuickVu(TM) Wireless Backup Camera. The camera has no (zero) wires. The receiver and monitor are super simple, too! Find it at
  • Timothy Nelson
    Timothy Nelson Dec 22, 2013
    i have been searching all day for the wiring diagram, my un-insatlation riped the cord out of the camera, and need to see where the 4 wires go. my dog ate my diagram...
    Uploaded 5 video answers.
  • 10 Answers
Avoid all of these complexities by using the truly wireless QuickVu(TM) Wireless Backup Camera. The camera has no (zero) wires. The receiver and monitor are super simple, too! Buy direct from the manufacturer!
Posted on Oct 31, 2013
Which wires in the wiring harness are for the back-up lights?
Buy an aftermarket, wireless back-up camera. Wire the camera to your back-up lights and mount the display somewhere on your dash that allows you comfortable viewing without blocking other essential controls or HVAC vents.
Sep 15, 2014 | Cars & Trucks
3-prong to 4-prong Power Cord Conversion.
This advice is on how to correctly install an ELECTRIC DRYER or ELECTRIC RANGE 220-240VAC power cord (US Standards).
3-Prong or 4-Prong – The Difference:
3-prong color code:
BLACK (HOT – 110-120VAC) – May also be referred to as L1
RED (HOT – 110-120VAC) – May also be referred to as L2
WHITE (NEUTRAL – 0VAC) – Usually grounded to the equipment frame via a jumper wire or metal strap.
4-prong color code:
WHITE (NEUTRAL – 0VAC) – DO NOT ground to equipment frame.
GREEN (GROUND) – Attach to equipment frame.
Which One to Use: According to the National Electrical Code (NEC), Article 250, installations after the year 2000, require the use of a 4-prong plug which incorporates a separate ground and neutral wire. If you currently have a home that uses the 3-prong receptacle and cord, you can continue to use it. You will have to upgrade to a 4-prong configuration, however, if you plan on relocating your current receptacle, or if the internal wires of the receptacle become damaged in any way and require repair.
Converting from 3-prong to 4-prong: Make sure you UNPLUG the appliance prior to any repairs. CAUTION: Voltages dangerous to life are still present even with the appliance turned off and still plugged in. Notably in the area of the terminal block where the power cords are installed. You will need to remove the old cord by following these steps:
  1. With the appliance UNPLUGGED, remove the access panel on the back of the unit where the power cord enters.
  2. With the cover removed, you will see a terminal block where the power cord is attached. The terminal wires will be colored with the WHITE wire in the middle, and the BLACK and RED wires on either end. NOTE: There should be a green jumper wire or metal bonding strap attached to the NEUTRAL (white) terminal wire.
  3. Remove the terminal lugs holding the old power cord wires in place. CAUTION: Use care not to drop any nuts or screws inside the appliance.
  4. Remove the bonding strap or ground wire from the Neutral terminal lug. NOTE: If disconnecting a ground wire, make sure you re-attach it to the appliance frame.
  5. Loosen the screws on the strain relief connector that holds the power cord in place and remove old power cord. NOTE: If your appliance does not have a strain relief that clamps down and hold the power cord in place, it is highly recommended that you install one. This prevents chaffing of the power cord against the appliance casing, and prevents the terminal wires from being pulled and broken loose. This could pose a potential shock hazard or cause damage to the appliance.
  6. Install new power cord by threading it through the strain relief connector and tighten down the screws.
  7. Connect the new power cord to the corresponding colors at the terminal block (Black goes to Black, Red goes to Red, White goes to White). The difference is going to be a Green (ground) wire that will connect to the appliance frame. There’s usually a green grounding screw for this. NOTE: If you disconnected a green grounding strap in Step 4., you can connect these two wires at the same point.
  8. Re-install access cover. Turn off the service breaker to the appliance PRIOR to plugging it back in. With the breaker in the off position, plug the appliance in, and THEN turn the breaker on. In the event, something was wired incorrectly, it is far better to have your hands away from the receptacle and controlled from a distance. Safety first.
on Jul 16, 2008 | Whirlpool LER5636P Electric Dryer
Need aservice manual for a audiovox 350 back -up camera for a car or owner manaul
If you don't find what you need, you might consider the truly wireless QuickVu(TM) Wireless Backup Camera. The camera has absolutely no wires, so it is easy to install. Buy direct from the manufacturer!
Oct 16, 2013 | Audiovox Acam350 3.5 Inch Lcd Rear-view...
