Question about Lexmark JetPrinter Z11 InkJet Color Printer
Z11 Printe Cartridge Stuck
Replaced the cartridge and had to load up the driver. The system asked to run an alignment process and proceeded to push two pages out of the printer with no printing. The system reported an error with the print job. Now the print cartridge and holder are stuck to the extreme right of the machine. Can't move it.
  • 54 Answers
First push cartridge inside and then try push out side and then keep the cartridge at right place and push it inside after pushing in make sure some green light blinking and start printing it
Posted on Feb 25, 2009
Epson bx300f printer wont print black.I have replaced all ink and run maintenance checks
According to your problem first make sure the cartridge you have replaced are original and not refilled old cartridge. Always using original cartridge is recommended. If the all of the above conditions are OK then first align the cartridges and also clean the cartridge head. You can also replace the same cartridge after a little shaking of cartridge. Take out the cartridge from the printer by the recommended process, shake the cartridge and make sure the ink is OK and not dry, then replace it again. open the printing preferences window form printer properties in your PC and align the cartridges, then reboot the printer after deleting all print job in print queue.
Apr 28, 2011 | Office Equipment & Supplies
Even with a new cartridge inserted, the printer does not print properly. The printer does not indicate that a new cartridge is needed. How do I clean the printer head? It is a HP Photosmart C3180 al in...
Step one: Complete the alignment process If you have already installed new print cartridges, follow these steps to complete the alignment process.
  1. After installing a new print cartridge, wait at least 20 seconds for the print cartridge alignment process to start.
  2. Wait for the print cartridge alignment process to fully complete.
  3. Make sure that the alignment page has printed on plain, white paper that has no other printing on it. If you need to create a new alignment page, load the tray with letter or A4 unused plain white paper and turn the product off and on again to create the page.
If an alignment page does not print when the product is turned on or off, the issue is resolved. If an alignment page continues to print when the product is turned on or off, you should replace the cartridges with new HP cartridges. Continue to Step two: Remove the print cartridges. Step two: Remove the print cartridges Follow the steps below to remove the cartridges. NOTE: When you remove and install the same print cartridge, the unit will not align the print cartridge as the unit remembers the alignment values for that print cartridge.
  1. Press the Power button to turn the product on. The Power button is lit when the unit is on. Figure 1: Power button lit c01336350.gif
  2. Make sure that the paper tray is down, and letter or A4 unused plain white paper is loaded in the paper tray.
  3. Lower the access door until it stops. Make sure that the print carriage moves to the right side. Figure 2: Lower the access door c01336351.gif
  4. Wait until the print carriage is idle and silent, and then using your thumb, lightly press down on a print cartridge to release it. Figure 3: Print carriage c01336352.gif
    • If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
    • If replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.
    Figure 4: Proper position of the print cartridges c01336353.gif 1 - Tri-color print cartridge 2 - Black or Photo print cartridge
  5. Pull the print cartridge toward you and out of its slot.
Step three: Install the new print cartridge
  1. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. Figure 5: Remove the tape c00312625.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00312564.gif
  2. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket.
    • If you are installing the tri-color print cartridge, slide it into the left slot.
    • If you are installing a black or photo print cartridge, slide it into the right slot.
    Figure 6: Print cartridge locations c00652788.gif 1 - Print cartridge slot for the tri-color print cartridge 2 - Print cartridge slot for the black and photo print cartridges
  3. Close the print cartridge access door. Figure 7: Closing the print cartridge door c00652789.gif
  4. If you installed a new print cartridge, the print cartridge alignment process starts after about 20 seconds.
  5. The unit aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
If you have completed all the steps listed above and are still experiencing a problem, service the product. Cause The product aligns the print cartridges every time at cartridge installation or replacement to ensure the highest-quality prints. The alignment page continues to print when the product is turned on or off, or when a print job is started, for any of the reasons below.
  • The automatic alignment process is not complete.
  • The ink cartridges are not properly installed.
  • One of the ink cartridges is defective.
  • One of the ink cartridges is low or out of ink. Black and all three colors must be available.
  • Protective tape on a new ink cartridge has not been removed.
  • Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
  • Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
  • The product needs to be serviced.
