Question about Craftsman 25cc Gas Line Trimmer
Bad running craftsman 25cc trimmer 4 yrs old
This trimmer has always been hard starting but in the past, once started it ran well. It has been in storage or moderate use other persons for 10 months. Once I started it now, It ran but badly. Never able to achieve smooth high performance..sputtering & dying. When it quit I couldn't get it started after that even after waiting hours. John R
  • sobriety0118 Feb 25, 2009
    Thanks for you response. To change the air filter i assume you have to remove the back 1/2 of the plastic housing around the engine. It has, I believe thy are called, torque screws holding it in place. Alsi, i did look at the spark plug already. it did not appear fouled. Should I change it anyway? John
  • 10,865 Answers
You need to do a couple of things to get your trimmer back on track. First of all pour out the old gasoline and get rid of it. Then remove the spark plug and go to an auto parts store and get a new one just like the old. If you have your manual, check to see what the recommended spark plug gap is gap it to that specification.
Finally remove the air filter and clean it or replace it as necessary.
Once that is all done, but some new, fresh gasoline. Then put in the new plug and the new gas and u will be good to go. please rate this answer as a FixYa cause it is.
Posted on Feb 25, 2009
  • Joe Hogan Feb 25, 2009
    yes john i change the spark plug often cause they are cheap and they make the engine start and run easier when they are new
Why wont my craftsman 25cc start
99% of the time its a carb or fuel problem. Always run premium fuel and store the machine in a cool place less than 100 F
Might can put a drop or two of fuel down the carb and revive.
Jul 18, 2014 | Craftsman 25cc Gas Line Trimmer
My 7-year old 25cc Craftsman line trimmer began surging during use, would bog down when given throttle, then would completely die, became hard-starting, and now doesn't start and run at all. Acts like...
A new fuel filter with new fuel lines and a rebuild kit for the carburetor should do it. You may even be able to get away with just the gasket and diaphragm kit for the carburetor. It is cheaper than the complete rebuild kit if you choose. Run synthetic oil and these things will last a good long while.
May 14, 2011 | Craftsman 25cc Gas Line Trimmer
What is the oil to gas ratio. I have lost my manual?
i use 50 to 1. machine has ran 3 yrs with no problems. just keep up with general maintanance. i do lawns on the side, and machine gets alot of hours in a week. starts within 2 pulls.
Sep 13, 2010 | Craftsman 25cc Gas Line Trimmer
Craftsman 25cc Gas Line Trimmer dies when giving throttle. It starts up and runs in the "Start" setting, then dies as soon as you give it gas. I replaced the carburetor...it ran great immediately after...
Sounds like the carb is getting clogged. Drain the old fuel and make sure the fuel filter is attached to the fuel hose inside the fuel tank. SeaFoam or a product called Start will sometimes clean the carburetor. If not, you will need to have the carb rebuilt, flushed or replaced.
Also, check your muffler and spark arrest, sometimes if they are clogged, you will have a similar issue.
Nov 11, 2017 | Craftsman 25cc Gas Line Trimmer
Runs on choke a little
sounds like the carburetor has gummed up a bit, and may need adjustments - or, the fuel pickup in the tank has come loose [i.e.: deteriorated fuel lines] - also, make sure your gas mix is FRESH. if your gas mix is more than 2 months old, dump it
Sep 19, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman flipover head string trimmer. Will not start. No spark.
could be coil also could be a fouled,dirty flywheel,check coil wire
Aug 25, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman gas 25cc weedwacker starts, runs a few secs, then dies
The gas take up line is disconnected or is broken. I have the same problem and need to find a diagram to fux it.
May 17, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 17" 25cc Trimmer...pull cord stuck
it's doubtful that bad gas caused this, it sounds like the cord was back-lashed and partially came off the recoil pulley. Remove the recoil cover and ensure the cord is all on the pulley, make sure the rewind mechanism works smoothly before re-installing.
May 07, 2009 | Craftsman 25cc Gas Line Trimmer
Trimmer starts immediately, then stops
How old is the trimmer? If still under warranty, Sears can fix this. If not, then my experience has been the problem is a bad coil. This is due to heat build up. When the coil gets hot, it shorts out.
Dec 04, 2008 | Craftsman 25cc Gas Line Trimmer
Craftsman 25cc Gas Line Trimmer Logo
537 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