Wiring a back up camera
Try the truly wireless QuickVu(TM) Wireless Backup Camera. The camera has no (zero) wires, so it installs simply. The receiver and monitor mount easily on the dash, or if you have an in-dash screen with an RCA input, simply run a cable from the receiver to the screen. Buy direct from the manufacturer!
Aug 18, 2013 | 2001 Lexus LX 470
I am installing a 30 amp cord on my Whirlpool dryer. The model number is WED5100VQ. I am having a problem finding the ground wire in which to ground the dryer because it only has a white wire coming from...
On whirlpool (all manufacture) dryers the ground wire is linked to the center terminal with the white wire and attaches to the cabinet grounding all metal on dryer since on panel attaches to the next making the entire cabinet have continuty through the neutral/ground wire.
When connecting 3 wire cord connect the two outside wires to red/black on cord block and center wire to white/center terminal connection on block.
For a 4 wire cord red to red black to black white to white and the green to rear of cabinet/any panel near block
(same question listed 2 times gets same answer 2 times)
Aug 13, 2011 | Whirlpool Dryers
We were recently given a kenmore dryer, without a power cord. How do I attach the 3 wire power cord that I bought to relace it?
Attach the power cord as follows:
1. Remove the cover on the terminal block on the back of the dryer.
2. Match the corresponding wire colors as follows:
a. RED - HOT (120VAC)
b. BLACK - HOT (120VAC)
c. WHITE - Neutral (0 VAC) - should have a ground strap attached, tying it equipment ground.
3. Make sure you use the power cord strain relief clamp when installing the power cord to prevent chaffing of the insulation and wire strain which can lead to broken wires.
NOTE: If the wires are not color coded, the outer two wires (left and right) are the HOT leads. The center conductor is Neutral.
For clarification purposes, the following link explains dryer power cord configurations/installation in detail:
If you have any questions, please post back and let me know. I hope you find this information helpful.
Mar 17, 2010 | Dryers
I have a 3 prong to change to a 4 prong cord on my dryer
The following link explains how to correctly install a 220VAC appliance cord to your dryer:
Read through the instructions provided and let me know if you have questions. This advice is how to convert from a 3 prong to a 4 prong appliance cord. You simply match the corresponding colors of the wires on the cord you intend to attach to the matching colors at the terminal block on the back of the dryer. If the wires are not color coded at the terminal block, the outer two wires (left and right) are the HOT leads, the center wire is the Neutral. Make sure the neutral ad ground wires remain independent of each other in a 4 wire configuration. The green wire should be terminated on a ground lug on the equipment cabinet while the neutral is terminated at the terminal block.
Let me know if you require further assistance. I hope this help you.
Feb 06, 2010 | Dryers
I need a cord I need for an observation cam from magnavox
Strange, I have the opposite problem, I have the cord and camera, but no monitor. I found the following fix below to make this camera hook up to any tv or monitor, but it's greek to me. It may help you though! Or, if you can translate these instructions for me to hook up mine, I'l happily GIVE you my cord!
"The DC power was sent up the coax and the video is AC coupled and sent back down. If you open the
camera and trace the wire from the center pin of the UHF connector, it will lead to an inductor
and a large value capacitor. The video is coupled through the capacitor, which blocked the DC
power from the video output amp. The inductor (coil) blocks the video from getting back into the
power section.
Cut the inductor loose from the center wire of the connector. Put well filtered +12 VDC at 500
mA (1/2 amp) or greater into the inductor at this point while running a video cable from the jack
to a video monitor or to the video input of your home VCR. Then you can see the video on your TV.
Power return is to the ground of the connector or any other convenient grounding node.
Jan 28, 2009 | Philips Magnavox 27MS343S 27" TV
Hooked up camera system wrong
yes. should work the same.
May 06, 2008 | Car Audio & Video
Innovage Speaker Phone
This is exact problem I was having. Just purchased phone about a week ago, 5/07. I took it back. I had phone company come out and it was this phone. I took mine back, but I would like to have one for the features if I could solve this problem.
Dec 29, 2006 | Innovage 1502084 Corded Phone
Virtual Reality Black Vr3 Wrless Backup Camera W Color Monit Logo
1,844 people viewed this question
Top Virtual Reality Home Security Experts
Lawrence Oravetz
Are you a Virtual Reality Home Security Expert? Answer questions, earn points and help others