Aug 28, 2008 | HP Office Equipment & Supplies
I have a non HP cartridge in my K550 it will printe one copy and then ask for an authentic HP cartridge, I reset and will again get one copy and then the request for HP cartridge...How can I by-pass this...
Each printer require certain matched type of cartridge, if you use another type of cartridge it may broke the system or the printer itself. Instead of trying to skip this notification, I think it would be wiser if you change the cartridge with the original one. It may more expensive, but guaranteed compatible with the printer and the software.
If you resist use this non HP cartridge, try to re-install the driver with this cartridge attach in the printer.
Hope this help.
Feb 03, 2011 | HP Officejet Pro K550 InkJet Printer
The alignment both vertical and horizontal are off!
Title: How to Install/Change the Print Cartridge Document ID:HO46 Back To Answers Properties 1000 Color Jetprinter 1100 Color Jetprinter 2030 Color Jetprinter 2050 Color Jetprinter 2070 Color Jetprinter 3000 Color Jetprinter 3200 Color Jetprinter 5000 Color Jetprinter 5700 Color Jetprinter 5770 Photo Jetprinter 7000 Color Jetprinter 7200 Color Jetprinter Lexmark X63 Lexmark X73 Lexmark X83 Lexmark X84 Lexmark X85 Mac OS 8.6 Mac OS 9.x.x WinWriter 100 WinWriter 150c Z11 Color Jetprinter Z12 Color Jetprinter Z22 Color Jetprinter Z25 Color Jetprinter Z31 Color Jetprinter Z32 Color Jetprinter Z34 Color Jetprinter Z35 Color Jetprinter Z42 Color Jetprinter Z45 Color Jetprinter Z45se Color Jetprinter Z51 Color Jetprinter Z52 Color Jetprinter Z65 Color JetprinterHow to install or change the print cartridge; Microsoft Windows 95; Microsoft Windows Me; Microsoft Windows 3.1x
Solution Microsoft Windows 95/98/Me:
(Applies to all printers)
  1. Click Start, Programs, Lexmark Series.
  2. Click Lexmark Control Panel.
  3. Click Print Cartridge installation.
  4. Depending on which cartridges you are using and which printer model you have, select Install Color Cartridge or Install Black Cartridge or Install Photo Cartridge.
  5. Carefully remove the tape covering the printhead of the print cartridge. Important: Be sure to remove all of the tape. Do not touch the copper area on the back of the cartridge.
  6. Insert the print cartridge into the print cartridge carrier.
  7. Push the cartridge back until it clicks into place.
    • If the print cartridge moves loosely in the carrier, it is not locked into place. Repeat step 7.
  8. Click the appropriate Cartridge Installed option in the printer software.
    • If you choose to install a new print cartridge, you will be prompted to align your print cartridges. The printer will print a page with a bi-directional alignment pattern. Follow these steps to align the cartridges:
      1. On the printed test page, locate the number under the Bi-directional Alignment pattern that comes closest to forming a straight line.
      2. Enter the number as the Bi-directional Alignment setting in the Alignment Cartridge screen.
      3. Click OK.
  9. Close the front cover of the printer.
Dec 16, 2009 | Lexmark JetPrinter Z11 InkJet Color...
How do I align ink jets?
      3. Click OK.
Nov 13, 2009 | Lexmark JetPrinter Z11 InkJet Color...
Lights are flashing on printer and it will not print . the voice says there is a problem with the printer. I did the alignment process but the voice keeps saying there is a problem. I took both cartridges...
There 3 light on the printer that able to indicate to user when problem occur. Which is the light u mean here?
1st button light blink rapidly = the printer may be out of paper, so load more paper and press the 1st button itself to continue. Or may be paper jam is occur, so clear the paper jam and press the 1st button light itself to continue.
If 1st button light blink slowly = mean the cartridge carriers are stuck, so raise the scanner unit and remove any object blocking the path of the cartridge carrier, make sure the cartridge are closed and installed properly, then lift the scanner unit, gently push the scanner support towards the cartridge carriers, and carefully lower the scanner unit until it is completely closed. After that press the 1st button itself to continue.
If 2nd LED light blinking = the color cartridge need to be replaced soon.
