Question about Riso RZ220 Duplicator
My Riso RP 3100 is not getting ink to the drum I switched out to another drum and the same thing- feels like the machine ''attacked'' the second drum the same way. Master is almost dry. Any help?
  • cards624 Mar 03, 2009
    The machine recognizes ink, but drum is dry
  • Ian  Auret
    Ian Auret May 11, 2010
    Is the maschine asking for ink?
    or does the machine reconised there is enougth ink but the drum is still dry?
  • 318 Answers
Ok,if you strip the drum open and remove the drum body there is a gear with a one way bearing on the inking roller remove that gear and clean the bearing and the sarft it is running on.If the machine is giving the same problem that ger needs to be replaced.
Remember if you strip the drum the drum is full of ink and can get everything full of ink.If you dont know how to strip the drum it is beter to get a qualified technicin to do the job.
Hope this was helpfull
Posted on Mar 03, 2009
How do i change the color of riso drUm from red to burgundy?
How-to: Convert Z-type Color Drums ' stencil.wiki
stencil.wiki/how-convert-z-type-color-drums Procedure for converting the color of a Z-type drum. Steps 1 - 9 also work ... Z-type Color Drums. Posted: 17 Oct 2014 14:04 by issuepress Last edit: 01 May 2015 14:20 by issuepress ... This tells the Riso to recognize newly installed ink tube.
Riso RP3505 drum color change - CopyTechNet.com
www.copytechnet.com > Forum > Technical Forums > Digital Duplicators Sep 9, 2008 - 3 posts - ‎3 authors Is there any way to change an RP color drum to black? How to change a drum color on a Riso MZ 770E? (I'm new ... 3 posts 8 Apr 2014 Riso gr3750 Drum versus GR377\GR373 Drums. 6 posts 1 Jul 2013 Riso RP3700 Print drums wont ink up 7 posts 28 Sep 2012 Riso GR 3750 alignment, drum and colour change ... 9 posts 3 Oct 2009 More results from www.copytechnet.com
change color drum riso Questions & Answers - Fixya
www.fixya.com > Forum > Tags Find solutions to your change color drum riso question. Get free help, tips & support from top experts on change color drum riso related issues.
Risograph GR drum conversion.mp4 - YouTube
z? 0:25 https://www.youtube.com/watch?v=YCttIfFdu0Q Jun 30, 2012 - Uploaded by SpareResidency Used citrus solvent to clean the exterior of an old red drum then switched the ink for a new tube of blue.
My Top 7 Risograph Lessons - Alfalfa Studio
alfalfastudio.com/my-top-7-risograph-lessons/ Jun 16, 2014 - When you need to add another color, you open up the drum door and change the drum to use purple, for example. The Risograph prints one ...
Replacing The Print Drum (cylinder) (color Change ...
www.manualslib.com > ... > Printer > RZ1090 > User manual Riso RZ1090, RZ1070 Manual Online: Replacing The Print Drum (cylinder) (color Change), Replacing The Print Drum (cylinder) (color Change), Removing The ...
Riso printing - Instructables
www.instructables.com/id/Riso-printing/ Risograph The underlying technology is very similar to a mimeograph. ... This master is then wrapped around a drum and ink is forced through the ... Change the color drum, change the paper on the glass sheet, make a master layer and . ... Remember that every different color you want to print, you have to print separate.
Jan 31, 2016 | Office Equipment & Supplies
Riso rp error t98-526
526 Drum set safety switch is ON, but drum connection signal is OFF.
try to remove the drum and re-install it. hope to be of help
Feb 25, 2013 | Riso RP 3700
System error T01-521
mon riso RP 3100 ep donne le code to1-521. veuillez me trouver une solution merci
Nov 22, 2012 | Riso RP 3700
I have a Riso RP 3700 and I changed a drum from brown ink to yellow ink and I can't get the brown ink to clear away, no matter how many sheets I run thru with yellow ink.
I've read a little about flushing drums with solvent or even gasoline or diesel google it a little see how people have done it. though I can imagine a Switch from a dark to light colour might be impossible. You could pull the screen off and wash it out. Some ideas. No solutions.
Jan 12, 2011 | Riso RZ220 Duplicator
Master wont ink up on riso 3700, How do I check ink pump and test
This is unlikely that the pump is not working.. I have 2 RP 3700s.. The screens are probably clogged.. with old ink.. or there could be a fit problem with the ink tube to the drum.. (no vacuum). With the drum in the machine and the ink in installed.. Take handle of a hammer and lightly (LIGHTLY!) push to ensure that there is no air pocket in the ink tube.. Carefull not to push too hard and squirt ink all over inside the machine. Also ink screens can be taken off and cleaned with varsol and re-installed.. Also as a final check.. make sure you are makeing a master.. look closely to see if you have a lazer burned image on your master.
Jun 02, 2009 | Riso RZ220 Duplicator
What does the error code E 01 stand for?risograph 4050
If its CR or TR, E-01 is main motor lock. turn off machine and hold reset button in while you turn the machine on again. Make sure your master removal unit and master feed unit are closed corectly.
Apr 07, 2009 | Riso RZ220 Duplicator
Risograph rp 3100 ui
Reset machine... and check connectors to the boards... its a communications error to the digitizer cpu
Oct 13, 2008 | Riso RZ220 Duplicator
Rp 3100 Drum Problem
You can clean it, thats a good idea but,,(and this is messy) roll back the master.. take out the ink cartridge, use a rod to squeeze some ink onto the area, and smooth it out into the screen with a plastic scraper.. Lay the master back over. Keep scrap paper around and print a big black square and run a couple hundred sheets through.. This will work. Messy but will work. If you don't want to manually put some ink on the area.. Print a large black square and run a couple hundred sheets.. see what that does.
Sep 10, 2008 | Riso RZ220 Duplicator
500 people viewed this question
Top Riso Office Equipment & Supplies Experts
Marius Chiriac
paulfvincent
Adorjani Laszlo
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