If 2nd LED light is ON = the color cartridge need to be replaced immediately.
If 3rd LED light blinking = the black cartridge need to be replaced soon.
If 3rd LED light is ON = the black cartridge need to be replaced immediately.
YBC (/\)
Sep 28, 2009 | Lexmark X2500 All-In-One Printer
Triple vertical printing with Z11
Here's what worked for me: (I'm using a black ink cartridge, but my 'printer properties' were set for a color cartridge, thus basically sending a '3-color signal' to my printer; making it print in triple vertical.)
Go to Settings > Control Panel > Printers. Right click on your printer, and click Properties. Click the Cartridge Maintenance tab, then click Install / Change Cartridge. Select the cartridge you are using in the drop-down list, and click Continue. Print an Alignment Page. If this dosen't work, close everything and try it again: I had to do it twice to get mine to work. Hope this helps!
Kerry
Apr 27, 2009 | Lexmark JetPrinter Z11 InkJet Color...
Lexmark z11 Vista Compatible?
Looks like I've cracked it [Touches wooden desk]. Need a USB to IEEE 1284 36-pin Parallel Printer Cable, like the one I received today (ordered yesterday from www.cables2u.co.uk). First, connect it to Z11. Turn on Z11 and boot up Vista PC/laptop. (I run Vista Business on my laptop.) Connect cable to computer. Message appears "Installing device driver software". Click it for status. 'Found New Hardware' box appears. Click 'Locate and install driver software'. A message appears "Error loading LXADSUI.DLL. Specified module could not be found". Click 'OK'. Message appears saying driver software installed successfully. ["Yeah, right ..."] (Have faith, folks!) Now, click Start, then Control Panel and double-click Printers. Right click on Z11 and click on Set As Default Printer. Right click on Z11 again and click on Properties. Check on Ports tab that Port USB is ticked for Z11. On Cartridge Maintenance tab, check right cartridge is showing. If not, click 'Install/Change Cartridge' and follow instructions. Then 'Clean Print Nozzles' and 'Align Cartridges'. Check settings on the other tabs in Properties look OK and try printing a test page! It looks good to me!
Jan 15, 2008 | Lexmark JetPrinter Z11 InkJet Color...
Black cartridges won't print. Color cartridge works.
Why dont you go to the store that you bought the printer from and ask one of there people there fix the problem..
Dec 28, 2007 | Compaq Inkjet Ij300 Printer
Lexmark z11
Your printer thinks you are using a color cartridge. If have the lexmark printer manager software, go to "install new cartirdge" and tell it that you are using a black cartridge. Otherwise, install a printer driver, reinstall the printer, and set it up again.
Driver link (if needed):
http://downloads.lexmark.com/cgi-perl/downloads.cgi?lxkprod=Z11+Color+Jetprinter
Dec 24, 2007 | Lexmark JetPrinter Z11 InkJet Color...
Open Questions:
I have a Lexmark Z11 that sat unopened in the box for several years until it was given to me as an emergency printer. The black ink cartridge had been pilfered by the original owner ( he got several of the se printers on clearance for $15 each). I bought a remanufactures high capacity cartridge. It workef fine for the three days of printing I did last week (about 25-30 pages of resumes and reference letters). When I went to use it a week later, it goes through the motions of printing but no ink is put on the page. I ran the clean cartridge several times but still no ink. I tried the new still-in-the-box color cartridge and did get color on the page in the alignment trial, but it was faded and full of white lines. I figured the cartridge was just old. It could be the ink leaked out of the remanufactured cartridge, but when I gently blew on the air hole I got a small splat of ink. (I used to be a sales rep for Canon printers a dozen years ago and we were told to do that to see if the cartridge still had ink.) I deleted and reinstalled the printer, unplugged and replugged cable and power cord twice. The printer receives the command and goes through the motion of printing, but as I said, no ink is put on the page. I have come to the conclusion the perhaps the remanufactured cartridge is at fault and I should take it back for an exchange, Can I get your take on it - is it the cartridge or the printer? Thanks! -Kathleen Brockway
Mar 01, 2017 | Lexmark JetPrinter Z11 InkJet Color...
Lexmark JetPrinter Z11 InkJet Color Printer Logo
228 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
